Puchacz fatal accident 18 Jan. 2004 at Husbands Bosworth.
Old January 14th 05, 08:04 PM
Ian Strachan
In article , Andrew Warbrick
writes
snip
I won't let a spin demo go beyond the incipient stage
below 1500', but then, I'm a wimp.
Dear Andrew,
You are not a wimp, you are sensible and alive. And so are your
students.
Having flown many spins in a military training environment, there was
always a "golden rule" on recovery heights. Heights for spin entry and
minimum heights for recovery were always such that if recovery had not
taken place, there was sufficient height to bale out or eject as
appropriate. I speak of the fully-developed spin, of course. Bale-out
heights were, to my recollection, something like 4000 ft for a Harvard
and Jet Provost and no less than 12000 ft for a Hunter. I recall a
Hunter spin bottom out once at 6000 ft but passing 12 it was recovering
so the crew stuck with it. They started at 35k, by the way!
It is this simple safety rule that some parts of the gliding world seem
to have forgotten. An instructional cult seems to have grown up in some
places that seems to think that low level spinning is an absolute
necessity to teach student pilots of the dangers. I instructed in
gliders for 35 years and IMHO, it is not necessary. Recovery from
fully-developed spins can be taught at a safe height just as in other
branches of aviation. There is nothing "macho" about spinning too low,
just a failure to understand the dynamics of the manoeuvre and the
possible dangers not only to the instructor but to the innocent student.
In any case, the emphasis in instruction should be on quick recovery at
the wing-drop or incipient stage before the spin has developed fully.
THAT should be practised very regularly and full multi-turn spins only
rarely to show what can happen if the correct actions are not taken
early enough.
I have even heard it said by some instructors that deliberate low level
spinning is required because the student must experience the visual
"ground rush" that he/she would get in a real situation of an
inadvertent spin at low level. This is a good way to an early grave,
particularly if something happens in one of these low level spins such
as control failure, rudder cable slackness, or even as simple as
someone's foot trapped the wrong side of a rudder pedal.
Also, spins are not regular reliable manoeuvres with streamlined stable
airflow, they are complex interactions between turbulent (stalled)
airflow, significant control moments and inertia/gyroscopic effects.
Occasionally, for no particular reason other than statistics, a spin
will go deeper into the stall (high alpha) than normal, and recovery
will be delayed. Think of this before continuing a deliberate
fully-developed spin below the height above the hard stuff at which it
would be possible to bale out if the recovery were to go wrong.
There are old pilots and there are bold pilots, but there are few old,
bold, pilots. An aviation truism, I think. Me, I'm old but still here
and enjoying cross country soaring!
Ian Strachan
Old January 14th 05, 08:41 PM
Don Johnstone
Spot on Ian. The rules for the Air Cadets in the UK,
RAF rules, prohibit intentional spinning below 2500ft
in a glider. If you are still spinning you abandon
at this height and to my mind this is one of the most
sensible rules the AC have. Even that might be cutting
it a bit fine depending on how easy it is to actually
get out of the glider.
writes
snip
Dear Andrew,
so are your
students.
there was
always a 'golden rule' on recovery heights. Heights
for spin entry and
if recovery had not
or eject as
course. Bale-out
ft for a Harvard
I recall a
the way!
gliding world seem
is an absolute
I instructed in
Recovery from
just as in other
branches of aviation. There is nothing 'macho' about
spinning too low,
and the
developed fully.
spins only
are not taken
early enough.
the visual
'ground rush' that he/she would get in a real situation
of an
to an early grave,
level spins such
as simple as
streamlined stable
(stalled)
effects.
a spin
and recovery
deliberate
stuff at which it
to go wrong.
there are few old,
old but still here
Ian Strachan
Old January 15th 05, 01:54 AM
I think that the strong criticism of the Puch is totally unwarranted.
