Regarding performance only, is there any study indicating that top of the fuselage location is worth than the normal under fuselage location?
Dan |
"You are bathing all the other avionics with high-energy RF pulses from the transponder... A L2 type wave antenna for mounted inside a non-conductive fuselage should normally be mounted back in the fuselage away from the pilot and avionics. And things like PowerFLARM 1090ES In are designed to work by seeing somewhat reduced power leakage of your transponder signal, not being blasted by the direct high-energy signal."
The avionics, except for the Oudie, are all in metal enclosures. "You may be operating the FLARM antennas closer to a transponder antenna than a good idea (~30cm minimum recommended by FLARM... but that's when both externally mounted, this may be worse mounted inside). I'm not even sure something as close as 30cm is a good idea externally. Does ownship PowerFLARM transponder identification work OK? Or do you have to disable PCAS etc.? FLARM range checks all look good?" The PF Flarm and ADS-B antennas are mounted on the sides of the canopy quite some distance from the xpdr antenna which itself is about a foot forward of the instrument panel. The PF range is better than the four other gliders I've checked. No PF problem with own glider xpdr. "How do you know if the Transponder is working OK until you check/ask?. You also might be flying in a remote enough area that you get few transponder interrogations, so things seem to work OK. A close encounter with a TCAS equipped aircraft might result in a chirp of ~1kHz transponder interrogations.. Even if things are are working OK now who knows what that will do to your electronics, PowerFLARM, traffic display, etc. when you might need to most rely on it." Will be doing another transponder check in the spring. "You likely have lots of conductive objects within the antenna RF near field near field (including the Schleicher panel support brass rod, all the usual wiring and conductive instrument cases). That can significantly affect the radiation pattern in ways unlikely to be obvious." Most of the unshielded wiring is in the bottom of the instrument enclosure directly below the L2 antenna where the radiated energy may be lower. But so far, everything seems to be working. "And you are possibly exposing yourself to excessive RF radiation." My lower legs are about a foot away while the rest of me is 2 to 4 feet away. I found a research paper that showed the radiation hazard was low. |
On Saturday, December 28, 2019 at 8:55:37 AM UTC-8, jfitch wrote:
On Saturday, December 28, 2019 at 12:26:15 AM UTC-8, Tango Whisky wrote: My transponder hs 250 W output, no way I would want that any place near my head or my balls. The normal location (recommended by many manufacturers) just ahead of the gear doors is much closer to your balls than an L2 in the nosecone (or the instrument pod), if that worries you. Probably less than 2' away. I always wear tin foil underwear to match my tin foil hat. But my transponder antenna is in the nosecone and works perfectly as tested by external radiated power and FCC ADS-B out reports. But you don't wear tin-foil socks, do your toenails grow faster during soaring season? Would like to get a bit more information on the tin-foil hat, I think I need one. I have my transponder antenna in the fin works great, no need for time foil panties. |
On Friday, December 27, 2019 at 5:22:04 PM UTC-8, wrote:
I put mine on a turtle deck on my ASW 27 and it works fine no issues with anyone seeing me or even worrying about it I really like the fact that it's there and was really easy to install compared to down by the gear Long ago someone (I believe from Arizona) posted here about doing some research by talking to folks very familiar with FAA radar design about putting the transponder antenna on top of the fuselage. The conclusion was that if very near and above the radar site, the signal *might* be blocked. Other than that, it should be fine. Since we do a lot of turning, the antennal will be blocked for times anyway. One reason for a transponder is to be seen by large aircraft TCAS, it's more likely they will be descending on a collision course, so having the antenna on top is a better idea.... 5Z |
The Jonker website says that they are putting both the transponder antenna and the Flarm antenna in the vertical tail. Any reports on how that is working out?
