making turns for 15 knots
Old March 31st 05, 05:48 AM
Peter Stickney
Jim Carriere writes:
vincent p. norris wrote:
The secret squirrel part is how do you find out the blade rate to
knots correlation of everyone else's submarines.
Well, ATC can give a pilot a groundspeed readout based on tracking his
progress on the radar screen. Can't something of that sort be done
with subs?
As in time-distance using two or more fixes, yes. I think the old
fashioned way was with a piece of paper, but it is nothing for a
primitive (by today's standards) computer to do it for you with two
or several fixes.
An interesting thing about all that Target Motion Analysis jazz is
that in some ways, the old analog "Iron Idiots" were better at it than
the modern digital numerical computers. You'd crank in the inital
observed estimates, and see if the Fire Control System's generated
solution matched the target. If it didn't, you'd fudge this & that
(Target bearing & speed, for example, or range if the speed was known)
until it was tracking smoothly.
Pete Stickney
Without data, all you have are opinions
Old March 31st 05, 03:35 PM
Qui si parla Campagnolo
mah wrote:
In reading some of the novels and other books, you hear the sonar
operators saying "Making turns". How did you get a blade count
converted to knots?
Thanks
MAH
'Making turns' means set the 'enigine' to turn the shaft at a specific
number of turns per minute...
"make turns for 20 kts', tell the engine room via EOT, engine room makes
it happen, look at readout on the bridge...set number of turns which may
or may not equate to a speed..
From my time as a Midi on the John Paul Jones...summer of 1969...
Old April 4th 05, 12:55 AM
mah
Many thanks to those that replied. Still some good people out here.
MAH
21st Century E-Business Money Making Formula NeoTycoon Owning 0 January 18th 05 08:28 PM
21st Century E-Commerce Money Making Formula NeoOne Piloting 0 January 4th 05 12:57 AM
millionaire on the Internet... in weeks! Malcolm Austin Soaring 0 November 5th 04 11:14 PM
Landing and T/O distances (Was Cold War ALternate Basing) Guy Alcala Military Aviation 3 August 13th 04 12:18 PM
Can F-15s making 9G turns with payload? Paul J. Adam Military Aviation 114 September 27th 03 05:47 AM