Puchacz was designed as a initial training ship but also one which can
fly many more aerobatic maneuvers then some other gliders. Puch can fly
rolls, loops, spins, hammerheads, snaps, you can teach inverted flight
in it, etc. It is called "advanced aerobatic trainer". It is quite a
remarkable glider. Of course the Germans will never admit it, so they
going to insist on their DG's. The point here is, after reading the
accident report it indicates to me a pilot error. Each glider has a
different characteristics. Some of them will recover with the stick in
the full aft position and some will not. Plain and simple. Each glider
comes from the factory with its manual. And that manual will tell you
how to fly specific ship. This is the same as comparing 7ECA Citabria,
which will recover from a spin with full aft elevator, to a Sukhoi 26:
this one needs to be recovered with the stick forward to break the
stall. You see, pilots flying aerobatics are aware of the handling
characteristics of the planes they fly. If I will be teaching a student
spins, I will be at 5000 + AGL. Why? Because if something goes to crap
I still have time to get out. They were flying spins at 1500. So, you
might say it is legal because the FARs are saying "no aerobatic
maneuvers below 1500' " . But is this really smart? Anyway, we can beat
the horse to death and everybody will have a different opinions. I
flown in SZD-50-3 Puchacz in the early and mid eighties with test pilot
January Roman with saddle bags filled with led near its tail to
simulate the aft C.G. without any problems. In addition we have done
those spins inverted as well...no problems. And we have done several
times. Puchacz is a trainer but it is also more then a trainer.
Approach it properly, with good manners and everything will be fine,
screw with it and it will bite. But the same is true for other gliders
and airplanes. Even for the DG. Everything else is in the pilot hands.
Old January 15th 05, 04:46 AM
JohnWN in Burke, VA
This isn't directly related; however, I ran across this article in the Dec.
2004 Glider Magazine. Apparently, the front control column failed.
"SZD-50-3 Puchacz Grounded in Poland":
http://www.glidingmagazine.com/NewsArticle.asp?id=1375
John In Burke, VA
"T o d d P a t t i s t" wrote in message
Andrew Warbrick
I read it and came away thinking the Puch was still
a possible culprit.
How? As stated in the report the Puch spins readily
but recovers very easily. Quoted from the report:
'It can reasonably be concluded that the only control
mishandling of the PUCHACZ
that can lead to delay in spin exit is the retention
of full pro spin elevator.. '
I was referring to these parts of the report:
"The trial confirmed that the glider was compliant with JAR
22; however, it considered that two areas
were worthy of additional comment. The trial considered the
aircraft to be only marginally compliant in respect of
stalls during turns and noted that avoidance of uncontrolled
rolling and spinning off a turn was reliant on pilot
awareness and skill. The trial also noted that height loss
in a spin was significantly greater than on other types and
that this was largely due to the steep attitude
(70 ° nose down) of the developed spin."
And this part:
"The JAR recovery procedure first introduces full opposite
rudder to counter the yaw rate. This use of rudder on the
Puchacz leads (to) a pitch down in the spin which reduces
incidence sufficient to facilitate auto recovery at forward
CG where recovery then occurs. As the established spin is
already estimated at 60-70 degrees, this pitch down gives a
very steep exit, perceived to be over vertical but probably
not so. It also contributes to the extensive height loss
during exit. In a tense or panic situation, particularly at
low level, the involuntary reaction could be expected to be
retention of full aft stick. This will sustain a spin
against full opposite rudder at CG aft of 6.0 inches aft
of datum."
The CG of the accident aircraft was behind "6.0 inches aft
of datum"
I also noted the fact that including this accident there
were six Puch spin accidents in the U.K. and five included
fatals. There are many more in the U.S.
I do, however, have to agree, we will never know exactly
what happened in this awful tragedy and any further
speculation over it is probably counter productive.
We agree it was an awful tragedy, but as I'm sure you know,
there is concern over the number of fatal spin accidents in
the Puch by relatively experienced pilots. A discussion of
reports like this is how future tragedies are avoided. I
was concerned by your comment that implied the report
exonerated the Puch, when I didn't read it that way. At the
very least, I would think Puch operators would want to make
sure they keep the CG of the Puch forward of the "6" aft of
datum" point per the recommendation discussed in the
report, and adhere to the spin altitude limits.
