HPh304s (Fes) owners
Old August 3rd 19, 04:48 PM posted to rec.aviation.soaring
Dan Daly[_2_]
Default HPh304s (Fes) owners
On Saturday, August 3, 2019 at 9:24:56 AM UTC-4, Gary Wayland wrote:
On Saturday, August 3, 2019 at 9:11:21 AM UTC-4, wrote:
Cockpit comfort is key as much as safe handling. Hph304cz is no longer in production I think.
S
Does the Shark have trailing dive brakes?
No. You can see spoilers/dive brakes and flaps on the 3-view on the manufacturer's website. http://www.hph.cz/products/hph-304s-shark/
Old August 3rd 19, 04:57 PM posted to rec.aviation.soaring
Gary Wayland
S
Oh yes, I see. I looked at their new L/D for the shark as opposed to the comparison with the 304CZ. I'm like, how could they thin that airfoil with all the mechanism that it took to put trailing dive brakes in the wing and still get the higher L/D ratios... Well, now I can see!
It's too bad they can't use them. Love those trailing dive brakes...
Thanks...
Old August 4th 19, 06:41 PM posted to rec.aviation.soaring
Paul Ruskin[_2_]
At 10:04 03 August 2019, wrote:
Yes.
HPH304 Shark.
S
OK. I have 500 hrs in a Shark SJ. Very nice to fly. Well built,
well thought through. The cockpit is a good size (I'm 6 ft 2, 90kg
and long in the back). I find it very comfortable - I can do 6 hr +
flights without any problem (which I don't find in some other
gliders). Lots of electrical power, so it can support a full suite of
avionics for that time and longer.
It's a little heavier empty than say a 29, and you really need a
rigging aid to rig, but it's straightforward if you have that. I fly at
about 500kg dry, so I can add about 100kg water if I want to. It
handles that well, and becomes a bit more stable.
On mine I get a little airflow around my feet, so use overshoes
when it's cold outside. But that might be specific to my airframe.
I like the jet - it's a good choice of powerplant. I get about 130km
range in still air - which is about twice the actual range of the FES I
think (all the FESs, not just the Shark). But the FES seems to work
reasonably, at least to give you more choice as to where you land
(we have two FES Sharks and a Discus at our club).
It doesn't quite have the performance of a 29 or a JS-1, but then
it's not as expensive. If you're in gliding to win competitions you
might want to spend more, but if like most people, you're in it for
fun, then it might suit you.
The flaps are straightforward - landing flap is nothing like as
aggressive as say an early 20 (which I had prior to the Shark), and
the airbrakes are good.
I've found the support in the UK superb, but can't comment on
what the support would be like in the US - it's very dependent on
the agent, I think.
Paul
Old August 5th 19, 01:51 PM posted to rec.aviation.soaring
Thanks! That is helpful.
What is the deployment time of Jet vs Fes?
S
Old August 5th 19, 08:31 PM posted to rec.aviation.soaring
David Bingham
Slawec,
I am a Shark FES owner.
It is a roomy comfortable cockpit.controls are nicely balanced and
a pleasure to fly.
As a non competitive pilot I find the performance matches every
expectation I had.
It is not difficult to fly.
The flaps are straightforward. I tend to use +2 flap for landing.
Landing flap is benign but beware the additional drag.
The fes is instant.
Don’t expect it to use is it as a motor glider to get from A to B.
But it will give you the ability to fly to the next thermal/landing
strip or simply give you a wider selection of fields to land in.
Perfect for ridge flying and low deployment.
A great glider.
Manufacturer back up? .........not so great but it shouldn’t be an
issue and I wouldn’t let that be a deterrent.
I have no purchase regrets.
At 17:46 02 August 2019, wrote:
Hi,
Any HPH304s owners (with Fes would be excellent) out there
willing to share
their experience with that bird?
Not much interested in performance , more comfort, easy of
handling and
suitability for low time pilot.
Post sales service etc.
I will much appreciate it.
Yours,
Slawek
Old August 5th 19, 08:32 PM posted to rec.aviation.soaring
David Bingham
Slawec,
a pleasure to fly.
expectation I had.
The fes is instant.
A great glider.
Hi,
willing to share
handling and
Yours,
Slawek
Old August 5th 19, 09:53 PM posted to rec.aviation.soaring
Looks like cockpit space will be deciding factor. I fit in Diana3. Will test fly both.
What did you mean by lacking manufacturer support?
Slawek
Old August 5th 19, 10:46 PM posted to rec.aviation.soaring
On Friday, August 2, 2019 at 1:46:49 PM UTC-4, wrote:
Hi,
Any HPH304s owners (with Fes would be excellent) out there willing to share their experience with that bird?
Not much interested in performance , more comfort, easy of handling and suitability for low time pilot.
Yours,
Slawek
I am the owner of a Shark MS. I have read with interest Davis Binghams thoughts and comments. I agree with almost everything mentioned. The one big thing I disagree with is factory support.
I have owned 20 + gliders over the years from different manufacturers. All have been a pleasure to deal with but none have measured up with the support I have received from HPH. Every question I have asked has been answered. I have sent e mails on Saturdays which have been answered the same day.
I have received follow up e mails from the factory making sure all is well. The factory has been as interested in my opinion and thoughts of the shark as I am of theirs. A rare experience!
Another feature I have appreciated is construction. I measured the contour of my wings when purchased 3 years ago and they have changed very little. An important issue for a competition pilot.
All in all I have enjoyed the HPH experience. Sam Giltner 5U
Old August 6th 19, 12:39 PM posted to rec.aviation.soaring
Alberto Recchi
I am the owner of a Shark MS and can confirm the factory support is excellent. You can email the CEO Jaroslav or Dasa or Martin directly and they’ll always answer immediately. I am 6.4 and weight 240lbs. With the weight of the engine the glider is very very fast. It flys superbly. Manufacturing quality is top notch. It’s certainly one of the best 18m out there in terms of quality/price ratio you can get.
USA owners of JS-1s without Jet [email protected] Soaring 0 July 3rd 17 01:48 PM
Beech Duke Owners/ex-Owners ple help... Stanley Owning 12 June 10th 16 12:36 AM
looking for LAK-17 owners Brad[_2_] Soaring 1 June 16th 10 11:40 AM
DG-300/303 owners... Alan Montague Soaring 48 April 22nd 07 01:58 AM
Any UH-1 owners in here? Jim Rotorcraft 7 October 6th 03 02:33 AM
