LS6 canopy gas spring
Old August 8th 20, 05:24 PM posted to rec.aviation.soaring
Sarah[_2_]
Default LS6 canopy gas spring
On Thursday, August 6, 2020 at 8:52:51 PM UTC-5, wrote:
Resurrecting this old thread, as the canopy strut on my LS7 just wen caput. Pretty sure it uses the same strut as the LS6. Richard (or other LS6 owners), could you let me know what replacement strut you found?
Jordan
I replaced my LS gas spring, but the source was the ex-LS dealer in Canada. If your local dealer can't help...
From the groups.io "LSgliders" forum:
https://groups.io/g/LSgliders/message/19
In case that link doesn't work, the key info was
Herst-Dat is german for "Herstellungsdatum" = date of manufacture. August 1987 in this case.... truly time to change.
When you Google for
"gasdruckfeder 850n 7256516"
(gasdruckfeder = gas strut) you have a few hits, e.g.
https://www.agrarexpress.de/gasfeder...ung-850n-360mm
Old August 9th 20, 01:28 AM posted to rec.aviation.soaring
Brian[_1_]
Try a 12.8 “ Strong Arm 4540 Lift support ~850N. Will likely have M6 ends and need a M6 to M8 adaptor and use the fittings from your old strut..
https://www.liftsupportsdepot.com/st...-lift-support/
https://www.google.com/url?sa=t&rct=...Zsj uxuRS67zc
Old August 9th 20, 04:56 PM posted to rec.aviation.soaring
Gianni Isotope
Thank you for the suggestion Brian. Unfortunately, on my worn-out strut, while one eyelet/bearing end is threaded onto the shaft, the other, attached to the cylinder, doesn't seem to be removable.
Jordan
Old August 10th 20, 01:34 AM posted to rec.aviation.soaring
Brian[_1_]
As I recall you are correct. I was able to find a 2nd end from another strut that had been retired.
Might be able find a suitable end online.
Brian
Old August 10th 20, 02:04 AM posted to rec.aviation.soaring
Brian[_1_]
You might also look at the struts on the front access door of the a cobra trailer. I seem to recall they used the same end fitting or possibly one I thought I could make work.
Canopy Ejection and Canopy Lanyard Casey[_2_] Soaring 6 April 12th 16 05:09 PM
Canopy gas spring for DG600 [email protected] Soaring 5 March 7th 13 12:46 AM
Canopy gas spring LS4, USA [email protected] Soaring 3 October 30th 12 12:01 PM
TOST Tow Spring Pad for Cub [email protected] Soaring 0 January 21st 08 04:08 AM
Ten tips for ASW20 canopy gas spring replacement. [email protected] Soaring 0 April 10th 07 05:15 PM
