LiFePo Refit Part 23 AC
Old March 7th 20, 04:19 PM posted to rec.aviation.soaring
Dan Marotta
Default LiFePo Refit Part 23 AC
Oh, and Fidel recommends removing the tail battery before trailering the
glider.Â* It should be apparent why.
On 3/7/2020 9:17 AM, Dan Marotta wrote:
My LAK-17a had an SLA tail battery and it was needed as ballast. When
I got a LiFePO4 battery, I put it behind the seat and put a block of
lead, which matched the removed battery weight, in the tail.Â* I
suppose I could have simply left the dead battery there and saved some
work but I didn't want to risk it leaking.
On 3/6/2020 5:47 PM, cdeerinck wrote:
While not necessarily applicable to your situation, FYI, DG prohibits
the use of any Lithium-Ion (even LiFePO4) in the tail compartment of
its gliders, which surprised me, and foiled my plans.Â* I suspect they
have their reasons.
I don't know if that applies to an LS or not.
Best to check with them on what is allowed in your situation.
Dan, 5J
Old March 7th 20, 05:13 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
From the LAK? Or all gliders? And just lithium batteries, or all types of
batteries? And what is the concern? I've never heard that advice before.
Dan Marotta wrote on 3/7/2020 8:19 AM:
Oh, and Fidel recommends removing the tail battery before trailering the glider.
My LAK-17a had an SLA tail battery and it was needed as ballast. When I got a
LiFePO4 battery, I put it behind the seat and put a block of lead, which matched
the removed battery weight, in the tail.* I suppose I could have simply left the
dead battery there and saved some work but I didn't want to risk it leaking.
While not necessarily applicable to your situation, FYI, DG prohibits the use
of any Lithium-Ion (even LiFePO4) in the tail compartment of its gliders, which
surprised me, and foiled my plans.* I suspect they have their reasons.
Old March 8th 20, 04:14 PM posted to rec.aviation.soaring
Dan Marotta
The recommendation is to remove weight which is placed high up in the
tail during road transport.Â* Jostling during trailering adds stress to
the aft fuselage at the base of the fin.Â* He has showed me very fine
cracks in the paint/gel coat.Â* Put simply:Â* Remove tail batteries before
trailering.
of batteries? And what is the concern? I've never heard that advice
before.
the glider.Â* It should be apparent why.
When I got a LiFePO4 battery, I put it behind the seat and put a
block of lead, which matched the removed battery weight, in the
tail.Â* I suppose I could have simply left the dead battery there and
prohibits the use of any Lithium-Ion (even LiFePO4) in the tail
compartment of its gliders, which surprised me, and foiled my
plans.Â* I suspect they have their reasons.
Dan, 5J
Refit Bomber Aircraft Will Help Scientists Study the Total Solar Eclipse pics 2 [1/7] - WB-57 2.jpg (1/1) Miloch Aviation Photos 0 April 15th 17 03:33 PM
Refit Bomber Aircraft Will Help Scientists Study the Total Solar Eclipse [6/8] - kapa20130730-018.jpg (1/1) Miloch Aviation Photos 0 April 15th 17 03:29 PM
Refit Bomber Aircraft Will Help Scientists Study the Total Solar Eclipse [2/8] - 715100main_jsc2011e038628_1600_946-710.jpg (1/1) Miloch Aviation Photos 0 April 15th 17 03:29 PM
Refit Bomber Aircraft Will Help Scientists Study the Total Solar Eclipse Miloch Aviation Photos 0 April 15th 17 03:26 PM
Solar panel chargers and LiFePo batteries [email protected] Soaring 5 May 5th 14 02:09 AM
