task not completed ClearNavII
Old May 15th 20, 05:48 PM posted to rec.aviation.soaring
Default task not completed ClearNavII
Without an email, don’t know how to point at it.
Old May 14th 20, 07:57 PM posted to rec.aviation.soaring
BobWa43
On Thursday, May 14, 2020 at 10:04:24 AM UTC-4, BobWa43 wrote:
I am new to ClearNav2. I have planned and flown two FAI tasks using the ClearNav2. ClearNav gave me a start time and changed from the start to first way point and then to the second way point, and then to the finish but no finish was acknowledged. I had the same task in my Nano and my Oudie, both recorded a completed task and the Oudie gave me a "task finished" announcement. This sequence applies to both flights. When the flights were analyzed on SeeYou, the files from the Nano and Oudie produced task completed analysis while the files from the ClearNav in one case said no valid start and in the other only the start was acknowledged. Does ClearNavII give a task completed statement like the Oudie? This is very frustrating. Please help me figure out what I am doing wrong. I would be happy to email the flight files to anyone who is interested and could help.Thanks ,
BobW
Thanks to all who have responded. I do not understand the time stamp problem. Could some one discuss this issue in more detail or point me to the previous discussion.
Old May 14th 20, 08:03 PM posted to rec.aviation.soaring
kinsell
BobW
There was a big discussion "Implausible Time Records" here a year ago.
The gps module (made by U-Blox) gets the time from satellites as soon as
it has position lock, but a few minutes later, a leap second correction
factor is received and makes the time jump backwards a few seconds.
Doesn't seem like a big deal, but causes some of the analysis software
to go bonkers. OLC can show bizarre plots where the entire flight is
compressed into a small portion of the time vs altitude graph for example.
Marotta started that discussion, he was also getting apparent GPS
jamming on parts of his flights, which complicated things.
-Dave
Old May 16th 20, 02:06 AM posted to rec.aviation.soaring
Nick Kennedy[_3_]
Whatta mean the CN2 doesn't text all my friends that I finished my task?
What kinda BS flight computer is that??
Do you live in a cave?
Its 2020 if you haven't noticed.
Nick
T
Old May 17th 20, 01:45 PM posted to rec.aviation.soaring
BobWa43
BobW
One mystery solved another found. It seems as though my ClearNav2 has suddenly started randomly recording high levels of engine noise, sometimes even when it is sitting on the ground. SeeYou gave me credit for an engine run in the middle of the flight thus changing the soaring start time to well after the task start time. Anyone experience similar behavior from their ClearNav2? Any explanation other than the usual vent noise, etc? Nano near ClearNav did not record any significant noise. Another good reason to restore the utility allowing downloads from Cambridge 302 through ClearNav.
Old May 17th 20, 02:25 PM posted to rec.aviation.soaring
Tango Eight
BobW
No, it's not supposed to do that. In the worst case, it's a hardware fault that will have to be corrected.
I answered the initial query here because it seemed like something that might have been of more general interest. I should have made clear that we typically do online customer support here https://clearnav.net/forum/index.php
best regards,
Evan Ludeman for CNi
Old May 17th 20, 03:01 PM posted to rec.aviation.soaring
kinsell
BobW
best regards,
He posted on the support forum first, got no solution, so then he posted
here.
I looked at his log, he also has a bizarre issue with B records having
duplicate time stamps. Sounds like flakey hardware that needs to be
replaced.
-Dave
Old May 17th 20, 04:20 PM posted to rec.aviation.soaring
Tim Newport-Peace[_6_]
to
produced
help.Thanks ,
BobW
sometimes
engine
through
ClearNav.
we
best regards,
here.
replaced.
-Dave
When recording at 1 second intervals, with a 1 second resolution, this can
happen. When it does. download again at (say) 4 second intervals.
Tim.
Old May 17th 20, 04:42 PM posted to rec.aviation.soaring
kinsell
to
produced
help.Thanks ,
BobW
sometimes
engine
through
ClearNav.
we
best regards,
here.
replaced.
-Dave
Tim.
He had downloaded at 2 second intervals and was getting this. Very
peculiar pattern to it, if the number of seconds ended in "3", then that
time stamp tended to be repeated, but with slightly different position
data, so it was a new reading. Occasionally other time stamps would be
repeated. Seems like electrical noise, or a bad chip to me.
I've asked for a 1 second interval download to see what that looks like.
2/3 completed Duster For Sale Blake Miller Soaring 1 November 28th 10 05:34 PM
FS: partially completed KR2 Jon Anderson Home Built 4 July 11th 08 07:03 PM
GA to 8ohm Headphone Adapter Completed Gary G Home Built 3 December 2nd 05 02:39 PM
GA to 8ohm Headphone Adapter Completed Gary G General Aviation 4 November 22nd 05 03:03 AM
TW Endorsement Completed [email protected] Piloting 7 May 9th 05 12:00 AM
