The Schleicher manuals for my ASH-26E do not specify any grease types. The only mention of grease types is to not use molybdenum disulfide on any bearings with brass parts.
One correction to my original post, I said "scoring" I meant to say "fretting". Also, FYI my knowledgeable person noted that white lithium grease is good long term for the other lube points (control connections). Cheers, Jim J6 On Saturday, 1 February 2020 20:16:16 UTC-6, wrote: What does your maintenance manual recommend? |
Jim Hogue wrote on 2/1/2020 3:42 PM:
So, I have been using white lithium grease for decades for all my glider fittings. This has worked out fine, no problems ever, all my fittings have stayed nice, with no damage of any kind. However, now that I have an 18 meter motorglider and am retired and blessed with time to go soar, my rigging habits have changed. I now typically keep my glider rigged for weeks at a time when flying at soaring safari or contest sites. When based at my home 'drome off season, I have a hangar so I am typically rigged for months at a time off season. A person knowledgeable about such things recently told me that white lithium grease for the main high stress attach points (wing pins and lift pins) is not good, it dries out and/or cannot stand up to or stay in place due to the high stresses on those components, and the result is scoring. This makes sense to me, and I am thinking about changing to a better grease for long-term rigging. He suggested molybdenum disulfide grease. I would like to invite comments on this. Are there other options for grease for long-term rigged gliders? What are the best sources (USA) for such greases? My ASH 26 E came with a small can of what looks like an amber colored wheel bearing grease. I've been using mostly that for 25 years. I'm not sure the exact grease is important. What may be happening to lift pins that wear is "false brinelling". From the full article under 'False Brinelling' in Wikipedia: ------------- The basic cause of false brinelling is that lubricant is pushed out of a loaded region. Without lubricant, wear is increased. It is possible for the resulting wear debris to oxidize and form an abrasive compound which further accelerates wear. In normal operation, bearings remain lubricated. However, if a bearing is stationary but subject to a very small oscillating or vibrating load, lubricant may be pushed out of the loaded area. Since the bearing is rolling only small distances (less than roller spacing), there is no action or movement that replaces the displaced lubricant. ------------- Derigging/Rigging probably reestablishes the lubricant film, regardless of the grease. Perhaps there is a lubricant that prevents the push-out; failing that, periodically pulling each wing panel out about 3 inches, greasing the lift pins, and sliding it back in would also do it. Note the problem can affect wear bearings on cars shipped by rail from the one coast to the other, or bell crank bearings in the wing of a glider that is trailered long distances over many years (that's how I encountered the problem). -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 |
On Saturday, February 1, 2020 at 3:43:01 PM UTC-8, Jim Hogue wrote:
So, I have been using white lithium grease for decades for all my glider fittings. This has worked out fine, no problems ever, all my fittings have stayed nice, with no damage of any kind. However, now that I have an 18 meter motorglider and am retired and blessed with time to go soar, my rigging habits have changed. I now typically keep my glider rigged for weeks at a time when flying at soaring safari or contest sites. When based at my home 'drome off season, I have a hangar so I am typically rigged for months at a time off season. A person knowledgeable about such things recently told me that white lithium grease for the main high stress attach points (wing pins and lift pins) is not good, it dries out and/or cannot stand up to or stay in place due to the high stresses on those components, and the result is scoring. This makes sense to me, and I am thinking about changing to a better grease for long-term rigging. He suggested molybdenum disulfide grease. I would like to invite comments on this. Are there other options for grease for long-term rigged gliders? What are the best sources (USA) for such greases? Thanks in advance, Cheers, Jim J6 Super Lube comes in an EP version, about twice the resistance to extreme pressures than their normal version: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 You could use molyD on the lift and drag pins as they aren't brass, and the main pins never wear (except through ham fisted assembly). But that seems fiddly. I've never seen a glider with more than a few hundred hours that didn't have some fretting on the pins, so it may be inevitable. |
On Saturday, February 1, 2020 at 6:43:01 PM UTC-5, Jim Hogue wrote:
So, I have been using white lithium grease for decades for all my glider fittings. This has worked out fine, no problems ever, all my fittings have stayed nice, with no damage of any kind. However, now that I have an 18 meter motorglider and am retired and blessed with time to go soar, my rigging habits have changed. I now typically keep my glider rigged for weeks at a time when flying at soaring safari or contest sites. When based at my home 'drome off season, I have a hangar so I am typically rigged for months at a time off season. A person knowledgeable about such things recently told me that white lithium grease for the main high stress attach points (wing pins and lift pins) is not good, it dries out and/or cannot stand up to or stay in place due to the high stresses on those components, and the result is scoring. This makes sense to me, and I am thinking about changing to a better grease for long-term rigging. He suggested molybdenum disulfide grease. I would like to invite comments on this. Are there other options for grease for long-term rigged gliders? What are the best sources (USA) for such greases? Thanks in advance, Cheers, Jim J6 Another thought: If you have a one man rigger, which almost all of us do,it isn't that hard to put a wing stand on one side , and the rigger on the other, like you are taking it apart, then pull the pins and slide the wings out enough(maybe 2 inches)to give the pins a fresh smear, and put it back together. You already have the alignment. I'll bet to could be done in less than 15 minutes. Cost is the price of wing root tape. FWIW UH |