Old January 15th 05, 11:00 AM
Janusz Kesik
Uzytkownik "Andreas Maurer" napisal w wiadomosci
On 14 Jan 2005 16:13:14 GMT, Andrew Warbrick
Have you ever spun one?
Until now I have not even seen a Puchacz in real life - but the sheer
number of spin accidents with experienced pilots suggests that
something is wrong, don't you agree?
Why doesn't it surprise me? Most of the pilots who write the worst opinions
on Puchacz never have flown it, or even seen it.
I don't think this is the problem. A typical Puchacz spin accident has
the instructor onboard, and I'm pretty sure that most of these
instructors knew about the correct spin recovery procedure.
I think that they're often crashed in spins just because they're most often
used ships for spin training. Just because they spin in a textbook way and
need a textbook recovery to get out of a spin, not only 'releasing the
stick' just like the Bocian or Junior.
Here in Germany we also had our share of Puchacz spin accident. One
was a successful spin recovery that went into an opposite spin - the
IP was not able to recover the second spin before impact.
Maybe they were too surprised by the fact that the glider entered another
spin due to inproper recovery action that they had lost a little bit too
much time.
Regards,
Janusz Kesik
Poland
to reply put my name.surname[at]gazeta.pl
See Wroclaw (Breslau) in photography,
The XIX Century, the Festung Breslau, and photos taken today.
http://www.wroclaw.dolny.slask.pl
Old January 15th 05, 04:26 PM
Tony Verhulst
I wonder about "letting go the stick" and letting the glider recover
itself - is this really being taught as a procedure?
I have not done this in glider but it works just great in a Super
Decathelon. Even a fully developed spin recovers quicky but you do add
opposite rudder. My acro instructor (placed 10th in the 2004 World
Advanced Aerobatic Championship in Sweden, FWIW) claims that most
reasonably stable aircraft will recover in this fashion. The ones that
don't are the Pitts's and Extra's - designed for acro and nothing else.
I intend to try it in an L23 when the season starts up again.
Tony V.
Old January 15th 05, 08:16 PM
Don Johnstone
At 16:00 14 January 2005, T O D D P A T T I S T wrote:
(snip)
there
This raises an interesting point. I am not for one
moment suggesting that this is the case but what if
there were some condition or some sequence that made
a glider irrecoverable from a spin, how would we know?
The only witness to that fact would not be available
to us.
I agree speculation may be inappropriate but discussion
around future prevention should be encouraged. A glider
spinning is out of control. We all assume that the
glider can be recovered to controlled flight. One way
of preventing accidents is to discontinue spinning
at a sensible height or if that cannot be achieved
abandon the glider. I can see that the definition of
'sensible' height may result in heated discussion so
I will only say that I have my own limit which I will
use and which I brief to others when flying dual.
Old January 15th 05, 10:43 PM
Andrew Warbrick
Have you ever spun one? I will repeat myself, it recovers
from most spins with most cockpit loads if you let
go the stick, so on the majority of occasions the instructor
has to be vigilant that the pupil applies the correct
recovery or an incorrect recovery technique will have
been learnt.
- but the sheer
that
I wonder about 'letting go the stick' and letting the
glider recover
We teach our
student pilots to center the stick, and apply opposite
rudder - in
that order. Letting go the stick is an unknown procedure
for me, I
have to admit.
You didn't read what I posted did you? I said the problem
with the Puchacz as a teaching tool is that it recovers
too easily even if the wrong (letting go of the stick)
technique is used and that as instructors we have to
be very careful that the pupil is not learning an incorrect
technique (which includes the non BGA/JAR22 technique
of moving the stick forward and then applying opposite
rudder. To quote from the DG500 trainer flight manual
'Apply full opposite rudder against direction of spin,
pause, then ease stick forwards until the rotation
ceases, centralise the controls and carefully pull
out of the dive. The ailerons should be kept neutral
during recovery.' If you are teaching anything else,
you are in test pilot territory).
