Fuses versus Breakers
Old March 11th 05, 09:24 AM
Bert Willing
There are components which are not fused internally (i.e. T/S indicators,
Colibri etc).
Bimetal breakers are disastreous in this case as they are very slow and will
ultimately less pass about 10 times the nominal value before cutting off.
This winter I was loocking into replacing my fuses by breakers, and I
decided that I didn't want to have this crap in my gliders. The breakers to
use are magnetic ones which are pretty fast - but the price tag is very
different... so finally I kept going with fuses.
Bert Willing
ASW20 "TW"
"Don Hammer" a écrit dans le message de news:
The question is, what is the typical forward drop of a fuse? Also, why
does the breaker have such a high forward drop at low amperages?
Thanks, John
Don't know about what is typical, but look at it this way. A breaker
trips because there is a bimetalic resistor that heats up when current
flows through it. If you have resistance you get heat and a voltage
drop. Stick in Ohm's law and you can probably get an answer to your
question.
BTW - Breakers and fuses are there for one thing only. They keep a
shorted wire from turning into a foam cutter. Components are usually
protected by an internal fusable device. Always size the breaker for
the wire.
Old March 11th 05, 12:47 PM
John Giddy
Colibri etc).
Fuses for individual instruments don't protect those instruments, but
do stop the larger battery fuse from blowing if the instrument fails
in a way which draws a high current from the battery.
This only works if the individual instrument fuses have a current
rating smaller than the common battery fuse.
If the common battery fuse blows, you lose ALL the instruments. If a
single instrument fuse blows, you lose that instrument, but you were
going to lose it anyway, as it is the failure of the instrument which
blows that fuse.
Cheers, John G.
Old March 11th 05, 02:57 PM
Bert Willing
Yes and no. Of course one needs a big fuse (mine is 7 Amps) on the battery
to protect the cable running to the instrument panel.
Individual fuses on simple instruments like a T/S do protect the main fuse
to blow off. On more sophisticated intrumentation like a radio or a flight
computer, the protect the instrument in the case you connect the battery
with the instrument switched on. That usually produces a spike which some of
the instruments (the LX160s is a good example) absolutely don't like.
Fuses which protect an instrument need to be fast fuses, fuses protecting
the main fuse or cables are slow fuses.
Bert Willing
ASW20 "TW"
"John Giddy" a écrit dans le message de news:
Colibri etc).
will
to
blows that fuse.
Cheers, John G.
Old March 11th 05, 11:12 PM
John Giddy
You would need very fast fuse to stop the spike you describe. Maybe a
surge supressor on the line near the sensitive instruments would do a
better job ? e.g. a 5W or so zener diode with a breakdown voltage of
14v. (or 16v if you are one of those who advocate 14v batteries) This
will also blow the battery fuse if you connect the battery in reverse
polarity by mistake, and prevent large negative voltages being applied
to insufficiently protected instruments.
It also saves you having to carry a supply of instrument fuses so you
can replace the fuse of the instrument which was ON when you connected
the battery.
Cheers, John G.
"zero" versus "oscar" versus "sierra" Ron Garret Piloting 30 December 20th 04 09:49 AM
Buying a plane versus renting RD Owning 35 March 5th 04 10:42 PM
leaving alternator breakers on all the time Frank Ch. Eigler Owning 9 October 24th 03 07:14 AM
Aircraft circuit breakers Bill Staley Soaring 5 October 6th 03 04:06 AM
Cessna 340 Tie down versus Hangar endre Owning 11 July 17th 03 02:49 AM
