Instrument tubing
Old August 8th 19, 10:34 AM posted to rec.aviation.soaring
Surge
Default Instrument tubing
On Wednesday, 7 August 2019 18:27:34 UTC+2, Tango Whisky wrote:
Exactly. Tubing should be silicone. No additional devices needed.
I can't agree more. Silicone tubing will practically last the rest of your lifetime, it never leaks and it reseals when removed and reconnected.
I used "food grade", thick walled, silicone tubing sourced from China due to the low price (around $50 for 12 meters) and free shipping. Red for pitot, blue for static, black for T/E.
PVC tubing is for fish tanks.
Old August 8th 19, 07:33 PM posted to rec.aviation.soaring
Behind the panel soft silicone tubing needs a lot more care on installation to ensure that it is fully supported otherwise it moves around in turbulence and when pulling G and that can cause pressure change to the vario. PVC tubing also needs care in that respect but less so. I never use silicone tubing or donuts or tie wire and have never had a leak at the instrument. I take care to make sure that T pieces etc are free of flashing - metal ones are better. The only downside of good PVC tubing is that a 90 degree bend that looks OK on installation can go flat over the years and cause a blockage so I always use 90 degree corner joining pieces instead.
Old August 8th 19, 07:40 PM posted to rec.aviation.soaring
Couple of things;
- I used to be a proponent of the small castration rings but feel they actually cause leaks instead of preventing them. YMMV. Plus they fairly quickly deteriorate by design.
- I like the "Wings and Wheels" tubing color coding scheme. Helps to prevents errors and makes seeing which tube goes to what much easier.
- All this info and more is in this presentation.
http://aviation.derosaweb.net/presentations/#airlines
Enjoy!
Old August 9th 19, 06:24 PM posted to rec.aviation.soaring
Wit Wisniewski
I use spring steel hose clamps like these:
https://www.dhgate.com/product/motor...404217759.html
They come in many sizes, and each size will work with a variety of tubing sizes. They're cheap, and reusable. A downside is that pliers are required to install and remove them.
For tubing short runs, I haven't found it making much of a difference between material types. Silicone, Tygon, and cheap imitations all work. On longer runs the tubing affects instrument dynamics. The more tubing is elastic, or the longer it is, the more it will delay and slow down the responses.
Size is a little more difficult to chose. If the probe orifice is large, a bigger diameter tube will transmit changes faster. If the orifice is small, the capacity/volume of the tube will form a filter against the source resulting in delayed and slowed indications of change indicating use of a narrower tube.
-Wit, HZ
Old August 9th 19, 09:48 PM posted to rec.aviation.soaring
krasw
Anything put over pvc or silicone tube just creates leaks.
Old August 11th 19, 05:46 PM posted to rec.aviation.soaring
Robert Seccombe SE3
That's what I used.
https://drive.google.com/file/d/1Kg5...w?usp=drivesdk
Source of green donuts for instrument tubing installation? Movses Babayan Soaring 14 April 10th 18 09:45 PM
Relesable instrument tubing [email protected] Soaring 6 February 13th 07 05:38 AM
source for clear+red instrument tubing John W Soaring 8 November 1st 04 01:19 PM
Tubing strength Ernest Christley Home Built 0 January 16th 04 11:43 PM