It may be possible to recover
by applying the full opposite rudder after heaving
the stick forward but it will be a delayed recover
due to control surface masking.
Hmm... looks like the missing 80 cm of wingspan on
the 505 really seem
to make a difference here - our 505 recovers nicely
even at fully aft
CG positions.
I can't remember precisely which of the 5000 variants
of the DG500 it applied to, it was probably the unflapped,
short span, retractable wheel version (whatever version
the SGC operates).
A pilot who has acquired the impression from the Puch
that all is required is to let go or relax the back
pressure could be killed in this situation.
spin accident has
of these
I think you've got the wrong end of the stick, I was
commenting that it is a problem with the Puch as a
tool for teaching spin recovery, not that it was a
factor in any accidents.
accident. One
spin - the
Which empasises the need to teach correct recovery
techniqes which include removing the opposite rudder
before loading the wings up pulling out of the dive.
Bye
Andreas
Regards,
Andrew
Old January 15th 05, 11:08 PM
Ian Strachan
In article , Tony Verhulst
writes
This idea seems a good way to die if you are already in a full spin,
particularly at aft C of G. I do no deny that it may work in some
aircraft but to get the idea that it is a good standard technique could
cut your time short on this earth.
Of course, you may not be in a fully developed spin, just in the early
stages before full autorotation has developed. In that case, just
centralising the stick and rudder (perhaps easing the stick forward) and
levelling the wings with aileron may work, but that just shows that you
were not in a condition of full autorotation which is the "fully
developed spin".
The standard recovery procedure once a full spin has developed that
works for most aircraft is,
1. Full rudder opposite to the spin direction (make sure it really is
opposite to the rotation, I for one have applied the wrong rudder in a
spinning jet when I was caught by a surprise departure).
2. Short pause,
3. Stick centrally and progressively forward until the rotation stops.
Keeping on absolutely FULL opposite rudder is important, some people
have only applied partial rudder with disastrous effects such as getting
into a high rotation spin. "Centrally" on the stick is important too,
applied aileron can adversely affect spin recovery. Some aircraft I
have flown that were regularly used for spin training, had a white
circle painted on the middle of the instrument panel to mark the
"central aileron" stick position for use during spin recoveries.
4. Centralise the rudder when rotation can be seen to have almost
stopped (if you wait too late to centralise the rudder, you will spin
the other way).
5. Ease gently out of the resulting steep dive, taking care not to
apply too much G (too much G can lead to G-stall or flick, and make
things worse). Bear in mind that after rotation stops, some gliders are
nearly vertical or even beyond (pitch angle, say, 100 degrees where 90
degrees is vertically down).
I do not know the L23, but be very careful in experimenting with fully
developed spins in any aircraft, that is, those with the nose well down
and over about two full turns. They can catch you out unless you
approach the exercise systematically. Aft C of G is particularly
dangerous, as is not having enough height to bale out if things go wrong
I do urge you to take such an exercise very seriously, as if your life
depended on it. As it does.
I speak as an ex military test pilot with much experience of stalling
and spinning in many types of aircraft, with and without engines. Any
fully developed spin is not to be taken lightly, at any altitude.
Recoveries from slow speed situations and wing-drops at the stall are
different, practise them often.
Conditions of full autorotation can be, often has been, and will
continue to be, fatal unless properly prepared for.
Ian Strachan
Old January 16th 05, 02:26 PM
Stefan
It doesn't work in "most" aircraft, but rather in *all* aircraft which
are JAR certified. In fact, for an aircraft to get JAR certification,
this method must recover from a spin of at least five full rotations.
(If the CG is within the stated limits, of course!)
Stefan
Who's At Fault in UAV/Part91 MAC? Larry Dighera Instrument Flight Rules 24 April 29th 04 04:08 PM
Single-Seat Accident Records (Was BD-5B) Ron Wanttaja Home Built 41 November 20th 03 06:39 AM
USAF = US Amphetamine Fools RT Military Aviation 104 September 25th 03 04:17 PM
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) Rich Stowell Piloting 25 September 11th 03 02:27 PM
