On Thursday, January 30, 2020 at 10:38:59 AM UTC-5, wrote:
Colton If your getting your 1-26 ready for xc and this years championships, let me share some of my advise. I flew records and the 1-26 championships last year simply with a 302 and an oudie igc. I didnot bother trying to load tasks into the 302, it simply functioned as a good vario. I used the oudie exclusively for working the task, recording the task, and giving me final glide info. It is very easy to create a task in the oudie and to upload competition turnpoint sets as well as downloading the flight data after your done. You should however be sure to have some aux power going to the oudie. I simply had a cig plug aux 12v receptical mounted below my panel which with a splitter kept the oudie charged and also my cell phone. You can also get the adapter cable which connects the oudie to the 302 which will also supply power to the oudie but it is not required, if you just want to use the oudie stand alone for all your navigation and task info. Dan The 302 5VDC output has a maximum capacity of (iirc, check the manual) 900 mA. If you exceed this, you will overheat your 302 and cause problems, perhaps problems requiring expensive repairs. Almost any device can/will exceed 900 mA when charging, some by quite a lot. I recommend strongly against using 302 as a 5V power source for this reason, it's just too easy to screw it up. T8 |
Roger your advice T8, I would not ask the 302 to run a half or fully depleted oudie. In my system, In this years system I start with my oudie fully charged and the 302 interconnect cable is just keeping the oudie topped up. I have about 30 hours on the new system and no issues whatsoever so far. My oudie igc will run easily for 7 hours on its internal battery, but I like the insurance of having some power going to her for the longer flights.
| Thread Tools | |
| Display Modes | |
| Upgrading a used Homebuilt... | [email protected] | Home Built | 5 | August 25th 06 03:57 AM |
| Upgrading your Strikefinder? | Peter MacPherson | Owning | 2 | September 1st 04 03:32 PM |
| Upgrading your Strikefinder? | Peter MacPherson | Instrument Flight Rules | 0 | August 31st 04 04:45 PM |
| Upgrading your Strikefinder? | Peter MacPherson | Piloting | 0 | August 31st 04 04:45 PM |
| Upgrading System | Anthony Acri | Simulators | 1 | July 17th 03 04:18 AM |
