Recoil starters on small 2-stroke engines
Old February 24th 05, 09:17 PM
Mark Smith wrote:
Mark Smith wrote:
Hand proping is also done but as a last resort when the battery
is
dead.
They do start easily when hand propped, but it takes a healthy
pull
on a
blade, then staying out of the way.
Some pushers with tails make getting away from the prop a
physical
excercise too.
Thanks, and thnaks to the rest who responded as well.
Supposedly with the adoption of the Light Sport Aircraft regs the
FAA
will soon begin stricter enforcement of the FAR 103 weight limits.
where are they going to get the hundreds of new inspectors to do this
effort,
'Fat' ultralights will have to get an airworthiness certificate
as Experimental Light Sport Aircraft, or be converted to lawn
ornaments.
actually, homebuilt is still available for us, no lawn ornaments.
that
statement was made by an FnAA employee who got canned from the sprot
pile it program, she is no longer around,
I heard it from an EAA guy who recently gave us a very informative
talk on the new LSA regs. He said that 'lawn ornament' was becoming
popular jargon at the FAA.
Don't non-FAR 103 compliant homebuilts require an airworthiness
certificate? (That is what I wrote.) Won't homebuilts now be
Experimental Light Sport Aircraft?, Is that the part I got wrong?
What if the 'homebuilt' was a factory built 'Fat' ultralight?
So I was thinking about how to get as large an engine
as possible, like maybe a Zenoah G-50 on something like a Sadler
Vampire while keeping it under 254 lbs.
A 'sneaky' way to get a few more lbs might be to install the
lightest BRS possible and then take the maximum weight allowance
for a BRS.
... getting the smallest one may be false safety as it may be too
small for the gross, depending on the pile it weight
E.g. lightest possible should be read lightest that is adequate for
gross weight. Was your spell checker that substituted 'pile it'
for a typoed 'pilot'? Actually a propos considering the context....
FF
Old February 24th 05, 09:32 PM
Morgans
"Mark Smith" wrote
Hand proping is also done but as a last resort when the battery is dead.
They do start easily when hand propped, but it takes a healthy pull on a
Does the fact that the two strokes have a gearbox, make the hand propping
harder? My guess is yes.
Old February 24th 05, 10:36 PM
Mark Smith
Mark Smith wrote:
is
dead.
pull
on a
physical
excercise too.
FAA
effort,
ornaments.
that
most don't know much about the regs as much of the so called regs
haven't been written/approved, and are being changed as special interest
groups complain,
this whole rule was written by those who don't fly much about planes
they don't fly at all,,,,,,,
for a BRS.
FF
typin in the dark with two fingers makes appropriate typos come and go,
if i like one, it stays,
experimental homebuilt is separate from sprot pile it, the full typo
just for you
any ultralight may be disassembled, rebuilt, and N numbered as a
homebuilt,
that is what should have happened to stay legal for the past twenty
years or more,
with sprot, several new classifications are available, but all require
special inspectors, many hours of schooling to inspect your own plane,
many many more to actually work on it
none of this required with ex homebuilt,
Mark Smith
Tri-State Kite Sales
http://www.trikite.com
1121 N Locust St
Mt Vernon, IN 47620
Old February 24th 05, 10:38 PM
Mark Smith
actually, since the engines are much smaller than the typical GA tractor
motor, and the gearbox gives you a speeup in the process, I feel they
are as easy plus or minus a bit either way,
if things are right, prime, throttle opening, general condition, first
pull starts are more the norm than not,
same goes for hand propping
Mark Smith
Tri-State Kite Sales http://www.trikite.com
1121 N Locust St
Mt Vernon, IN 47620
Old February 25th 05, 12:00 AM
homebuilt,
years or more,
That was my thinking too. But supposedly after a couple of years the
FAA will not allow 'Fat' ultralights to be re-certified. Two
obvious questions being how would the FAA know what the homebuilder
started with when he started (re) building it. How would, (and
why would) the FAA distinguish between a rebuilt 'Fat" UL and
a scratch-built knock off of a 'Fat' UL? Voluntary compliance
I would suppose.
FF
Old February 25th 05, 12:15 AM
Mark Smith
homebuilt,
years or more,
I would suppose.
FF
what they would like,, as a punishment for past violations of 103 that
went unpunished,,,,,,,
maybe is that we all lose a lot of money when the 'time is up' for
registering under the severly flawed sprot pile it plane rules,,,,,,,
but I like you, feel that there is NO WAY to stop anyone from
constructing a plane using any parts from where ever, fat ul or the
kitchen door, and calling it a plane, asking for and getting an N
number,
If stephenson can get a business going using the stupid rules he helped
write more power to him,
bigtime Pols and their near criminal partners do it every day using
government funds, etc
I could just as easily start a business where I buy and sell the 'lawn
ornaments' and sell them back for the purchase price and a buck, they
then have a clear title to the newly purchased kit, with the papertrail
totally OK for the homebuilt rule paperwork,,,,,,,,,
Pols write laws and leave loopholes all the time, then squeak inbetween
them charging you and I lots of money to get out of a jam,
no reason we can't do the same,,,,,,,,,,,,,,,,,
Mark Smith
1121 N Locust St
Mt Vernon, IN 47620
1-812-838-6351
Old February 26th 05, 01:35 PM
Mark Smith
Darrel Toepfer wrote:
Mark Smith wrote:
You might be thinking of the E box with the roller clutch and electric
starter built in
Must be, thanks... When I was flying this, the owner mentioned against
ever handpropping it:
http://bbs.whodat.net/n6663k/engine.jpg
That pic s of the C box, not the E
so the starter is on the front end of the engine, not visible in the
picture,
I hand proped this exact combo many times,,,,,,,,,,,,,some for showing
how to do it, a couple because the battery was dead.
Mark Smith
1121 N Locust St
Mt Vernon, IN 47620
1-812-838-6351
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 1st 04 02:31 PM
BSFC vs gas mileage, 2 stroke vs 4 stroke Jay Home Built 10 August 24th 04 02:26 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 1 January 2nd 04 09:02 PM
