Winter project
Old December 30th 04, 10:16 PM
Default Winter project
Just changed the memory battery in my Cambridge model 20 GPS recorders.
No big deal, Rex who the Cambridge dealer at Williams Soaring showed me
how:
+ Purchase new batteries #2325 from local drug store/ radio shack.
+ Power up your GPS in order not to lose memory and security.
+ Remove 2 screws that hold antenna.
+ Under antenna you will see the battery, hold clip up and slide old
battery out.
+ Slip new battery in (+ up)
+ Replace antenna and screws.
Now that wasn't all that hard, was it? I used a small screw driver to
hold the retaining clip up, it would be a good idea to NOT touch the
case with any tool used to remove the battery. Case is probably
negative and we're working on the positive side of the battery. If you
get a spark followed by a puff of smoke------------------------I have
found the only way to get that little puff of smoke back inside the
little black box is to send it back to the factory.
Enjoy,
JJ
PS, My memory battery now reads 3.3 Volts, not its normal 2.8
PS #2, A day was lost at the standard nats this year because of "No
Trace"
V-6 STOL Project For Sale Bruce A. Frank Home Built 0 January 28th 05 07:28 AM
Tie-down winter hazards [email protected] Owning 6 January 12th 05 10:23 PM
Winter Flying [email protected] Piloting 36 January 3rd 05 03:19 AM
AI Acft- A Gem Discovered mike popken Simulators 4 January 11th 04 05:06 AM
Question: Researching Project Tilt Home Built 21 December 17th 03 02:39 PM
