Exhaust Tape
Old July 3rd 03, 02:07 PM
Scott
Thanks everybody for the replies. .
It sounds like the wrap does work but would require extra attention for
inspection of cracks. Does it stick to the pipes? Can I remove it
every annual or every other annual to inspect the exhaust pipes?
I have heard about ceramic coating the pipes. Can this be done after
they have been used for a few hundred hours? Also once they are coated,
does the ceramic interfere when repairing them, ie..welding a crack?
thanks,
Scott
Scott wrote:
AS sells an insulating tape for exhaust pipes. The theory that it will
cause more of the heat to leave the end of the exhaust pipe and less
into the engine compartment.
Since I have an updraft cooling system this would be very nice in the
summer since my exhaust pipes are below the cylinders.
Anybody use this stuff? Does it work? Does it last?
Any tips for installing it?
Scott
"Those who sacrifice freedom to get security, deserve neither."
- Benjamin Franklin
Old July 3rd 03, 03:17 PM
RobertR237
In article , Scott writes:
thanks,
Scott
I don't know about removal of the wrap but would suspect that it will not go
back on as easily once removed. Just a guess.
My understanding of the ceramic coating is that it can be applied even after
the pipes have been used for a while since the pipes are normally bead blasted
before application to ensure that a good bond is achieved. I would recommend
that it be done before use though. I am not too sure about the repair aspect
but don't believe it would cause any problems.
Bob Reed
www.kisbuild.r-a-reed-assoc.com (KIS Builders Site)
KIS Cruiser in progress...Slow but steady progress....
"Ladies and Gentlemen, take my advice,
pull down your pants and Slide on the Ice!"
(M.A.S.H. Sidney Freedman)
Old July 30th 03, 03:06 AM
Pat Thronson
3 questions,
Is "DIY" a chemical cleaner and what does it stand for?
How does the bead blasting work inside the header pipe? I would think the
inner corners would not be properly prepared for the ceramic coating, or is
the media inserted then vibrated? I would think the coating process would be
more of a need of a chemical clean and etch (pickling process) than a
mechanical one.
why not just buy a new tuned coated or exotic metal header for the engine,
pretty cheap compared to the money invested into the motor, imho.
Pat Thronson
Old July 3rd 03, 10:05 PM
Keith Olivier
Scott
If the tape wrapping is any good it will be made from ceramic or aluminium
oxide fibre with a foil on the outer surface to reduce erosion of the fibre
in service. The fibres are usually held together with a binder, so that you
can work with it without the stuff falling apart. After some service, the
binder either burns away or sets in the shape it is in, meaning that you
would normally irreparably damage the wrap by removing it after service.
How well it insulates depends on the thickness and the diameter, as well as
the so called "shot content" with ceramic fibre. Anything over 5 micron
diameter causes skin irritations (like everyone knows from fiberglass).
Under 5 microns this is reduced, but the risk of inhaling the stuff
increases.
An exhaust system can be perfectly reliable with insulation, provided it is
made from a high grade steel and has been designed with either slip joints
or bellows to compensate for the thermal expansion. I think that slip
joints are more common in aircraft designs, since the system does not have
to be absolutely airtight.
In most cases, working with a known cracked exhaust system can be a waste of
time, unless you are willing to do dye penetrant tests to locate all the
other cracks that there are bound to be, but are too small to see with the
naked eye. Ceramics do not melt at the temperatures that cause steel to
flow, hence weld contamination is a major problem.
Regards
Keith
"Scott" schrieb im Newsbeitrag
thanks,
Scott
