My turns and speed at altitude are getting a lot better, but are not consistent enough yet.I have done every
Landing so far with my CFI monitoring. Need more stick time. Working on sim (x-plane ASK 21)at home. I'm mostly in an ASK 21 for my training |
Seems your CFI is letting you practice doing it wrong which in this glider is a very bad idea. By flight 17 you should only be flying precisely coordinated all the time. I’d suggest working on that exclusively (if necessary with another CFI) until you’ve got it down. It will make all your other flying easier and safer
Thanks, my CFI is not letting me do this in the pattern anymore I feel his inputs on the controls if I start to get loose,and his verbal direction.The 2-32..that was a while ago. For some reason I find the ASK easier to fly cordinated. Need more stick time.
Making streamlined (centered yaw string), constant airspeed, constant bank angle turns in a glider is not easy. It requires you understand what to do, when to do it, and why you're doing what you're doing. Then it takes "lots" of practice. Simulation-based filght training provides the time and opportunity needed to accumulate the level of experience required. Condor is the best glider flight simulation available and is easily the best $60 you will ever spend with respect to your glider flight training.
I highly recommend you buy it from Cumulus-Soaring, Inc. I am available at no cost to help you get started with Condor. Contact me: smanley at wisc dot edu |
On Thursday, June 4, 2020 at 4:07:35 PM UTC-4, Scott Manley wrote:
Making streamlined (centered yaw string), constant airspeed, constant bank angle turns in a glider is not easy. It requires you understand what to do, when to do it, and why you're doing what you're doing. Then it takes "lots" of practice. Simulation-based filght training provides the time and opportunity needed to accumulate the level of experience required. Condor is the best glider flight simulation available and is easily the best $60 you will ever spend with respect to your glider flight training. I highly recommend you buy it from Cumulus-Soaring, Inc. I am available at no cost to help you get started with Condor. Contact me: smanley at wisc dot edu alright, Cumulus..is'nt that Paul Remde? I'll do that. thankyou |
| Thread Tools | |
| Display Modes | |
| FLORIDA to MICHIGAN | [email protected] | Soaring | 1 | April 22nd 20 06:55 PM |
| Thunder over michigan | DougS | Piloting | 3 | July 9th 07 03:22 PM |
| Michigan Rental? | Arnold Sten | Piloting | 2 | April 5th 05 01:36 PM |
| Winter in Michigan | Roger | Owning | 8 | January 28th 05 07:24 PM |
| Winter in Michigan. | Denny | Owning | 2 | January 28th 05 05:47 AM |
