Shear Pins for Propellors?
Old April 1st 05, 05:36 PM
AES
The propellors on outboard motors for boats have (or at least always
used to have) shear pins.
The argument against using them in airplanes on safety grounds seems
pretty compelling, however. Boats keep floating even if the shear pin
shears . . .
Old April 1st 05, 06:21 PM
EL
In addition to the points made by others, let me throw this out:
Suppose the prop strike occurs when the engine is set to high power (maybe not the most likely scenario but quite possible).
The prop makes contact with something and the pin shears. At that very instant, the engine is set to high power but now has
no load on it. With no load, the engine will speed up a lot - way past redline. A likely outcome would be pistons,
connecting rods, and parts of cylinders/heads flying out in all directions, possibly followed by fire - considerably more
damage than from a normal prop strike!
Eric Law
"Rich Lemert" wrote in message link.net...
Back when I was growing up on the farm, we used several powered implements that received their power from the tractor
through a power take-off assembly. Somewhere on the device's power train, between the
PTO take-off and the "business end" of the apparatus, there was always
either a belt-drive or a coupling fitted with a "shear" pin. Both of these systems were intended to protect that tractor
(and the implement)
by failing if the implement bit off more than it could handle.
This morning, while driving past the airport on my way to work, the thought occured to me that a shear pin could be used
to protect airplane engines (at least partially) from prop strikes. My understanding is that the props on light singles (at
least) are connected directly to the engine's drive shaft.
Recognizing that this issue is driven as much by regulation as by anything, I'm wondering if there would be any benefit
to using shear pins in these systems. Would it reduce the need for a complete (or partial) tear-down after a prop strike?
Would there be any benefit for more complex propeller arrangements?
Any thoughts?
Rich Lemert
Old April 1st 05, 06:58 PM
Eduardo K.
The engine's ECU should take care of that. (grin
Eduardo K. |
| "World domination, now"
http://e.nn.cl | Linus Torvalds
Old April 1st 05, 09:06 PM
EL
Heh heh...
I once had a car where the rev-limit function was built-in to the fuel pump relay and it had a design quirk. Once the RPM
limit was exceeded, the fuel would be cut off but only after a short time delay. So the effective limit was 6100 plus
however many RPM you could get in about 1/2 second!
Eric Law
"Eduardo K." wrote in message ...
Eduardo K. |
Old April 2nd 05, 02:55 AM
Rich Lemert
Dale wrote:
In article .net,
anything, I'm wondering if there would be any benefit to using shear
partial) tear-down after a prop strike? Would there be any benefit for
Any thoughts?
I think the best protection for the engine would be to not land gearup,
taxi into super soft stuff, or do any of the other things that cause
prop strikes. G
Agreed, but then again I plan on asking for some spin training when I
get back into lessons again.
Rich Lemert
Old April 2nd 05, 03:11 AM
Rich Lemert
Dave Stadt wrote:
"John T Lowry" wrote in message
k.net...
Sounds to me like an idea worth pursuing. Could have two shear pins,
with visually checkable integrity during preflight inspection, to
counter the problem of one failing.
John Lowry
Flight Physics
Now you have added two additional points of failure.
Just to play devil's advocate (1): I would think that the pins could
be designed to have a mean time between failures at least as long as
that of the engines themselves.
Just to play devil's advocate (2): Would failure of a shear pin
be qualitatively any different than any other engine failure?
Just to play devil's advocate (3): Logic would suggest that a
propellor shaft shear pin failure would most likely occur during
take-off, since that's when the engine is delivering the most power.
Just how much torque is the propellor applying to the shaft at this
time?
(Disclaimer: I really do understand everyone's concern about adding
potential failure points to the system.)
Rich Lemert
Old April 2nd 05, 03:23 AM
Heywood
A 300-hp direct-drive engine is producing 583 lb-ft of torque at 2700
rpm.
Old April 2nd 05, 03:30 AM
Rich Lemert
This is something that I hadn't considered (and I suspect a lot of
others haven't, either). In fact, I think this answer is more compelling
than the primary answer I'm getting of "unnecessary potential failure
point", especially since you can probably design the MTBF for a shear
pin system to be at least as long as that of the engine itself, whereas
I don't see there being a simple way to implement an over-speed
prevention system.
Rich Lemert
Old April 2nd 05, 03:08 PM
Matt Whiting
(maybe not the most likely scenario but quite possible). The prop
instant, the engine is set to high power but now has no load on it.
likely outcome would be pistons, connecting rods, and parts of
fire - considerably more damage than from a normal prop strike!
prevention system.
Electronic rev limiters such as cars have had for years now... But that
is too modern a technology to be suitable in an airplane engine. :-)
Matt
Old April 2nd 05, 05:13 PM
The shear pin would fail at idle. The propeller on an airplane
is the engine's flywheel, and its inertia carries the crankshaft
between power strokes and smoothes its rotation. There's a
reciprocating force between the prop and crank flange, therefore, and
ANY looseness between the two will result in forces that will fail
attaching hardware. There have been cases of six 7/16" prop bolts
breaking when they weren't tight enough. There have been cases of
charring of wooden props when they weren't tight enough; the friction
created by small amounts of movement between the prop and flange heats
the wood. Props use six or eight substantial bolts for a reason: to
keep the thing on there tight. A shear pin in the system requires
looseness in the drive, and it just won't work. This isn't a boat ot
tractor. Imagine the damage when the flywheel of an outboard motor,
auto or tractor engine is a little loose.
Further, a sudden stop of the prop also pulls the crank radially
as the weight of the prop at its free end tries to keep moving. The
crank gets bent anyway, or the case fails, or engine mounts are
damaged. Any forward movement bends the prop backwards, too.
Dan
Newbie question on trailering Setup joe Soaring 11 December 26th 04 11:10 PM
sound of wind shear Dan Jacobson General Aviation 2 May 11th 04 11:43 PM
IPAQ Wiring - which pins are used Michael Soaring 9 March 15th 04 08:48 PM
Amazing Wind Shear Today Jay Honeck Piloting 25 December 3rd 03 10:23 PM
taper pins Ernest Christley Home Built 4 September 12th 03 03:15 AM
