Some LiFePO4 Battery Testing Results Manual and Automated
Old April 19th 19, 01:58 PM posted to rec.aviation.soaring
Default Some LiFePO4 Battery Testing Results Manual and Automated
On Thursday, April 18, 2019 at 11:09:51 PM UTC-4, kinsell wrote:
On 4/17/19 7:58 PM, John DeRosa OHM Ω http://aviation.derosaweb.net wrote:
Luckily with the LiFePO4 batteries when they get below ~11.0Vdc the BMS basically shuts the battery off.
True for most of them, but some of them don't actually do that. Easy to
ruin the battery that way. If I were building a battery tester, I'd
include an automatic load cutoff.
The "B6" device will stop the discharge at 2V per cell. That's only 8 volts for a 4-cell ("12V") battery. That's rather low, although supposedly does not harm the battery. But you can cheat and tell it it's a 5-cell battery, then it will stop at 10V. Just remember to change it to 4 cells for charging!!!
A "12V" LiFePO4 battery in good shape will maintain above or close to 12V for almost all of its discharge curve, then plummet rapidly at the end.
Old April 21st 19, 06:56 AM posted to rec.aviation.soaring
2G
On Wednesday, April 17, 2019 at 6:58:40 PM UTC-7, John DeRosa OHM Ω http://aviation.derosaweb.net wrote:
Every year I test my two LiFePO4 batteries to gauge how long they will last during a flight. I decided to open the field a bit and also tested some soaring friend's batteries.
You can read about my simple cheap manual process (later automated - see below) here http://aviation.derosaweb.net/#batterytest which was also detailed in Soaring (Feb 2012). Yeah, I know there are automated testers on the market but I want to create something cheap that everyone can make.
My battery go/no-go is how long it will take for the battery to drop to 12.0Vdc with a continuous 12Ω (~1A) resistive load. Here is what I found;
2013 Bioenno Model BLF-1209T- 6.5H
2015 Stark Model SP-12V9-EF - 5.5h
2015 Bioenno Model HN12V9AHF- 7.0H
2017 Bioenno model BLF-1209WS - 9.0H
Full details of my results can be found here http://aviation.derosaweb.net/batter...s_04.08.19.pdf
Anyone else tested their batteries in this same way? What are your results?
Automation - Manually gathering data every 10 minutes for 6-9 hours on four different batteries is tedious at best. I watched a lot of movies. So I decided to automate the process with an cheap $10 Arduino Duo. The Arduino software takes a reading at different points of time based on the current voltage. Every one minute at the beginning and end of the test, and every 10 minutes in the middle.
It still takes 6-9 hours to run the test but recording the voltages is fully automated so running the test is a start-then-walk-away-and-come-back-later-for-the-findings kind of deal. Luckily with the LiFePO4 batteries when they get below ~11.0Vdc the BMS basically shuts the battery off. The program detects any voltage drop below 8Vdc and terminates itself.
If anyone is interested in duplicating my Arduino test rig, drop me a line and I will share the details. My Arduino code can be found at http://aviation.derosaweb.net/batterytest/arduino.
John OHM Ω
It would be helpful to modify your spreadsheet to calculate watt-hours. Comparing batteries by amp-hour capacity was ok when using the same chemistry, but is not misleading when comparing SLA to LFP.
There is a marketing ploy among the LFP manufacturers called "equivalent SLA capacity." It turns out that they are using very high discharge rates (10C) to come up with this so-called "equivalent capacity." When WH capacities are compared at a more typical glider situation, 1C, the LFP has about a 7% WH advantage at the same AH rating.
The big advantage of LFP batteries is there slower aging characteristic. SLA batteries can drop precipitously after 2-3 years of use, far beyond any datasheets I have read. They *should* be good for 400-500 discharge cycles. This would be at least 10 years of typical, non-commercial glider flying. Only once have I seen SLA batteries last more than 4 years, and most are really shot by then (50% capacity).
I encourage more sharing of battery testing of this sort. It will help us get a better handle on this annoying technology which even the big boys hate (just ask Boeing).
Tom
Old April 21st 19, 02:48 PM posted to rec.aviation.soaring
John OHM Ω
The big advantage of LFP batteries is there slower aging characteristic. SLA batteries can drop precipitously after 2-3 years of use, far beyond any datasheets I have read. They *should* be good for 400-500 discharge cycles.. This would be at least 10 years of typical, non-commercial glider flying. Only once have I seen SLA batteries last more than 4 years, and most are really shot by then (50% capacity).
Tom
Yeah, batteries, a love-hate relationship, can't live without them, but they suck. One thing about capacities: if you fully discharge an SLA repeatedly it shortens its life (as measured in years). Thus a "9AH" SLA is really about 5AH, unless you don't care if you have to replace it in less than 2 years. (They are cheap enough that you may not care.) OTOH the LFP battery you can bring right down to where it shuts itself off and no harm done. So if it is honestly rated, a 9AH LFP truly has usable 9AH, perhaps 8AH after a few years. Just don't touch any LFP rated as "xxAH SLA equivalent", those are designed for starting motors (e.g., for motorcycles) and they are "equivalent" in cranking power (peak current) but not real AH (low current for hours).
Moreover, the voltage of the LFP stays higher (say well above 12V) for a much higher portion of its discharge cycle, then plummets. That means less warning about when it will run out, but meanwhile your radio transmissions will be good. An SLA gradually declines in voltage as it discharges, and some radios (and some other devices) may not work as well on, say, 11.7V.
Albeit most modern glider-oriented devices (e.g., varios) are designed to work normally down to 10V or so. Devices with internal switching power supplies draw more current when the supply voltage is lower, roughly a constant power draw (watts). E.g., I measured the current draw of a Portable PowerFLARM and it was roughly between 100 and 200 milliamps, depending on the supply voltage, the higher the voltage the LOWER the current (very unlike a light bulb). That's why an LFP, with its somewhat higher voltage, yields a longer run time than an SLA for the same amp-hours discharged.
