Must the PLANE be IFR-equipped to fly over17,500?
Old August 26th 04, 01:14 PM
Ron Natalie
"Bryan Martin" wrote in message news:BD52976F.35D22%
I still haven't found the rule that requires either the pilot or the plane
to be IFR certified in order to file an IFR flight plan. I just know that
both are required in order to fly in actual instrument conditions.
The rule is that you must be IFR rated to operate IFR. This means on an
IFR clearance (when in controlled airspace, or without one in uncontrolled
airspace). It has nothing to do with whether you are in instrument conditions
or not (actual or simulated).
Old August 27th 04, 02:29 AM
Juan Jimenez
john smith wrote in news:hPMWc.34135$cT6.21347
@fe2.columbus.rr.com:
John Ross wrote:
As I understand it, in order to fly (legally) above 17,500 feet, the
pilot must be instrument-rated and file an IFR flight plan.
In sunny, cloudless conditions can you file an IFR flight plan and go
over 17,500 if your plane (like my Pitts 12) is not equipped to fly at
night or in bad weather, i.e. no lights or gyros?
IIRC, flight above FL180 also requires dual transponders.
Only in airspace controlled by a country that requires such. One of the
trivia questions I ask pilot friends once in a while is what two points in
the US can you fly to over FL180 without having to file an instrument
flight plan or even have an instrument rating. One of the possible answers
is Miami to San Juan, Puerto Rico, because class A stops 12 miles off the
shoreline. Once you pass that you can fly as high as you want over
international waters.
Juan
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 October 1st 04 07:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 April 1st 04 08:27 AM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 March 1st 04 07:27 AM
A Good Story Badwater Bill Home Built 15 September 3rd 03 03:00 PM
rec.aviation.aerobatics FAQ Dr. Guenther Eichhorn Aerobatics 0 September 1st 03 07:27 AM
