new owner questions
Old March 29th 05, 04:27 PM
Michael
Jay Honeck wrote:
2. My nav indicators are a King KI-204 with glideslope and an old
KI-201 or something that is like 30 deg off (2 KX170b's). If I buy
a
KI203 on Ebay to match the 204, is it as simple as popping out the
old
indicator and pushing in the new one.. will the pins match? Or is
this
something I just leave to the local avionics guy?
Are you planning on flying IFR with this aircraft? Do you REALLY
want to
slide down an "Ebay Glideslope" in the clag? Some things just cost
money,
man; let the avionics shop have a whack at this one.
In aviation, things are often counterintuitive. I've generally had
much better luck with buying stuff off ebay and installing it myself
rather than allowing an avionics shop to have a 'whack' at my airplane.
Unfortunately, the units are not pin compatible.
My advice - first swap the KX-170B's to make sure it's the indicator,
not the radio. Then, once you know it's the KI-201 or KX-170B, watch
Ebay for a good deal on whichever one you need. I find it's usually
more cost-effective to do that than repair an old piece of avionics,
and besides whenever the monkeys at the avionics shop work on a plane,
they break something. Better to do it yourself, and all it takes is an
A&P logbook entry. That's if anyone notices - you are, after all,
replacing identical parts...
3. If I replace the wing root seal, do I need an A&P signoff?
If you mean that black rubber thingy at the wing root, no. If you
mean some
sort of a speed fairing wing root seal, yes.
Actually, either one would be a non-structural fairing or cowling, so
either way no signoff needed.
Michael
Old March 29th 05, 06:42 PM
Jay Masino
mean some
The speed mod fairing (like the Knots2U one) requires an STC and 337, so
it's a not the same as removing/replacing an existing OEM fairing.
--- Jay
__!__
http://www2.ari.net/jmasino ! ! !
http://www.oceancityairport.com
http://www.oc-adolfos.com
Old March 29th 05, 07:30 PM
Blanche
mean some
But remember, the wing root seal was originally installed BEFORE the
wing was attached!
Old March 29th 05, 08:01 PM
Michael
so
wing was attached!
Are you sure? In any case, I've never seen anyone pull the wing off to
replace the wing root seal. The deteriorated seal is pulled out, and
the new seal is pushed in, at least on every Piper product I've ever
seen. That's clearly a preventive maintenance operation, since the
seals are non-structural and the removal and replacement requires no
complex aseembly/disassembly operation.
Michael
Old March 29th 05, 08:08 PM
Michael
so
Actually, only the original installation requires a 337, because a
major alteration takes place. After that removing and reinstalling the
same fairing is preventive maintenance.
There is actually logic to this (pretty rare for the FAA) - the
original installation requires a change to type design. It may require
new fasteners, changes to the mounting points, whatever. It makes
sense that it's not something an untrained person should do. But once
the original installation is done, taking it off and putting it back on
is no big deal.
In general - you would be surprised at how much the owner can legally
do, provided he follows the proper procedures.
Michael
Old March 30th 05, 03:09 AM
Blanche
Michael wrote:
so
wing was attached!
At the factory, at the initial installation of the root seal, it's
attached to one side (I forget which, probably the wing) before the
wing is attached to the body. That's why it's so d*** difficulty to
get a new one installed by yourself!
Old March 30th 05, 04:21 PM
Jay Masino
so
That's what I meant. Sorry I wasn't clearer.
--- Jay
__!__
Old March 30th 05, 04:23 PM
Jay Masino
This doesn't make sense, to me. The "bulb" part of the seal squeezes into
the crack between the body and the wing. That's what holds it in
place. It wouldn't stay in place, when the wing was detached from the
body.
--- Jay
__!__
Old March 30th 05, 05:17 PM
Blanche
Jay Masino wrote:
[snip]
body.
Jay -- have you replaced the wing root seal? I agree the bulb is
what holds it in place. And trying to replace it (which can be
done, go back and read the r.a.o archives) is really awkward,
difficult and frustrating.
Homebuilt Aircraft Frequently Asked Questions List (FAQ) Ron Wanttaja Home Built 40 October 3rd 08 03:13 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 2nd 03 03:07 AM
