![]() "Wade" wrote I've been taught this shtudown procedure, too. But, what is the magic about turning them BOTH off, simultaneously? As someone else said, it catches a faulty "off" position, in the switch. -- Jim in NC |
Wade wrote:
If, at idle, you turned off the left mag, and noted an rpm drop, then turned off the right one, and also noted an rpm drop, then doesn't that confirm the same thing as turning both of and feeling for the engine to start to shut-down? No. Turning off the left mag verifies that that position of the switch will ground out the left mag. Turning off the right verifies that the switch will ground out the right mag in that position. You can only verify that "off" really grounds out both mags by turning the switch off. George Patterson "Naked" means you ain't got no clothes on; "nekkid" means you ain't got no clothes on - and are up to somethin'. |
and now the other part of that question... for most key switches that have
"Off" "Left" "Right" "Both" "Start" positions.. what happens when you go to the "Start" position.?. BT "Bill Zaleski" wrote in message ... You are shorting the magneto that is not selected, therefore inhibiting it's operation. On Tue, 17 May 2005 22:49:09 -0400, Martin B wrote: Hello, Here is my question: On regular aircrafts, like C150, C172, PA28, when we perform the magneto check where we select Left, than Right, while looking for RPM drop... what is the switch doing? When we select Left or Right, do we short that particular magneto or are we shorting the other one? I checked all my books and cannot find the answer. Thanks in advance, Martin |
"BTIZ" wrote in message
news:uhzie.7310$Db6.649@okepread05... and now the other part of that question... for most key switches that have "Off" "Left" "Right" "Both" "Start" positions.. what happens when you go to the "Start" position.?. Assuming just one magneto with an impulse coupling, the other magneto is shorted and the starter is engaged (by electrical relay, generally...I'm not aware of any airplane starter that runs the current straight through the mag switch). Note also that this is true only of systems that use an impulse coupling for starting. Of course, you could have just posted that information, rather than turning into a pop-quiz. ![]() Pete |
most correct answer...
"Peter Duniho" wrote in message ... "BTIZ" wrote in message news:uhzie.7310$Db6.649@okepread05... and now the other part of that question... for most key switches that have "Off" "Left" "Right" "Both" "Start" positions.. what happens when you go to the "Start" position.?. Assuming just one magneto with an impulse coupling, the other magneto is shorted and the starter is engaged (by electrical relay, generally...I'm not aware of any airplane starter that runs the current straight through the mag switch). Note also that this is true only of systems that use an impulse coupling for starting. Of course, you could have just posted that information, rather than turning into a pop-quiz. ![]() Pete |
![]() What's the logic of grounding the non impulse-coupled mag during starting? (Not a "pop quiz" - I'd like to know). G Faris In article , says... Assuming just one magneto with an impulse coupling, the other magneto is shorted and the starter is engaged (by electrical relay, generally...I'm not aware of any airplane starter that runs the current straight through the mag switch). Note also that this is true only of systems that use an impulse coupling for starting. Of course, you could have just posted that information, rather than turning into a pop-quiz. ![]() Pete |
Greg Farris wrote:
In article , says... Assuming just one magneto with an impulse coupling, the other magneto is shorted and the starter is engaged (by electrical relay, generally...I'm not aware of any airplane starter that runs the current straight through the mag switch). Note also that this is true only of systems that use an impulse coupling for starting. Of course, you could have just posted that information, rather than turning into a pop-quiz. ![]() Pete What's the logic of grounding the non impulse-coupled mag during starting? (Not a "pop quiz" - I'd like to know). G Faris The non-impulse magneto will fire earlier, if at all, and it may back-fire the engine, as the cranking speed is slow. -- Tauno Voipio tauno voipio (at) iki fi |
what is a non-impulse coupled magneto? (also a question, not a quiz)
"Greg Farris" wrote in message ... What's the logic of grounding the non impulse-coupled mag during starting? (Not a "pop quiz" - I'd like to know). G Faris In article , says... Assuming just one magneto with an impulse coupling, the other magneto is shorted and the starter is engaged (by electrical relay, generally...I'm not aware of any airplane starter that runs the current straight through the mag switch). Note also that this is true only of systems that use an impulse coupling for starting. Of course, you could have just posted that information, rather than turning into a pop-quiz. ![]() Pete |
![]() "BTIZ" wrote in message news:uhzie.7310$Db6.649@okepread05... and now the other part of that question... for most key switches that have "Off" "Left" "Right" "Both" "Start" positions.. what happens when you go to the "Start" position.?. BT Usually, the propeller starts turning and after a seond or two the noise level increases. Sorry, couldn't pass that one up. |
a good answer... but missing essential elements.. LOL
See Pete's answer BT "Dave Stadt" wrote in message m... "BTIZ" wrote in message news:uhzie.7310$Db6.649@okepread05... and now the other part of that question... for most key switches that have "Off" "Left" "Right" "Both" "Start" positions.. what happens when you go to the "Start" position.?. BT Usually, the propeller starts turning and after a seond or two the noise level increases. Sorry, couldn't pass that one up. |
American nazi pond scum, version two | bushite kills bushite | Naval Aviation | 0 | December 21st 04 10:46 PM |
Hey! What fun!! Let's let them kill ourselves!!! | [email protected] | Naval Aviation | 2 | December 17th 04 09:45 PM |
Accidents happen... | Manuel | Piloting | 26 | November 28th 04 11:32 AM |
LEFT WINGERS IN FOR BIG SURPISE - STROKES TO FOLLOW ELECTION | Jarg | Military Aviation | 3 | April 20th 04 06:37 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