Old April 22nd 19, 03:48 AM posted to rec.aviation.soaring
2G
John OHM Ω
The big advantage of LFP batteries is there slower aging characteristic.. SLA batteries can drop precipitously after 2-3 years of use, far beyond any datasheets I have read. They *should* be good for 400-500 discharge cycles. This would be at least 10 years of typical, non-commercial glider flying. Only once have I seen SLA batteries last more than 4 years, and most are really shot by then (50% capacity).
Tom
LFP batteries are not immune from accelerated degradation due complete discharge, but may be less affected than SLA. There has been a recent report about Nissan Leaf batteries losing 10% capacity per year:
file:///C:/Users/tom_s/Downloads/preprints201803.0122.v1.pdf
These cars used a nickel manganese cobalt chemistry, so is not directly applicable to LFP. I think we will have to collect the data as there is no upside for manufacturers doing it.
Most avionics are using switching power supplies, so we should be comparing batteries on the WH capacity, not AH. LFP manufacturers are using SLA AH-equivalent comparisons for energy storage applications, not starter batteries, which have markedly lower energy storage. Motorgliders are a somewhat unique situation where you would like to do both with the same battery.
Tom
Old May 2nd 19, 10:11 PM posted to rec.aviation.soaring
Some updates;
- I was lent a Bioenno BLF-1209WS purchased in Jan 2019. Tested and ran for 8.8h.
- Updated my Arduino automated tester by adding an "LCD Keypad Shield" display to allow monitoring of the testing. The updated code has been uploaded..
- Created a new XLS spreadsheet to parse the automated testing results and create a graph from them
- Added pictures of my test rig.
Find all this, and more, at http://aviation.derosaweb.net/batterytest.
John OHM Ω
Old May 2nd 19, 10:27 PM posted to rec.aviation.soaring
Dan Daly[_2_]
On Thursday, May 2, 2019 at 5:11:13 PM UTC-4, John DeRosa OHM Ω http://aviation.derosaweb.net wrote:
Some updates;
John OHM Ω
I get 404 not found at http://aviation.derosaweb.net/batter...g_Template.xls and the other two as well. I do see the SOARING reprint, though.
Old May 3rd 19, 05:33 AM posted to rec.aviation.soaring
Some updates;
John OHM Ω
Dan - You might just need a web page refresh as I had been actively updating the web page around the time of your 404. Let me know if it still fails.
Old May 3rd 19, 12:13 PM posted to rec.aviation.soaring
Dan Daly[_2_]
On Friday, May 3, 2019 at 12:33:46 AM UTC-4, John DeRosa OHM Ω http://aviation.derosaweb.net wrote:
Some updates;
Find all this, and more, at http://aviation.derosaweb.net/batterytest..
John OHM Ω
John - it now shows the "updated" banner, and I can download. Thank you! Your page is a great resource!
Old October 14th 19, 11:37 PM posted to rec.aviation.soaring
Default Some LiFePO4 Battery Testing Results Manual and Automation update
You may remember last spring that I did some testing under load of my (and others) LiFePO4 batteries. After a year's worth of soaring I tested my two batteries again. Below is an update and comparison.
Tested was done with a 1A load and after just coming off the charger to when the battery has discharged to 12Vdc.
2015 Stark - Model SP-12V9-EF
April 2019 - 5.71h
October 2019 - 5.49h (loss of 13.3mins or 3.8%)
2017 Bioenno - Model BLF-1209WS
April 2019 - 8.83H
October 2019 - 8.85h (loss of 12.0mins or 3.2%)
I also updated my Arduino based testing rig's display. Previously, I used a simple 2 line by 16 character LCD B/W display. Now I am using a 240x320 pixel LCD touch sensitive color display. Oooooo, cool (and surprisingly cheap).
The new display allows me more room to display information during testing and to create a real time graph of the data. Displays are more fun than necessary but what the heck. There is amazingly inexpensive open-source hardware available for the Arduino system. The O'Reilly "Arduino Cookbook" leads you by the hand to create some powerful cool tools.
Information can be found at http://aviation.derosaweb.net/presen...s/#batterytest.
Old October 16th 19, 03:44 AM posted to rec.aviation.soaring
2G
On Thursday, May 2, 2019 at 2:11:13 PM UTC-7, John DeRosa OHM Ω http://aviation.derosaweb.net wrote:
Some updates;
John OHM Ω
Congratulations on building a battery tester (I wouldn't bother, myself).
But here are the shortcomings of your tester:
1. It has no discharge cutoff. It keeps discharging the battery until totally discharged. This can damage the battery, and is certainly not good for it. I would not test a battery w/o this.
2. It does not discharge at a constant current. The current decreases as the voltage drops. Modern battery testers will do this.
3. It does not discharge at a constant wattage. This is a more typical scenario where avionics will increase current as the voltage drops.
That said, it is better than sitting down for 6 to 10 hours and recording meter readings. I have switched my avionics battery from a Pb to a LiFePO4 partly because I don't want to buy a new battery every 2 years.
Tom
Test results LiFePO4 glider batteries after 6 years SF Soaring 102 August 9th 18 06:46 PM
Resetting a Bienno LiFePO4 Battery OHM Ω http://aviation.derosaweb.net Soaring 3 June 26th 18 09:26 PM
LiFePO4 battery technolocy [email protected] Soaring 9 October 17th 12 10:05 PM
LiFePO4 battery ASM Soaring 4 December 6th 11 07:00 PM
Spring Cleaning and Battery Testing ContestID67[_2_] Soaring 34 March 20th 11 06:49 PM
