Transponder installation article- Soaring Magazine
Old December 15th 20, 06:34 PM posted to rec.aviation.soaring
Dan Marotta
Default Transponder installation article- Soaring Magazine
On 12/15/20 10:15 AM, wrote:
On Tuesday, December 15, 2020 at 11:56:33 AM UTC-5, Dan Marotta wrote:
On 12/15/20 3:02 AM, wrote:
A few random notes from my TT22 installation:
- From the Trig Installation Manual: "The transponder power input is not protected against reversed power connections. Reversing the power and ground inputs to the transponder will destroy it. Check wiring before applying power."
-- A proven hazard demonstrated (luckily) by someone else
- Common sense for all transmitters but not obvious on a transponder: Make sure the antenna is connected before any transmission takes place. When is that? Generally, anytime the transponder is on GND, ON, or ALT switch mode and it gets and replies to an interrogation. SBY mode use (e.g., for initial TT21/22 SETUP programming) should be OK without having the antenna connected. But it's easy to mistakenly turn past SBY onto one of the "transmit" positions. So it's best to have the antenna connected before powering on.
- If you plan to have ADS-B Out by integrating a Trig TN70 or TN72, both the firmware on the TC20 control head AND the main transponder (TT21/22) must be of a certain version number or later (like v1.14 and v2.12, respectively). An authorized Trig dealer can confirm the current requirements and upgrade your firmware as needed.
-- The firmware versions are displayed very briefly on the control head screen after powering on. I video'd the sequence and replayed it several times to catch the numbers.
Good information about the firmware. I had to send the control head for
the TT22 in the Stemme to the avionics shop for upgrade. There was no
charge for the service IIRC.
Dan
5J
Thank you all for the help and information, as wel as the link to the original article. We're considering installing a trig22 with ADS-B out for or glider, which also happens to be a DG303 as in the article.
Thanks
If your DG303 is experimental, then get the TN72 GPS and TA50 antenna.
Those are what I installed in my gyro and they work perfectly. No need
to buy the gigantic TA70 antenna which is a pain to mount and costs a
bunch more. I mounted my TA50 antenna on the glare shield of the gyro
using the sticky back tape that came with it. It hasn't moved in 150
hours of flying plus ground ops.
Dan
5J
Old December 16th 20, 01:56 AM posted to rec.aviation.soaring
Dan
5J
Thanks
Dan
5J
Yes, our 303 is experimental so the trig22 seems like the best way to go. I imagine we'll be also opting for the ADS-B option given the relatively low cost and ease to do so.
Old December 16th 20, 02:41 PM posted to rec.aviation.soaring
Greg Palmer
Dan
5J
Thanks
Dan
5J
It was my article and install in Soaring. I have lots more pictures and some great wiring diagrams made by John DeRosa, email me or call with any questions or help needed. Greg Palmer 847-922-1234
Old December 19th 20, 10:14 PM posted to rec.aviation.soaring
2G
Dan
5J
Thanks
Dan
5J
I had the ADS-B out option installed on my ASH31Mi using the TT22 and the TN72, and highly recommend it. You will be much more visible to both ATC and airliners with TCAS. A big bonus is the power consumption of this pair is very low. I only wish this was permitted for certificated gliders.
Tom
Old December 20th 20, 02:04 AM posted to rec.aviation.soaring
- Common sense for all transmitters but not obvious on a transponder: Make sure the antenna is connected before any transmission takes place.. When is that? Generally, anytime the transponder is on GND, ON, or ALT switch mode and it gets and replies to an interrogation. SBY mode use (e.g., for initial TT21/22 SETUP programming) should be OK without having the antenna connected. But it's easy to mistakenly turn past SBY onto one of the "transmit" positions. So it's best to have the antenna connected before powering on.
Dan
5J
Thanks
If your DG303 is experimental, then get the TN72 GPS and TA50 antenna..
Dan
5J
Tom
Yes. I'm definitely interested in pursuing this... thanks for all the info and help.
Gregg. I'm sure I'll be in touch once the holidays settle down a little bit, this has been put on the backburner during the holidays. I always thought adding a transponder would be a good idea, but after a much more closer than comfortable encounter with another aircraft that I'm sure never saw me, it has become a priority. Adding the ADS-B out unit is in rhe plans as well.
Old December 22nd 20, 12:19 AM posted to rec.aviation.soaring
John Johnson
Should I assume it is not legal in the US to use a TT21 with a TN72 for ADS-B out in an experimental glider? That combination is ok in Europe (I think) with the difference being the US wants 2x the xmit power for ADS-B (TT22 at 250W) vs the 125W output of the TT21. I would like to think that having otherwise compliant, lower power ADS-B out is better (and not illegal) than no ADS-B out in an aircraft that is legal without ADS-B.
