#11
Fat Albert the Apache dines on a diet of the cheapest, stinkiest,
crapola, 83 octane, gas I can find... He only gets toxic, lead spewing, plug fouling, valve sticking, 100LL, on trips where I can't get to the gas station.... My mechanic is mumbling because the plugs have gone 4 years and way over 400 hours and are going strong... This annual he said he HAD to change the plugs because of the hours, he felt he JUST couldn't sign them off for another year... I said, "Fine, JUST as long as you are paying for them!"... He changed the subject... I lean by the EGT at 70% or higher... On local flights I am normally at 60 - 65% power, lean em until they go rough, and smile... ymmv, sar, bni denny |
![]() wrote in message news:_CBfe.4084$nX1.2291@trnddc09... On 8-May-2005, "BTIZ" wrote: BTW, how many out there are aware that 80 octane unleaded avgas used to be available, back in the 40s and 50s? Actually I think it was available up into the mid to late 70s... 80/88, and it was colored Red... 80/87 avgas was (is) NOT unleaded. It just has less lead content than even "low lead" 100 (100LL) and WAY less than "conventional" 100 octane (which you never see anymore). The specification for red 80 octane did include the option for no lead to be added. We had it at the airport until about a year ago. |
Huh??? On my 230 hp O-470, I cruise at 23-squared, without any fancy
engine monitors. Using the "pull-until-it-feels-about-right" method of leaning, I get 12 gph. I can lean to that fuel flow without any undue engine sounds, too. But my EGTs go well over 1500 degrees, and my CHTs push 350 when I do. I would rather burn a bit more gas. On a side note, as I asked you earlier, what part # spark plugs are you running? I am curious due to your undue propensity to fouling while running avgas. I have no idea, and I don't have my logs handy. However, as I said, I will be replacing them with a hotter-burning plug when they wear out. Of course, without all that lead fouling, they may never wear out! ;-) -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
![]() Jim Carriere wrote: Awww, anecdotal evidence. Statistically speaking, you need a larger sample size ![]() Actually would be more like a longitudinal case study... same subject evaluated over a long period of time. Applicable only to the individual, or perhaps a population of similar subjects... but still a valid data point. I like the bit about the hours/years on the spark plug... Dave |
![]() "Jay Honeck" wrote in message news:shJfe.64410$r53.14308@attbi_s21... On a side note, as I asked you earlier, what part # spark plugs are you running? I am curious due to your undue propensity to fouling while running avgas. I have no idea, and I don't have my logs handy. However, as I said, I will be replacing them with a hotter-burning plug when they wear out. Of course, without all that lead fouling, they may never wear out! And I've never had a fouled plug (at all...nada) in the 1400 hours I've had my airplane, burning nothing but 100LL (TN IO-550). Maybe you're just unlucky :~) |
![]() "Jay Honeck" writes: Huh??? On my 230 hp O-470, I cruise at 23-squared, without any fancy engine monitors. Using the "pull-until-it-feels-about-right" method of leaning, I get 12 gph. I can lean to that fuel flow without any undue engine sounds, too. But my EGTs go well over 1500 degrees, and my CHTs push 350 when I do. I would rather burn a bit more gas. [...] OK, but that brings into doubt your assertion about your fueling style being a big cost savings, doesn't it? Using 25% more fuel at 70% of the cost per unit volume is only about a 10% savings. Or maybe you didn't lean aggressively on avgas either? - FChE |
But my EGTs go well over 1500 degrees, and my CHTs push 350 when I do. I would rather burn a bit more gas. [...] OK, but that brings into doubt your assertion about your fueling style being a big cost savings, doesn't it? Using 25% more fuel at 70% of the cost per unit volume is only about a 10% savings. Or maybe you didn't lean aggressively on avgas either? Right -- I leaned no differently with avgas. A cooler running engine will, all other things being equal, last longer. I *can* lean a lot more, push my EGTs over 1500 degrees, push my CHTs to 350+ degrees, save some gas -- and risk my new engine. Now, of course, there are many theories on leaning (I've read 'em all), but with my normally aspirated engine having such (relatively) unbalanced fuel flow to each cylinder, I don't feel comfortable aggressively leaning. If I had fuel injected, balanced-flow GAMI-jectors, I'd be singing a different tune. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
![]() Jay Honeck wrote: At cruise we tend to run 23 squared, leaned back to 15 gph. ????? No wonder you got fouled plugs. You should be around 13 gph at 23 squared for a 230 hp engine. |
![]() Jay Honeck wrote: Huh??? On my 230 hp O-470, I cruise at 23-squared, without any fancy engine monitors. Using the "pull-until-it-feels-about-right" method of leaning, I get 12 gph. I can lean to that fuel flow without any undue engine sounds, too. But my EGTs go well over 1500 degrees, and my CHTs push 350 when I do. EGT is irrelavant and 350 is not hot. |
On 9 May 2005 10:21:51 -0700, "Jay Honeck" wrote:
I *can* lean a lot more, push my EGTs over 1500 degrees, push my CHTs to 350+ degrees, save some gas -- and risk my new engine. Now, of course, there are many theories on leaning (I've read 'em all), but with my normally aspirated engine having such (relatively) unbalanced fuel flow to each cylinder, I don't feel comfortable aggressively leaning. John Deakin has written that if you lean to the lean side of peak and the engine runs rough, pulling on full carb heat will distribute the fuel into the air mixture better and give you the ability to lean to the lean side of peak. You might just try it, if only for a little bit if you are too uncomfortable with the process. Corky Scott |
MoGas Long Term Test: 5000 gallons and counting... | Jay Honeck | Home Built | 82 | May 19th 05 02:49 PM |
