Mags
Old April 20th 05, 07:24 PM
Dan Luke
"Matt Barrow" wrote:
I routinely run my engine 50 LOP in cruise; the CHT's stay below 380
deg. How could I get it hot enough to "melt it down into slag?"
( Never mind!! )
Hee-hee! Now *I* did it!
I meant "50 ROP in cruise."
Dan
C-172RG at BFM
Old April 22nd 05, 01:46 PM
: I'm running in my overhauled engine - 4 hrs - all a full rich.
: I don't understand why you would want to operate the engine without
: leaning. No recommendation I've ever read about post-overhaul break-in
: ever included anything like that.
For breakin (4 hours is a good minimum for when most of the breakin should
have occurred), you absolutely need to run at a very high power setting. High cruise
(~70%) is a minimum, but I've seen recommendations of 85% or so as well. At those
power settings, you'll need to have a very rich mixture to:
A) Prevent major damage from detonation
B) Keep the engine cool (CHT cooler than "normal" preferrably)
I've got an EGT in mine (now well broken in), and in a long climb I'll lean to
maintain EGT I get at takeoff (1400 on my plane). If you don't have that, you're
better off leaving it full rich while you fly around for a few hours at 85%. A few
hours at wicked rich isn't going to hurt/dirty anything... just reduce power (70%)
before landing and lean it until it wheezes cook out the carbon buildup.
-Cory
* Cory Papenfuss *
Old April 22nd 05, 08:24 PM
TripFarmer
Just broke in 6 new Millenium Cylinders last July and their break-in
instructions said to run them at 100% for 2 hours at 3-4,000 feet. I did
this and the temps dropped after about 30 minutes showing the rings were
beginning to seat. They have run well since.
Trip
In article , says...
ruise
se
e
few
0%)
-Cory
* Cory Papenfuss *
Old April 23rd 05, 06:16 PM
TripFarmer wrote:
: Just broke in 6 new Millenium Cylinders last July and their break-in
: instructions said to run them at 100% for 2 hours at 3-4,000 feet. I did
: this and the temps dropped after about 30 minutes showing the rings were
: beginning to seat. They have run well since.
Exactly. "100%" at 3-4000' is probably 85-90% unless you're turbocharged.
Gotta run them hard and cool initially to seat them.
-Cory
* Cory Papenfuss *
Old April 24th 05, 12:52 PM
Mike Spera
IMO, an indication of something not right in the mag. It bears watching.
Well, I would recommend PULLING, not watching. You may have a shorting
coil ot other problem. Often, there are visual indications. I would
rather find out on the bench than during takeoff. Also check the wire
going to the ignition switch. This wire grounds the mag when the switch
is in the "off" position. If it is shorting somewhere else, this can
also cause your condition.
The probability of a mag problem is pretty high. The probability of all
4 bottom plugs fouling completely at the same time is pretty low, unless
you are burning 2 quarts an hour.
Good Luck,
Does anyone have Kitplanes Mag's from 1986? Nunya Home Built 10 June 21st 11 07:22 AM
VW1834 and Slick 4001 Mags M J Veary Home Built 4 March 4th 05 11:23 PM
FA: Slick Mags (used) 600 series with harness BFC Aviation Marketplace 0 June 24th 04 04:21 PM
Two Mags from Florida Larry Smith Home Built 7 October 25th 03 08:47 AM
Av mags and sims.... Don Parker Simulators 7 August 11th 03 05:48 PM