On Sunday, December 29, 2019 at 12:26:19 PM UTC-8, wrote:
The Jonker website says that they are putting both the transponder antenna and the Flarm antenna in the vertical tail. Any reports on how that is working out? See above, I mentioned how that is working out. |
5Z wrote on 12/29/2019 10:11 AM:
On Friday, December 27, 2019 at 5:22:04 PM UTC-8, wrote: I put mine on a turtle deck on my ASW 27 and it works fine no issues with anyone seeing me or even worrying about it I really like the fact that it's there and was really easy to install compared to down by the gear Long ago someone (I believe from Arizona) posted here about doing some research by talking to folks very familiar with FAA radar design about putting the transponder antenna on top of the fuselage. The conclusion was that if very near and above the radar site, the signal *might* be blocked. Other than that, it should be fine. Since we do a lot of turning, the antennal will be blocked for times anyway. One reason for a transponder is to be seen by large aircraft TCAS, it's more likely they will be descending on a collision course, so having the antenna on top is a better idea.... Near airports, airliners are descending and ascending; in between they are above 18K. In our area, the C-17s cruise high and low; the low ones (2000' agl) are never a problem, but the other ones do cross our normal altitudes at least twice each flight. I'm skeptical that they are mostly descending, but I think their TCAS can easily detect us when they get within a few miles, regardless of the top/bottom location. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 |
On Sunday, December 29, 2019 at 10:11:09 AM UTC-8, 5Z wrote:
On Friday, December 27, 2019 at 5:22:04 PM UTC-8, wrote: I put mine on a turtle deck on my ASW 27 and it works fine no issues with anyone seeing me or even worrying about it I really like the fact that it's there and was really easy to install compared to down by the gear Long ago someone (I believe from Arizona) posted here about doing some research by talking to folks very familiar with FAA radar design about putting the transponder antenna on top of the fuselage. The conclusion was that if very near and above the radar site, the signal *might* be blocked. Other than that, it should be fine. Since we do a lot of turning, the antennal will be blocked for times anyway. Unfortunately "it's more complex" applies to lots of stuff with aircraft surveillance.Â*And I would hope any research folks did thought about some of the things I'll describe here. My concern with upper surface antennas is more blanketing from the wing, and that includes to distant SSR sites. The fuselage directly blocking the antenna like when near/overhead an SSR is not the main concern I have because already the SSR likely can't see you.Â*(OK sure if the long length of the fuselage points directly at the antenna you might have an issue). If you are very near, i.e. ~overhead a radar site you may well be in the "cone of silence" of both the primary radar and SSR and likely not seen regardless of transponder antenna location or orientation. SSR and primary radar have a fairly wide cone of silence/shallow viewing angle above the horizon.. Think things like an SSR sees things only below ~30 degrees above the horizontal around the antenna. Transponder antennas also have a cone of silence pointing out the end of their antenna. Hopefully a bit narrower than the SSR cone. An antenna mounted on an upper fuselage area on a glider might be helped by diffraction around the glider fuselage, and that weak diffracted part of the signal may be OK when closer to a SSR (or ADS-B ground site) but still within that say 30 degree angle above the horizon. As the transponder antenna looks out more towards a distant SSR antenna the angle shallows and hopefully seeing a bit better signal due to decreased angle, but you can have significant range loss, especially say if relying on a distant (up to ~200NM!) en-route SSR to fill in details). But it's complex and would need modeling to see what happens. Ah the irony is that very local overhead performance to an SSR antenna may depends on other (possibly quite distant) SSR sites.... SSR cones of silence get somewhat addressed by integrating together data from overlapping radar systems.Â*That is what the FAA Fusion system does, and it also folds in ADS-B data. (And ADS-B ground stations themselves have similar cone of silence issues, and a similar solution of adjacent ground towers partially covering each other).Â* Any analysis you would want to look at upper and lower antenna performance to local SSR interrogators at around that 30 degree angle, and at more distant SSR sites that are filling in the data for the cone of silence at shallower angle. And my concerns again are more things like wings obscuring line of site, and wanting to make sure that any ground plane and antenna installation is as good as posible to maximize signal quality to/from more distant SSR sites regardless of wether the antenna is top or bottom mounted. And I sure appreciate Dan posting a followup link to that picture of the antenna stuck out the side of a fuselage. I had never seen that before, much worse than I had imagined, and I sure did not want to seem to be recommending it.. blanketed directly above by the wing, blanketed to the side by the fuselage and side/below by the gear when extended, and ~90 degree crossed signal polarization when the glider is banking left.Â* One reason for a transponder is to be seen by large aircraft TCAS, it's more likely they will be descending on a collision course, so having the antenna on top is a better idea.... 5Z Like Eric I don't understand why TCAS threats are assumed to come from above. I would suspect an equal distribution, and threats are going to be approaching near the same altitude with a relatively shallow climb or descent angle. In a bad case TCAS IIÂ* is going to command an RA which could put you relatively close laterally but above or below the threat aircraft... and I would assume those RA directions are equally distributed as well. And you've already executed the RA command before the angle above/below the threat gets very steep. I think there are studies/modeling of aircraft showing TCAS performance with single antennas if I can find them I'll point them out (but the system exists as it does with all light aircraft largely having single lower antennas). With it being hard to guess/know how well things are really working one thing I have thought would be neat is a transponder antenna performance test tool similar to FLARM range tool or OGN/KTrax used ground and/or airborne 1090 MHz/ADS-B receivers. (Mark Hawkins are you looking for a project? :-)) |
Well, Here is a picture of Schlicher's recommended location for the Antenna-same as Schempp Hirth-Above landing gear doors.
Interesting. https://www.alexander-schleicher.de/...reinbau-27.pdf Dan |
"Pay attention to the proper ground plane installation with any of the standard external transponder 1/4 wave antenna. That is very important."
Can the ground Plane be inside a carbon fibre fuselage for an external blade type antenna ? Dan |
| Thread Tools | |
| Display Modes | |
| PowerFlarm Antenna Locations on Carbon Fuselage | Dan Marotta | Soaring | 9 | August 15th 19 09:38 PM |
| ASW27 Trasponder Antenna Installation Inside Fuselage. | Paul Birkett | Soaring | 45 | January 8th 18 04:31 AM |
| ASW-24 - Transponder Cable Routing in Fuselage | [email protected] | Soaring | 6 | February 3rd 15 06:00 PM |
| Transponder Antenna Placement Fuselage Bottom - Minimize Damage?Exact Location | WaltWX[_2_] | Soaring | 9 | January 20th 15 12:00 AM |
| Transponder and antenna | Paolo | Soaring | 1 | March 6th 04 04:32 AM |
