On Wednesday, October 23, 2019 at 10:14:03 AM UTC-5, Joel Flamenbaum wrote:
Beautiful - fuel consumption and where is the fuel stored? Duration at full throttle? Also, drag or loss in performance with turbo extended? Awesome combination A 10 gallon fuel cell is built into the fuselage behind all of the control systems. I have a slightly aft CG during takeoff and as I burn fuel my CG moves forward. Duration with full fuel would be 20 minutes at full power. If I get a tow and only run one turbine I can double the endurance. The extended turbines have a pretty small drag signature. I am guessing it is similar to leaving the gear down. The air noise is more noticeable then the drag during the extended cooling cycle. Chris |
Hi Chris,
Interesting modifications, congratulations to your achievement! Are the gelcoat-discolorations on the tail caused by the heat of the exhaust, or is this a result of fuel contamination? I remember that in some turbine powered gliders, the engines are slightly angled against the fuselage centerline in order to keep the heat away from the tail. If I am not mistaken, this was the case with the LS4 jet retrofit offered by M&D (https://md-flugzeugbau.de/en/areas-o...rieb-mdtj-42/). Christoph |
On Wednesday, October 23, 2019 at 12:38:32 PM UTC-5, wrote:
Hi Chris, Interesting modifications, congratulations to your achievement! Are the gelcoat-discolorations on the tail caused by the heat of the exhaust, or is this a result of fuel contamination? I remember that in some turbine powered gliders, the engines are slightly angled against the fuselage centerline in order to keep the heat away from the tail. If I am not mistaken, this was the case with the LS4 jet retrofit offered by M&D (https://md-flugzeugbau..de/en/areas-...rieb-mdtj-42/). Christoph The discoloration is a build up from a number of takeoffs and heat is not a problem. The diesel fuel is mixed with turbine oil for bearing lubrication which soils the tail. A wax/grease remover is needed for removal. |
On Tuesday, October 22, 2019 at 4:58:19 PM UTC-5, wrote:
For the last month I have been flight testing the rebuilt ASW 27. The program is going well and I am nearing completion of the required phase 1 testing. I still have max gross weight, final spin testing and a tow test for completion. So far I have only been able to self-launch since no towing is available this late in the season. The twin turbines are working well and provide a solid 600 fpm climb rate at these cooler fall temperatures. The steerable tailwheel is also working well and provided good directional control during takeoff and landing. Here is a link to a compilation of short clips from the flight test program. https://www.youtube.com/watch?v=S_rFhN_abrQ Chris https://www.youtube.com/watch?v=S_rFhN_abrQ |
At 13:46 24 October 2019, wrote:
On Tuesday, October 22, 2019 at 4:58:19 PM UTC-5, wrote: For the last month I have been flight testing the rebuilt ASW 27. The pro= gram is going well and I am nearing completion of the required phase 1 test= ing. I still have max gross weight, final spin testing and a tow test for c= ompletion. So far I have only been able to self-launch since no towing is a= vailable this late in the season. The twin turbines are working well and pr= ovide a solid 600 fpm climb rate at these cooler fall temperatures. The ste= erable tailwheel is also working well and provided good directional control= during takeoff and landing.=20 =20 Here is a link to a compilation of short clips from the flight test progr= am.=20 =20 https://www.youtube.com/watch?v=3DS_rFhN_abrQ =20 Chris https://www.youtube.com/watch?v=3DS_rFhN_abrQ Says "video unavailable". |
At 14:36 24 October 2019, Never Again 2 wrote:
At 13:46 24 October 2019, wrote: On Tuesday, October 22, 2019 at 4:58:19 PM UTC-5, wrote: For the last month I have been flight testing the rebuilt ASW 27. The pro= gram is going well and I am nearing completion of the required phase 1 test= ing. I still have max gross weight, final spin testing and a tow test for c= ompletion. So far I have only been able to self-launch since no towing is a= vailable this late in the season. The twin turbines are working well and pr= ovide a solid 600 fpm climb rate at these cooler fall temperatures. The ste= erable tailwheel is also working well and provided good directional control= during takeoff and landing.=20 =20 Here is a link to a compilation of short clips from the flight test progr= am.=20 =20 https://www.youtube.com/watch?v=3DS_rFhN_abrQ =20 Chris https://www.youtube.com/watch?v=3DS_rFhN_abrQ Says "video unavailable". gliderpilot.net mangles urls. Take out the "3D", should be "v=S_rFhN_abrQ". |
"v=S_rFhN_abrQ". That worked, thank you. |
Chris, maybe a link to your youtube channel instead?
Nice video. Welcome to the jet club. BTW, your canopy needs cleaning. Also, Bob Carlton and I have found that Windex easily removes the residue from jet exhaust on the tail. Use REAL Windex. Some of the off-brand blue glass cleaners won't do it.
| Thread Tools | |
| Display Modes | |
| URL to a video clip. Many have never seen this before | Jess Lurkin[_8_] | Aviation Photos | 0 | May 5th 15 04:34 AM |
| Video clip from the Sunship Game | Guy Byars[_2_] | Soaring | 24 | August 21st 09 07:23 PM |
| mishap video clip's | larry | Naval Aviation | 0 | September 15th 05 10:28 AM |
| Does anybody know a link to a real picture of the X-43 in flight sans Pegasus or better yet a video clip of the flight? | Scott Ferrin | Military Aviation | 0 | April 3rd 04 09:47 PM |
| The insane spitfire video clip | gatt | General Aviation | 30 | November 4th 03 07:43 PM |
