After spending many hours using a Pocket PC for navigation and weather,
I feel that PDA solutions can offer tremendous value but are not for everyone. If you are tech savvy and do not need the PDA for primary navigation you can potentially save many thousands of dollars vs. the cost of panel mount units and proprietary weather data feeds. Keep in mind that the underlying PDA operating systems are imperfect and can fail you at inconvenient times. Are you ready and willing to perform soft resets, define Bluetooth connections, proactively manage memory (i.e., don't run a bazillion applications at once), move files, configure Internet properties and acclimate to a screen with tiny fonts? If not, go straight for a dedicated aviation handheld or panel unit and get regional NEXRAD on your cell phone. That will keep you out of the worst weather. All NEXRAD data is minutes-old information regardless of how much you spend to get it and is not suitable for picking your way through storms. For missions that include hard IFR, I would want an in-panel display with a satellite NEXRAD receiver and an independent storm scope. The PDA would then make a good backup. One benefit of having a PDA is the wide range of aviation specific software applications. Mix and match to suite your needs without being locked into the offerings of a single vendor. Much like choosing a wine, start at the low end and work your way up. When you find one you like, stop. If you have a Pocket PC and an in-cockpit Internet connection (satellite or 'cell' phone), you can get a moving map with NEXRAD for a monthly cost equivalent to a couple quarts of Aeroshell 15w-50. I cringe when I read about pilots spending thousands of dollars on PDA based solutions. Hundreds is about right, not thousands. If that spare change is burning a hole consider spending it on training or maybe a 2nd AI. Search google using = Pocket PC Moving Map NEXRAD METAR for some on-topic links. |
Most people I've talked to about cell phone use in flight report no
signal above maybe 3000 AGL unless it's a satellite-based system. I've tried mine at 5000 AGL and got nothing. However, I do agree with your analysis of the PDA systems. I have one and would never use it as primary. |
| Thread Tools | |
| Display Modes | |
| Garmin/AT no longer supporting WSI weather on MX20 moving map | Peter R. | Owning | 10 | April 19th 05 04:08 PM |
| making the transition from renter to owner part 2 (long) | Journeyman | Piloting | 2 | April 15th 04 11:19 PM |
| FA: WEATHER FLYING: A PRACTICAL BOOK ON FLYING | The Ink Company | Aviation Marketplace | 0 | November 5th 03 01:07 AM |
| XMRadio Satellite Weather Has Arrived | Richard Kaplan | Owning | 37 | September 2nd 03 03:51 PM |
| And they say the automated Weather Station problems "ASOS" are insignificant because only light aircraft need Weather Observations and forecasts... | Roy | Piloting | 4 | July 12th 03 05:03 PM |
