Looking for a reversible fuel transfer pump
Old April 7th 05, 06:34 PM
Default Looking for a reversible fuel transfer pump
I have a 12Gal aux tank that I want to be able to transfer fuel TO and
FROM my main tank. For simplicity and lightness, I'd prefer to use a
single reversible pump on a single fuel line ... along with a solenoid
shutoff valve in series to prevent gravity flow when off.
There are cheapo plastic pumps available at a hardware store that would
"do the job" but I wouldn't consider using one in an airplane. Yet I
can't seem to find a QUALITY 12V reversible gear pump rated for
gasoline. (I did find a few for oil and diesel at aptly-named
reversopumps.com.)
Anybody know of one? Pump capacity isn't critical, but would like it
to be at least 3GPM.
Greg
P.S. I say "gear pump" above because virtually all gear pumps are
reversible by virtue of their construction, whereas other styles
usually are not. But I'm not hung up on a gear pump as long as it can
pump in both directions.
Old April 7th 05, 08:22 PM
Juan Jimenez
Would it not be easier (and probably cheaper) to find a valve that can
switch input and output?
Juan
reversopumps.com.)
Greg
Old April 7th 05, 10:18 PM
Ya, that's another option. I doubt it'd be CHEAPER or LIGHTER than a
reversing pump, but if I can't find a reversing pump then such a valve
may be my ONLY option. So OK, I'll bite:
Where can I get a quality valve that supports swapping of inputs and
outputs, and will handle gasoline?
I actually had this drawn up long ago with a standard 4-way valve (such
as used with fuel-injection), a pair of one-way check valves, and lots
of interconnects. It seemed to be overly complicated. I can't find
that sketch now, tho' I'm sure I can recreate it with a little thought.
If there's a purpose-made valve for this, that would be GREAT.
Greg
Old April 8th 05, 04:28 AM
Juan Jimenez
Maybe this will work.
http://www.reversopumps.com/valve_assemblies.html
I think these folks have the reversing pumps as well....
http://www.reversopumps.com/download...Industrial.pdf
Greg
Old April 8th 05, 04:29 AM
Juan Jimenez
Geez, I just read your original message and saw you had been to
reversopumps.com already. Had you seen that valve already?
Greg
Old April 8th 05, 02:55 PM
Yup, I'd been to reversopumps.com early in my quest, and subsequently
contacted them as to whether gasoline was supported. They responded
quite quickly: Nope. (Actually, it says this in their FAQ section too.
But diesel would be OK.)
Meanwhile, I re-drew the "plumbing circuit" using a single
non-reversible pump and a duplex valve (e.g. an FS22-D2). It's not all
that complicated ... but the valves is very $expensive. And I'd really
like to be able to do this electrically rather than mechanically.
So I've also been researching solenoid-actuated valves, and have put in
some inquiries to several of the manufacturers as to their suitability
for gasoline. I can obviously do it with a set of four 2-way solenoid
valves, or with a pair of 3-way valves and a 2-way.
But the #1 choice would still be a reversible pump for gasoline ...
along with an on-off 2-way solenoid in series if necessary.
Greg
Old April 8th 05, 09:03 PM
Morgans
IMHO, a setup like you describe has too many possible points of failure.
Better off with the mechanical valve, for reliability.
Old April 9th 05, 07:29 AM
Rob Turk
You should be able to do this with two simple left-right switch valves.
Doesn't cost much and it's quite light.
http://www.aircraftspruce.com/catalog/appages/whfsv.php
Rob
Night flying in the mountians in a cessna 150, NW_PILOT Instrument Flight Rules 150 March 4th 05 06:13 PM
Night flying in the mountians in a cessna 150, NW_PILOT Owning 135 March 4th 05 06:13 PM
Replacing fuel cut-off valve with non-a/c part??? Michael Horowitz Owning 46 January 15th 05 10:20 PM
Anybody need a fuel transfer pump? Roy Smith Home Built 1 January 5th 04 05:53 PM
Pumping fuel backwards through an electric fuel pump Greg Reid Home Built 15 October 7th 03 07:09 PM