I believe our national dealer has recommended Master Pro Multi Purpose
Lithium Grease. If you're looking a a nasty messy gooey black grease suitable for wheel bearings, this one fills the bill perfectly. I've always been happy with the white lithium stuff in a tube myself. -Dave On 2/1/20 4:42 PM, Jim Hogue wrote: So, I have been using white lithium grease for decades for all my glider fittings. This has worked out fine, no problems ever, all my fittings have stayed nice, with no damage of any kind. However, now that I have an 18 meter motorglider and am retired and blessed with time to go soar, my rigging habits have changed. I now typically keep my glider rigged for weeks at a time when flying at soaring safari or contest sites. When based at my home 'drome off season, I have a hangar so I am typically rigged for months at a time off season. A person knowledgeable about such things recently told me that white lithium grease for the main high stress attach points (wing pins and lift pins) is not good, it dries out and/or cannot stand up to or stay in place due to the high stresses on those components, and the result is scoring. This makes sense to me, and I am thinking about changing to a better grease for long-term rigging. He suggested molybdenum disulfide grease. I would like to invite comments on this. Are there other options for grease for long-term rigged gliders? What are the best sources (USA) for such greases? Thanks in advance, Cheers, Jim J6 |
I had the lift pins replaced on my ASH 26 E at 3000 hours, due to pitting and
wear. The wings weren't loose or making any noise, but Rex Mayes was doing the 3000 hour inspection, and said it was a good idea. I rigged it for about half it's flights, the other half it remained assembled, primarily at glider camps. I used various grease, but primarily the grease that came with the glider in a little unmarked - thick amber axle grease is the look of it. I was not very diligent with greasing the pins. The pitting is something that proceeds slowly, so you have years to order replacement lift pins (or rotate them 180 deg, as some pilots do). kinsell wrote on 2/3/2020 6:37 PM: I believe our national dealer has recommended Master Pro Multi Purpose Lithium Grease.* If you're looking a a nasty messy gooey black grease suitable for wheel bearings, this one fills the bill perfectly. I've always been happy with the white lithium stuff in a tube myself. -Dave On 2/1/20 4:42 PM, Jim Hogue wrote: So, I have been using white lithium grease for decades for all my glider fittings.* This has worked out fine, no problems ever, all my fittings have stayed nice, with no damage of any kind. However, now that I have an 18 meter motorglider and am retired and blessed with time to go soar, my rigging habits have changed.* I now typically keep my glider rigged for weeks at a time when flying at soaring safari or contest sites.* When based at my home 'drome off season, I have a hangar so I am typically rigged for months at a time off season. A person knowledgeable about such things recently told me that white lithium grease for the main high stress attach points (wing pins and lift pins) is not good, it dries out and/or cannot stand up to or stay in place due to the high stresses on those components, and the result is scoring.* This makes sense to me, and I am thinking about changing to a better grease for long-term rigging. He suggested molybdenum disulfide grease. I would like to invite comments on this.* Are there other options for grease for long-term rigged gliders?* What are the best sources (USA) for such greases? Thanks in advance, Cheers, Jim J6 -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) - "A Guide to Self-Launching Sailplane Operation" https://sites.google.com/site/motorg...ad-the-guide-1 |
Hard to think there is any techincal requirement for special grease with glider main and lift pins. The enviroment is not that extreme. Just put some clean vaseline on pins and clean old dirty vaseline off every time you rig. This has been done succesfully for close to 100 years now. Some pin wear is pretty normal during 3000 hrs no matter what grease you use.
I have been using WD40 spray grease for a couple of seasons. Easy to apply an non messy. They do two variants including a lithium based grease which is good for high loads -25C to 130C Any reason not to? Jim |
Le mardi 4 février 2020 09:08:00 UTC+1, krasw a écritÂ*:
Hard to think there is any techincal requirement for special grease with glider main and lift pins. The enviroment is not that extreme. Just put some clean vaseline on pins and clean old dirty vaseline off every time you rig. This has been done succesfully for close to 100 years now. Some pin wear is pretty normal during 3000 hrs no matter what grease you use. Absolutely. I have been using plain automotive grease for the last 20+ years on my gliders and can't imagine why I should give it any more thought. |
On Tuesday, February 4, 2020 at 12:08:00 AM UTC-8, krasw wrote:
Hard to think there is any techincal requirement for special grease with glider main and lift pins. The enviroment is not that extreme. Just put some clean vaseline on pins and clean old dirty vaseline off every time you rig. This has been done succesfully for close to 100 years now. Some pin wear is pretty normal during 3000 hrs no matter what grease you use. Super Lube- has the same consistency and appearance as Vaseline just not as messy and goes on thin. |
| Thread Tools | |
| Display Modes | |
| The Long-Term Outlook for the U.S. Navy’s Fleet - CBO | Mike | Naval Aviation | 2 | January 28th 10 10:46 PM |
| Long term storage | JSBOUGHER | Owning | 19 | October 18th 06 12:49 PM |
| Easily single rigged gliders | Bill Alexander | Soaring | 12 | December 3rd 04 05:40 AM |
| Composite Aircraft in the long term... | Jay Honeck | Owning | 29 | September 9th 03 01:55 AM |
| Composite Aircraft in the long term... | Jay Honeck | Piloting | 29 | September 9th 03 01:55 AM |
