FES climb rate question.
Old October 12th 20, 09:18 PM posted to rec.aviation.soaring
Mana
Default FES climb rate question.
As is the new LAK 17c FES https://www.youtube.com/watch?v=rxe6DIfPKb4
More prop clearance, 16s batteries and higher max RPM for 2.5 m/s climb rate. The angle of attack of the wing is smaller, back to what it was on the 17a (vs the 17b that was based on the fuselage of the LAK 19)
These gliders are sustainers only.
Looks like the Silent 2 is rated for self-launch.
As is the miniLak FES, also a 13.5M glider. It works well for them because they are lighter
than the 18M gliders.
Old October 12th 20, 10:16 PM posted to rec.aviation.soaring
Looks like keeping the tail down is interesting at 1:30 in the video.
What does the POH ask you to do with the stick?
If you use it to hold down the tail and hit a bump, then how high can the tail bounce before entering lawn mower mode?
Technically self launch, but with grass or tiger country, the tow line didn't look all that long and having the batteries full seems wise.
Old October 16th 20, 03:11 PM posted to rec.aviation.soaring
waremark
Take-off performance looks impressive. I was surprised by the amount of noise - sounded not unlike a petrol engined aircraft as it passed the camera, although presumably it is actually much less loud.
Any idea what the endurance is of that aircraft?
As the owner of a petrol self-launcher, I like to know that I have enough endurance for a launch to 2,100 feet (700 m), a relight if necessary, and a reasonable self-retrieve later if necessary. I will stick to petrol until batteries can cope with at least that.
Old October 17th 20, 12:13 AM posted to rec.aviation.soaring
2G
I would like to know if it can even launch to 2,100 ft without the motor/controller overheating.
Tom
Old October 17th 20, 12:53 AM posted to rec.aviation.soaring
John Foster
Much of the noise you hear from any propeller-driven aircraft comes from the tips of the propeller breaking the sound barrier. That won't change between an electric vs petrol engine. The longer the propeller, the faster the tips move.
Old October 17th 20, 03:50 AM posted to rec.aviation.soaring
2G
My ASH31Mi has a 1.55m diameter propeller that has a max rpm of 2500. If you do the math, this works out to 454 mph, well below the speed of sound. Few GA aircraft have props that go supersonic, and you can really tell those few that can.
Tom
Old October 17th 20, 04:23 AM posted to rec.aviation.soaring
Kenn Sebesta
You're right that a fair amount of noise comes from the prop, and in particular that petrol vs electric won't change this.
However, I do not agree that it's because of breaking the sound barrier. Good prop design will keep the max tip speed below 0.6-0.7 Mach at max RPM and flight speed. It would be extremely hard to spin a well-specced prop fast enough that you'd see tips breaking the sound barrier. In an airplane which doesn't have a prop specifically designed to work transsonic (which AFAIK is pretty much any airplane outside of a handful of research ones), the prop loses so much efficiency as the tips approach Mach that you either actually slow down or dramatically increase the required engine power.
Old October 17th 20, 04:50 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
John Foster wrote on 10/16/2020 4:53 PM:
The longer the propeller, the slower it turns.
Old October 17th 20, 07:48 AM posted to rec.aviation.soaring
andy l
It does happen, but rarer than you think. The Harvard is an example that comes to mind.
For me, the only one. Maybe design has moved on a bit since then
Old October 17th 20, 01:13 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
True, provided that the prop diameter, number of prop blades and RPM are
the same.
True only if the RPM stays the same.
The quietest propeller-driven aircraft I've heard is the Antares 20 - it
uses a large (2m diameter), slow turning two blade propeller. From 50m to
the side all you can hear as it accelerates past you on take-off is a
quiet fluttering/puttering noise.
At the other end of the scale, for shear prop-generated racket you can't
beat a CRESCO top-dressing aircraft - but you'll need to visit NZ during
the top-dressing season to hear that, unless your local jump club has a
CESCO PAC-750, which is probably just as loud.
Martin | martin at
Gregorie | gregorie dot org
Why Isn't Vx The Best Rate Of Climb? RandyL Piloting 18 September 28th 06 07:50 PM
figuring Rate of Climb Michael Horowitz Home Built 1 June 19th 05 03:16 AM
Newbie question on Rate of Climb Wright1902Glider Home Built 0 August 17th 04 03:48 PM
Rate of climb Dillon Pyron Home Built 3 May 8th 04 01:08 PM
Climb Rate for DG-600M Steve B Soaring 5 August 25th 03 08:17 AM