Probably not a realistic hope - but it would save me the not trivial expense of upgrading my TT21 to a TT22.
JJ
Old December 22nd 20, 01:23 AM posted to rec.aviation.soaring
Get the TT22. Don't consider the TT21. It could save you about $150 on a $2500 USD purchase but does not provide full ADS-B compliance. In the USA this means a TT21 does not allow you to fly in transponder-required airspace. The TT22 provides a full ADS-B out solution and more transmit power, yet its power consumption is identical to the TT21, according to Trig's spec sheets.
For an experimental glider you can use the same GPS receiver and antenna that you would find in a TT21 ADS-B out package (Trig TN72 and Trig TA50), so the only added cost is the $150 to upgrade to the TT22.
...david
JJ
Old December 22nd 20, 03:49 PM posted to rec.aviation.soaring
Brian Roach
On Tuesday, December 15, 2020 at 7:53:22 AM UTC-5, India November wrote:
On Tuesday, December 15, 2020 at 6:51:42 AM UTC-5, wrote:
After installation and testing are complete, take a flight and the check your FAA performance report he
https://adsbperformance.faa.gov/PAPRRequest.aspx
Mine flunked the first time. I had one of the configuration settings wrong, but it was easily sorted out with information provided by Prof. Pfiffner:
http://www.craggyaero.com/tt22_tn72_settings.htm
Cheers,
...david
I am thinking of installing a TRIG xponder for next season, maybe with ADS-B, but this would mean installing multiple GPS antennas (FLARM, C302, Xponder) and I'm running out of room under the glareshield.
Questions for the experts out the need there be a minimum spacing between GPS antennas (i.e. do they interact); and is there a way to connect one GPS antenna to feed one or more boxes?
Thanks!
Ian IN
Relative to multiple GPS antennas under the glare shield, I'm afraid nothing is simple in this world.
I have a standard category install (TRIG TN 70, big TA 70 GPS antenna), plus two other GPS antennas (FLARM, LX9000) about 6 inches away. No ill effects noted on anything after a good season of flying. I originally was leaning towards a splitter, but decided to try separate antennas first after considering the following.
You can get splitters/combiners/hybrids, but necessarily will lose ~4dB per 'split'. The GPS antennas are active, so each receiver will put a few volts DC on the coaxial antenna cable to power the amplifier integrated into the antenna. With multiple receivers you need a DC coupled branch on the splitter for only one receiver, and DC blocks on the other branches. Once you have this figured out, you need to look at the receiver specifications, since some interpret an open DC circuit as an antenna fault. Simple, huh?
Cheers,
Brian
MM
Old December 22nd 20, 06:38 PM posted to rec.aviation.soaring
John Johnson
On Monday, December 21, 2020 at 6:23:20 PM UTC-7, wrote:
Get the TT22. Don't consider the TT21. It could save you about $150 on a $2500 USD purchase but does not provide full ADS-B compliance. In the USA this means a TT21 does not allow you to fly in transponder-required airspace.. The TT22 provides a full ADS-B out solution and more transmit power, yet its power consumption is identical to the TT21, according to Trig's spec sheets.
...david
JJ
Fully agree a new purchase should be a TT22. Unfortunately, my glider has been setup with mode-S TT21 for some time now. I understand it costs ~$1000 or so to have an existing TT21 upgraded to TT22 specs. Since I can't see any practical need for my glider to have the 2x xmit power compliance, I'd like to save the $1000 and, perhaps, spend it in the future when the next wave of new transponder compliance requirements come about. I could always perform the upgrade later if that made sense for me.
thx, JJ
Old December 22nd 20, 06:56 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
John Johnson wrote on 12/22/2020 10:38 AM:
...david
JJ
I suggest you keep your TT21, but install a TN72 with a TA50 antenna (total equipment cost of
about $460). You can't use it to enter A, B, and C airspace, though there are probably some
exceptions for glider operating areas (and maybe others), but you otherwise have all the
features the TT22 would give you. Here's the Trig document for gliders:
https://www.trig-avionics.com/librar...ust%202018.pdf
Maxim Magazine soaring article [email protected] Soaring 15 April 1st 17 05:40 PM
October Soaring magazine OLC League article Mark628CA Soaring 22 October 11th 14 05:51 PM
Need help locating article from Soaring Magazine Tim Taylor Soaring 1 March 26th 10 10:57 AM
Need help locating article from Soaring Magazine Tim Taylor Soaring 0 March 24th 10 01:20 AM
Subaru magazine soaring article JS Soaring 9 March 21st 08 03:41 AM
