STD Libelle Restoration Reccomendations
Old June 12th 20, 03:48 PM posted to rec.aviation.soaring
Nick Kennedy[_3_]
Default STD Libelle Restoration Reccomendations
Scotty
Just my 2 cents
Plan on putting a few bucks into a modern vario/ flight computer.
I think the best bang for the buck is a Cambridge 302 with a associated 303 display tied into a Naviter Oudie. Its easily plugged together, even I can do it and I'm a computer idiot. All you need to do is set the Baud rate of the 320 [ 4800 ] to the Oudie, easy.
This stuff can be picked up used pretty cheap and it works great and will really help you get up and away.
If you fly with any traffic around a Power Flarm is a great safety device which really works.
Get a couple of NEW LiPo batterys too!
Good luck with your project!
Nick
T
Old June 13th 20, 01:45 PM posted to rec.aviation.soaring
On Thursday, June 11, 2020 at 11:31:43 PM UTC-4, wrote:
Hello All,
I recently bought a Standard Libelle and would like some guidance/recommendations/ideas/etc if you guys would be so kind. Below is basically a list of things I would like some help with and the overall status of the glider as it sits.
1) Recommendations for epoxy, primer, and polyurethane topcoat brands. I see a lot of recommendations for a PPG Durathane but I haven't found a source for buying the real stuff. I plan on sanding down to the first hint of green glass and building the glider up.
2) Any of you libelle owners have a spare canopy or a mold laying around? Or any other libelle parts...
3) Panel wise, the glider already has a mechanical and total energy vario.. I have space for 2 more gauges, but don't plan on adding any of the fancy stuff unless I find a spectacular deal. Might remake the panel as it is a little scrappy as it is.
4) Any ideas?
Anything is appreciated. I am new to the airplane ownership club.
Happy landings,
Congrats on your new ship. I'm on my second Std Libelle project.
First- seriously consider refinishing. This is a big job and many are abandoned out of fatigue and frustration. About 1/2 a day into the project the standard comment is "there must be an easier way to do this". There isn't. It takes a lot of hours. We've done this a bunch of times and take about 400 hours to do a refinish.
If the finish is not badly cracked and crazed, consider sanding and polishing the existing finish to extend the useful life. My 201 is 48 years old and the wings are still very good with no cracking. The original Scwaballack finish held up really well. It is also a bitch to sand off.
If you do bite off refinish, do in stages. Fuselage or wings first, then the balance.
Most refinishers use PPG Concept acrylic urethane. There are other options, but this is the most commonly used.
Look at Richard's blog on the topic. It is very informative.
Good luck
UH
Old June 14th 20, 12:33 AM posted to rec.aviation.soaring
Scotty Tobin
Hello All,
3) Panel wise, the glider already has a mechanical and total energy vario. I have space for 2 more gauges, but don't plan on adding any of the fancy stuff unless I find a spectacular deal. Might remake the panel as it is a little scrappy as it is.
4) Any ideas?
Happy landings,
Have you done or found anyone's turbulator placement for the top and bottom or is that something that's better to do the actual experimentation for placement. On either of your rebuilds have you gone with the wing fairing? I am considering that if the performance is worth the work.
Old June 14th 20, 12:48 AM posted to rec.aviation.soaring
Hello All,
1) Recommendations for epoxy, primer, and polyurethane topcoat brands.. I see a lot of recommendations for a PPG Durathane but I haven't found a source for buying the real stuff. I plan on sanding down to the first hint of green glass and building the glider up.
4) Any ideas?
Happy landings,
I don't have the data on turbulator placement but I recall that it was reported to be a good improvement. Possibly the Libelle group site has it.
I have installed wing root fairings and winglets on a customer ship. Both improved performance and handling. The root fairings make the flow over the tail better and help tracking a good bit.
UH
Old June 14th 20, 07:06 AM posted to rec.aviation.soaring
Ross[_3_]
I took a few pictures of the things I did to mine
Somewhere I have the pics of the wheel as well. We changed it to a Beringet disc brake. Worked very well indeed
https://drive.google.com/drive/folde...3VfZkdsdFV0cmc
Old June 14th 20, 01:22 PM posted to rec.aviation.soaring
Love the carbon fiber stick grip and the leather seat cushion. Did you have those custom made for you or are they off the shelf items you purchased somewhere? Can you share you sources?
Robert
Old June 14th 20, 03:00 PM posted to rec.aviation.soaring
Scotty Tobin
Ooooohhh that’s a pretty bird. Second on the carbon stick and seat cushion.
You wouldn’t happen to have your original canopy or that mold laying around would you?
Old June 14th 20, 02:59 PM posted to rec.aviation.soaring
Scotty Tobin
Do you have a link to this Libelle group site?
Old June 14th 20, 11:07 PM posted to rec.aviation.soaring
Join the group- Ross provided the link. Turbulator info is on that site.
UH
Old June 14th 20, 03:42 PM posted to rec.aviation.soaring
Ross[_3_]
I get all my upholstery done by a great company in Germany. Interieur.
They have supplied me with all the right stuff for years. no task is too big and they have all the patterns for almost every glider.
I am not affiliated with them in any way but have known them for 25 years
https://interieur-albstadt.de/interi...-albstadt.html
The carbon sticks are also great. I still have one here, but I would need to check the internal diameter to be sure it will fit a libelle, but I am 99% sure it will. If anyone is interested...
The Libelle group that is very active is he
https://groups.io/g/libelle/topics
Great bunch of guys that are always willing to exchange info and help out where they can.
Std. Libelle vs Club Libelle [email protected] Soaring 10 August 21st 19 01:00 AM
Chute Reccomendations for ASW19 Robert Tarnoczy Soaring 3 July 15th 16 05:02 PM
Portable GPS reccomendations Bob Piloting 4 October 31st 08 07:36 PM
reccomendations in Phoenix? driftingtrack Piloting 6 November 11th 06 09:18 PM
Reccomendations for used glider/trailer setup around 12K joe Soaring 3 December 17th 04 02:40 AM
