HANDHELD RADIO
Old March 28th 05, 09:42 PM
Tim Mara
sounds to me like the person using the handheld radio is not close enough to
the microphone.......if you're getting the transmission then the radio is
reaching your receiver
tim
Tim, it's neither. When someone uses the handheld on the ground when
I'm flying in my glider, the transmission is very weak. So much so
that I have to close all the vents and turn up the volume considerably
to hear what they are saying. The radio operates just fine; it's just
that it doesn't seem to transmit well.
I'm only guessing, but I'd put my money on the antenna as the problem.
Old March 28th 05, 11:16 PM
F.L. Whiteley
just checking
JRC has a pretty good track record, but one or two bad experiences can be
disappointing.
YMMV,
Frank
"BTIZ" wrote in message
news:h3O1e.565$ZV5.57@fed1read05...
ok... I think we all knew that... but from what I read... ICOM is not
JRC...
just cause ICOM is "made in Japan".. that does not make it JRC...
I did not see any affiliation to JRC in the article...
so.. whats your point?
BT
"F.L. Whiteley" wrote in message
please read the following
http://www.icomamerica.com/downloads/cq-interview.pdf
news:ViL1e.543$ZV5.432@fed1read05...
Hint,... it's not the antenna... it's the radio... JRC = Japan Radio
Corp...
Get an ICOM
BT
All,
I have been using a JRC JHP-500 handheld radio for field
communications
and have been a bit disappointed with it's performance. It has a
standard 6" flex antenna. When I am in the air and someone tries to
talk with me using the handheld, the transmission always sounds very
weak, even if I am flying right over the top of them at the airport.
For all I know, the radio is fine and the real culprit may simply be
the antenna.
Any suggestions?
Any suggestions on other (stock) handheld transceivers that have
worked
well for others that won't break the bank?
Old March 29th 05, 03:03 PM
Tim Newport-Peace
X-no-archive: yes
In article , Tim Mara
writes
tim
roups.com...
The next logical step would seem to be:
Attach a RF Power Meter to the radio (using a Dummy Load) and confirm
that the RF Power is as per specification.
If this is OK:
Attach an AM (Not FM) Modulation Meter in place of the Power Meter and
confirm that the depth of Modulation is to specification.
If these test return OK results then it is probably a User Problem.
Tim Newport-Peace
"May you be cursed with a chronic anxiety about the weather."
John Burroughs (1837-1921).
Old March 15th 16, 04:34 AM posted to rec.aviation.soaring
Default HANDHELD RADIO
JVC= Japan Victor Company, an old subsidiary of RCA - RCA-Victor
Even if you by an American radio it's probably A. Made in Japan or B. Manufactured with Japanese components.
But Icon is a good low to mid end radio, but if you're talking about a back-up radio that could be the difference of survival or not a couple dollars in your pocket sure won't do you any good when you're 8-10ft ASL on a some mountaintop!
Old March 15th 16, 04:57 AM posted to rec.aviation.soaring
All handholds suffer from some Faraday effect when transmitting from inside a vehicle be it a plane a car or whatever. Your best bet is splicing into your external antenna.
Another good idea is to looking into how and why different antennas are made and take a crack at it. If you're lucky enough to survive an aerial catastrophe and all you have is your back-up handheld you can greatly increase the TX distance of your handheld just by using parts of your craft to "MacGyver" a possibly lifesaving antenna.
Old March 15th 16, 11:03 AM posted to rec.aviation.soaring
Casey[_2_]
Two of us at our club have the Vertex VXA-220, and no problems so far.
https://www.youtube.com/watch?v=PUqve7OchwQ
Old March 16th 16, 12:52 AM posted to rec.aviation.soaring
Vaughn Simon[_2_]
Which reminds me. I have a Vertex VXA-150 that has become surplus to my
requirements. In very good condition! This one hasn't seen lots of
use, but it's light enough that I used to fly with it hanging from my
neck on a breakaway lanyard. It was always handy and never adrift or
(worse) behind a rudder pedal!
http://www.acespilotshop.com/pilot-s...-150-pro-v.htm
vaughnsimon at gmail dot com
Vaughn
Boosting ICOM IC-A23 Handheld Aviation Radio CHANGE USERNAME TO westes Instrument Flight Rules 23 June 9th 04 12:41 PM
STS Handheld Radio Repair - USA Ray Lovinggood Soaring 3 April 25th 04 01:33 PM
Vertex VXA-150 Pro V handheld radio question Alan Meyer Soaring 2 April 24th 04 01:42 PM
Ext antenna connection for handheld radio Ray Andraka Owning 7 March 5th 04 01:10 PM
Ham Radio In The Airplane Cy Galley Owning 23 July 8th 03 03:30 AM
