#11
The ceiling was still 1700 overcast, so he (atleast) started the approach
in the clouds. If he was on final approach, inside the marker, his heading should have been 240; bu tone witness reported seeing him flying NE. He must have been below the ceiling, in VMC, at that time. Perhaps that report is wrong; they often are. If it is correct, it is very puzzling since he was within sight of the airport. Sorry, I won't be able to respond to any questions; I'm leaving the country tomorow for six weeks. vince norris |
Well, not exactly. Although vacuum systems are ridiculously prone to
failure, my reasons for not finishing my instrument training a 1. Time. I was signed off to take the test back in '02 . Then we bought the hotel, and my time ceased being my own. 2. Utility. I have carefully tracked the weather since '02, to see what weather I would have flown in with an IR that I wouldn't have flown in VFR. In those nearly three years, we have not scrubbed a single flight that I would have flown in with my instrument ticket, simply because a Piper Pathfinder doesn't have de-icing equipment, and I can't wrestle with thunderstorms in a Cherokee. Because instrument weather around here consists primarily of either (a) icing *or* (b) thunderstorms (usually embedded), my instrument ticket would not enhance my flying much. 3. Proficiency. Because of this very lack of utility, I fear that one of two things would happen to me: (a) I would feel compelled to practice instrument flight regularly, in order to remain proficient. Instrument flying under the hood is not something I enjoy, and -- given my extremely limited time -- would take precious time away from the family flying that I currently am able to do. *or* (b) I would simply not use it very often, and then -- when I really needed it -- I would not be proficient at it. A non-proficient instrument pilot in the clouds is a very scary thought. So, some day, when my life slows down, I will finish up my instrument training -- not because I believe it's essential, or even because I think that it will enhance the utility of my airplane, because I know both of these statements are untrue. When I get the IR, it will be because I want to -- plain and simple -- or because I've purchased a Pilatus (or better) that can truly fly in the clouds in the Midwest. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Oh come on now Jay! ;-)
I just flew 6.5 hours in beautiful VFR weather today on IFR flight plans. There was the possibility of fog at my initial destination, but it burned off before we arrived. For this trip, it was more expeditious to file IFR due to transiting Class B airspace enroute. Takeoff, climb, cruise, set the autopilot, descend, land. Two weeks ago, I took off in VFR conditions but had to air-file to continue to my destination. I then shot an approach, breaking out 200 feet above the MDA. Had I not been instrument rated, I would have had to turn back and return to my departure point. With as many long cross-country trips that you make, you would have greater flexibility in your travel plans. You do not fly exclusively in Iowa, so to say that ice and thunderstorms are the reasons you choose not to complete your instrument rating is not as valid as you would like it to be. A family trip to and from Florida promted me to get current four years ago. We were in Savannah GA, got up at 7 am, the air was thick with humidity and with no wind. By the time we ate, checked out and got to the airport, the fog was thick on the ground. We waited four hours for it to finally lift sufficiently and break up for a VFR departure. Had I been current at that time, I would have waited only an hour for it to lift above approach minimums (you always want to be able to get back in if something should arise) and depart IFR. JUST DO IT! |
"jsmith" wrote in message
... [...] A family trip to and from Florida promted me to get current four years ago. We were in Savannah GA, got up at 7 am, the air was thick with humidity and with no wind. By the time we ate, checked out and got to the airport, the fog was thick on the ground. We waited four hours for it to finally lift sufficiently and break up for a VFR departure. Had I been current at that time, I would have waited only an hour for it to lift above approach minimums (you always want to be able to get back in if something should arise) and depart IFR. JUST DO IT! While I agree that Jay would likely get more utility from an instrument rating than he suggests, I also think that for someone flying recreationally, ratings should be obtained as they are desired. As he currently has no desire to get the rating, it's probably best he not waste time on it. And it certainly is a time-consuming rating. The instrument rating is roughly the same amount of work as the initial rating, IMHO. Pete |
JUST DO IT!
That's the worst possible reason to get a rating, AFAIK. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Blueskies wrote:
Ice... "vincent p. norris" wrote in message ... Fo those who inquired about this accident, here is the preliminary NTSB report: http://www.ntsb.gov/ntsb/brief.asp?e...31X00387&key=1 vince norris No post crash fire. No fuel? ....richie |
| Thread Tools | |
| Display Modes | |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 03:26 PM |
| 12 Dec 2003 - Today’s Military, Veteran, War and National Security News | Otis Willie | Naval Aviation | 0 | December 13th 03 12:01 AM |
| Single-Seat Accident Records (Was BD-5B) | Ron Wanttaja | Home Built | 41 | November 20th 03 06:39 AM |
| USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 04:17 PM |
| AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Piloting | 25 | September 11th 03 02:27 PM |
