Bonanza Down
Old February 16th 05, 03:45 PM
"Jürgen Exner" wrote:
About 6,000 feet above the airport, his said his engine stalled.
He brought his plane onto a grassy field and eventually stopped on
Auld Road outside the airport.
Makes you wonder what went wrong such that he couldn't make the airport
Yeah, especially when the road is no more than 50ft from the threshold.
Probably more like 30ft.
Mike Flyin'8
Old February 16th 05, 06:24 PM
John T
Orval Fairbairn wrote:
Yes -- but the described circumstances would probably call for an FAA
checkride. If he overflew the airport at 6000 feet and lost his
engine and couldn't make the airport, there is something radically
wrong with his technique. 10 to 1 he never practiced power off
approaches.
Maybe, but my point was if you're going to start casting aspersions on other
pilots, make sure you're accurate in your own statements. "Forgetting to
*retract*" landing gear, as "cosmo_kramer" suggested, would not result in a
belly landing as described in the OP.
John T
http://tknowlogy.com/TknoFlyer
http://www.pocketgear.com/products_s...veloperid=4415
____________________
Old February 17th 05, 04:37 AM
Jürgen Exner
John Harlow wrote:
Gross said when his fuel tanks are at full capacity, his plane could
fly about 1,100 miles. He said he thought it was full when he left
Las Vegas.
Oh oh, not good. The insurance won't like that....
Which kind do they "like"?
The one that doesn't happen and where they can keep the money? ;-)
But, seriously, running out of fuel is one good reason for the insurance to
raise the rate dramatically. While an engine failure can happen for many
valid reasons, running out of fuel is almost always a stupid pilot error.
And insurances don't like stupid pilots.
jue
Old February 25th 05, 04:11 AM
Roger
On Tue, 15 Feb 2005 19:14:36 GMT, "OtisWinslow"
Ya know .. there's a reason I always track fuel usage off
of tach hours.
I even base my log on tac hours, but that has never kept me from
visually checking the level in all tanks.
On the Bo there really isn't an excuse for not being able to check
visually...unless you're 3 feet tall. Even my wife at 4' 10 1/2" (I
have to remember that half) can check everything except the tip tanks
and they are usually empty.
www.rogerhalstead.com
Old February 25th 05, 08:21 PM
Ben Hallert
Gross, who has been flying for 12 years, said he wasn't sure the
exact
cause of the aircraft's trouble, beyond the stalled engine, but he
suspected that one of the plane's fuel tanks was empty.
I'm still a student pilot, but the engine-out emergency checklist in
the plane I train in has a step to switch fuel tanks (and run fuel
pump) specifically to deal with this situation. At 6,000 feet, he
should have had more then enough time to do this if he set best glide,
right? If it turns out that he was sucking on an empty tank and that's
the only problem, then this sounds like evidence that he didn't do his
checklist, or is that step not standard in Bonanza's?
Again, I'm just a student pilot, so if I'm wrong, lemme know.
A Killer Bonanza Orval Fairbairn General Aviation 20 January 28th 04 10:07 PM
A36 Bonanza turbo prop Jeff Owning 46 January 7th 04 02:37 PM
Bonanza Alternator Light Peter Shurman Owning 0 July 27th 03 07:42 PM
Early Bonanza or Apache? Brinks Owning 11 July 16th 03 06:01 PM
Bonanza Seat Mod Ron Natalie Piloting 3 July 10th 03 01:57 PM
