Speed of a vario
Old August 10th 20, 12:51 AM posted to rec.aviation.soaring
Dan Marotta
Default Speed of a vario
During takeoff you're adding kinetic energy to the total energy of the
glider.Â* I would expect the TE vario to show the increase. Remember, it
shows total energy; the up and down movements of the needle are telling
you how the total energy of the system is acting.
On 8/9/2020 2:00 PM, BG wrote:
On Saturday, August 8, 2020 at 7:49:02 PM UTC-7, wrote:
Which vario has lowest latency? (Least delay to indicate thermal we pass)
Anyone has done side by side tests?
S
Sage Vario's are the fastest mechanical I know, however the seat of your pants is be far the most accurate if you fly well. Our typical TE systems have flaw that would prevent even the fast electrical or mechanical from giving good information. Have you ever glanced at your TE on take roll? Any horizontal wind gust shows as lift and sink, a typical take off roll shows 4-5 FPM lift!!. Using the seat of pants combined with a averager works for most of us.
BG
Dan, 5J
Old August 9th 20, 09:46 PM posted to rec.aviation.soaring
Scott Williams[_2_]
S
This interesting summary of the physiological delay of the visual system could be considered another reason a hypothetical 'instant' vario would be less than useful. If you like technicalities, that is.
Scientists have revealed the human brain has a 15-second lag that helps stabilize incoming visual information, which we don’t notice bombarding us in the course of our everyday lives.
Eyes tend to receive an enormous information load from dusk till dawn, and as one opens his or her eyes in the morning, the brain starts its intensive work, processing incoming pictures from the surroundings, including imagery from TV screens and computer monitors.
A team of vision scientists at the University of California, Berkeley and Massachusetts Institute of Technology (MIT) revealed this secret of the human brain: To save us from insanity induced by a constantly changing torrent of pictures, shapes and colors – both virtual and real world – the brain filters out information, failing in most cases to notice small changes in a 15-second period of time.
It actually means that what we do see is, in fact, a mixture of past and present. According to the research, published in the journal Nature Neuroscience, stability is attained at the expense of accuracy.
"What you are seeing at the present moment is not a fresh snapshot of the world but rather an average of what you've seen in the past 10 to 15 seconds," said study author Jason Fischer, Ph.D., a neuroscientist at MIT.
Old August 10th 20, 12:53 AM posted to rec.aviation.soaring
Dan Marotta
Well that all sounds scientific, but why then are sounds synchronized
with vision?Â* According to the below explanation it would seem that I
should see your lips moving 10-15 seconds after I heard what you said.
S
Dan, 5J
Old August 10th 20, 09:01 AM posted to rec.aviation.soaring
Chris Wedgwood[_2_]
S
We're gonna need to see that paper. Got a link?
Old August 10th 20, 03:45 PM posted to rec.aviation.soaring
Here's the link to the article (hit "download'). Though I commend Scott for slugging through the article and citing it (a welcome behavior for RAS), the authors do not conclude that the brain has a "15 second lag" to process the current visual field of an observer and has no connection with vario lag. It might have some loose relevance to a pilot's ability to pick out a moving, converging object from background when doing his/her scans. A 15 second lag would have meant more cavemen being eaten by dinosaurs.
https://www.researchgate.net/publica...ual_perception
Old August 10th 20, 09:45 PM posted to rec.aviation.soaring
If we had a 15-second lag in responding to visual stimulii, none of us could survive more than a few landings. Or the drive to the airport, for that matter.
Old August 10th 20, 10:17 PM posted to rec.aviation.soaring
Scott Williams[_2_]
S
I agree that a 15 second delay in perception is demonstrably false, but the delay effect does exist, only the degree is questionable.
try this reaction time test.
https://humanbenchmark.com/tests/reactiontime
Scott
Old August 10th 20, 11:25 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
pass)
S
Seems to me that, while simple reaction time is a fair measure for, e.g.
responding to a FLARM alert, its a bit more complex when responding to a
vario's audio and optical output.
For starters, you should be looking out the window, and only look at the
vario when its tones change - if then: I tend to use its sound and butt
feel for centering a thermal rather than looking at the waggling needle
until I'm reasonably centered. IOW, response to a vario is a complex
reaction to the feel of the air and the vario tone rather than a simple
response to an optical signal.
Martin | martin at
Gregorie | gregorie dot org
Old August 10th 20, 11:59 PM posted to rec.aviation.soaring
Dan Marotta
That was fun!
370 ms
301 ms
294 ms
290 ms
308 ms
That puts me in the 16.8 percentile.Â* What's that mean, anyway?
S
Scott
Dan, 5J
Old August 11th 20, 02:57 AM posted to rec.aviation.soaring
SoaringXCellence
Dan,
It means you're very slow, only faster than 16% of the test subjects. I got an average of 210, that's the 76 percentile.
MB
Best vario for airmass awareness across the speed range Jim Hogue Soaring 50 January 30th 20 12:26 AM
FS: ILEC SB8 Acoustic Vario / Speed Commander Michael Huber Soaring 0 December 17th 07 02:07 PM
Rico Speed to fly+ audio Vario 4 sale Gregg Leslie Soaring 0 October 21st 06 12:39 AM
FS: RICO VACS speed to fly vario computer Victor Bravo Home Built 0 September 7th 05 06:54 AM
FS: RICO VACS speed to fly vario computer Victor Bravo Soaring 0 September 7th 05 06:54 AM
