Homebuilts and radios!
Old September 23rd 04, 03:43 AM
Default Homebuilts and radios!
Hi, I am finishing the construction of a J-3. I intend to have the
following in the aircraft and would like to know if you can give me any
hints or suggestions on the type, location and mounting of the antenna
farm. I would either like to hide the antennas or build them from
scratch or kit. I am not sure what the uv protection on the fabric
would do to the signals if I use hidden antennas. The wing spars and ribs
are wood, and I plan to use Polyfiber to cover it.
I will have one of each of the following;
Microaire Comm
Microaire Transponder
PDA GPS System ( Would prefer built in system, but they are not in the
price range)
ELT
2-meter ham unit
Amateur TV Transmitter
Thanks
Old September 23rd 04, 03:13 PM
Stealth Pilot
Microaire Comm
price range)
ELT
2-meter ham unit
Thanks
what no twin overhead foxtails?
Stealth Pilot
Old September 23rd 04, 03:45 PM
sidk
I can offer a word of advice regards the Microaire Comm: I have one
in my Starduster that now works quite well but initially I was plagued
with howling in the transmit audio due to rf getting back into the
radio because of two deficiencies in my installation:
1) non-optimum match to the transmit antenna.
2) insufficient shielding of audio wiring.
After I did it right, it works great.
Sid Knox
Velocity N199RS
Starduster N666SK
KR2 N24TC
W7QJQ
farm. ;
Microaire Comm
price range)
ELT
2-meter ham unit
Old September 23rd 04, 09:42 PM
Craig
wrote in message ...
Microaire Comm
price range)
ELT
2-meter ham unit
Ahhh...small but not insignificant question here.....have you taken
the time to do a power loading analysis? Most Cubs that I know of
don't have either the battery or generator capacity to that much of a
load for any length of time.
Just for a data point, my Motorola VHF rig is 45 watt minimum, but
requires a 30 amp breaker.
Craig C.
Old September 24th 04, 03:26 AM
UltraJohn
Craig C.
What is it a tube type final? 45 watt should only require about 60 watt
input for the final plus maybe another 20 watt for the rest of the rig
including drivers (if it's transistor). That's less than 7 amps give it at
least 50% cushion would be around 10 amps so why 3 times the current for
the breaker?
John
Old September 27th 04, 07:43 PM
Craig
UltraJohn wrote in message nk.net...
the breaker?
Sorry for taking so long but I've had all the systems down due to some
ISP induced problems for the last few days.
Doubt it's a tube final (Motorola MCX1000), but I did take a better
look at the power cord this morning as I was getting ready to fab a
new mount for the van for it. Has a 3 amp control line and a 15 amp
main power line. The 30 amp line was a feed for some other gear for
the truck and just happened to be laying on the wire bundle when I
looked at it last week,
Craig C.
Old September 28th 04, 09:39 AM
John
nk.net...
at least 50% cushion would be around 10 amps so why 3 times the current
for the breaker?
Craig C.
I can accept that a lot easier ;-) Still quite a bit overkill so trying to
figure out what kind of electrical system capacity to power it along with
all the other gear in the plane I think you could figure a lot less.
Have a great day
John
kc5vb (but mostly inactive (got into it to tinker with electronics which is
both my hobby and profession!))
Old September 29th 04, 01:48 PM
Robert Bonomi
John wrote:
nk.net...
for the breaker?
Craig C.
Have a great day
John
Part of it is probably due to the fact that Motorola rigs are well known
for actual RF output _well_ above the 'nominal' output. I used to use a
nominal 30 watt VHF hi-band unit where the actual RF out was just over 47
watts. Every time I took it into the radio shop to have the cavities tweaked,
they insisted on doing a TX test. *Despite* my warning them about the output
level, they'd blow the attenuator on the test instrument every time. After
the puff of smoke, the urge to say "I told you so" was nearly overwhelming.
Nav/Comm for homebuilts question(s) Dave Gribble Home Built 3 August 29th 03 09:57 PM
