Newbie VOR question
Old April 4th 05, 07:58 PM
Bruce W.1
Larry Dighera wrote:
You'd be surprised at how little the distance increases on a VOR route
compared to a direct route.
You're probably right about the distance. But doesn't everbody flying
TO/FROM VOR stations cause air traffic problems like near misses
(collisions)? Or being aware of this do you just watch the skies very
carefully near VOR stations? Or are there altitude guidelines for each
radial?
Old April 4th 05, 08:48 PM
Dan Luke
radial?
Sort of. There are rules defining what the usable altitudes are based on
magnetic course being flown. Opposite direction traffic should be at least
500' apart, vertically. This offers no protection, though, for aircraft
flying in the same direction or on converging courses that are on the same
side of the compass.
http://www.faa.gov/ATPUBS/AIM/Chap3/aim0301.html#3-1-5 defines VFR cruising
altitudes, which are 1,000' apart. IFR altitudes are 1,000' apart, too, but
are 500' above or below VFR altitudes. Above FL290 the IFR cruising
altitudes are 2,000' apart.
Dan
C-172RG at BFM
Old April 4th 05, 09:08 PM
Don Tuite
radial?
Traffic may be heavier over VORs, and the closer your heading is to
due North or South (where the hemisphere[1] rule toggles, the more
alert you should be.
That said, I've never actually noticed a particularly heavy increase
in traffic over VORs.
Don
[1] Why hemiSPHERE? Semi-circle I could see, but . . . .
Old April 4th 05, 10:06 PM
George Patterson
Bruce W.1 wrote:
You can calculate your position by triangulating from two VOR stations.
How many pilots do this? Or do most just fly between omnis? When you
fly cross country do you just fly VOR to VOR, or do you draw a straight
line to your destination and constantly triangulate while enroute to see
if you are on this line?
When I navigate using the VOR network, I usually go VOR to VOR in congested
airspace and straight line for long cross-countries. When traveling straight
line, I frequently use the triangulation method to verify my location when there
are no good landmarks nearby. I frequently use triangulation to determine the
point at which I pass an intersection or waypoint (whether official or
otherwise). For example, I may fly one radial from VOR "A" to remain outside the
DC ADIZ, but I know that I can change course once I pass the point at which a
particular radial of a second VOR crosses that one. In any case, I treat the VOR
network as sort of a backup to pilotage (and I treat pilotage as a backup to
LORAN/GPS).
As Larry pointed out, in most cases, using the airways usually doesn't increase
your enroute time all that much over going direct.
George Patterson
Whosoever bloweth not his own horn, the same shall remain unblown.
Old April 4th 05, 10:46 PM
Larry Dighera
On Mon, 04 Apr 2005 18:58:38 GMT, "Bruce W.1" wrote in
(collisions)?
Congested airways near VORs can be an issue. But the designers of the
VOR airway system had enough insight to separate east and west bound
VFR traffic by 1,000' vertically, and IFR traffic from VFR traffic by
500'. But airways, being only 4 nautical miles wide either side of
centerline can be congested over VORs.
Yes. That and ATC Radar Advisory Service are the principal methods
used to separate VFR flights on VFR airways.
Or are there altitude guidelines for each radial?
Nope.
Have you spent any time reviewing this:
http://www.airweb.faa.gov/Regulatory_and_Guidance_Library/rgFAR.nsf/CurrentFARPart!OpenView
Old April 7th 05, 05:15 PM
Klein
On Mon, 4 Apr 2005 13:03:03 +0000 (UTC),
(Paul Tomblin) wrote:
In a previous article, "Bruce W.1" said:
It sounds like you guys that still use VOR's fly to/from them and maybe
make course corrections when you hit a radial from another VOR. Just
seems like a zig-zag way to get around, but the easiest way (without GPS).
Some people have rho-theta RNAV systems which to the calculations for you,
so you can say "I want to fly to a point that's 23DME on the 186 radial
from that VOR", and it will give you a CDI just as if you were flying
directly to the VOR.
The plane that I flew up here to where I'm currently weathered in has a
KNS-80 that can supposedly do that, but I've never found the need. In IFR
you pretty much are on the airways or going direct to a VOR, and in VFR I
just use the GPS and go direct to the destination.
I used to fly a plane equipped with a KNS-80. The way I used it to
straighten out my course was to dial in the radial and distance to the
(n+1)th VOR in my flight plan as soon as I came in range of the nth
VOR in my plan. This also allows you to avoid overflying the VORs
with their higher traffic density. But give me GPS any day!
Klein
Introduction to a newbie Shane O Aerobatics 9 December 31st 04 06:13 AM
A question only a newbie would ask Peter Duniho Piloting 68 August 18th 04 11:54 PM
Newbie questions Rail / Ejector launchers AL Military Aviation 19 November 14th 03 07:47 PM
Newbie question Bill Gribble Soaring 6 November 6th 03 07:57 PM
Basic Stupid Newbie Questions... John Penta Military Aviation 5 September 19th 03 05:23 PM
