soaring on Mars?
Old January 14th 21, 02:19 AM posted to rec.aviation.soaring
Moshe Braner
Default soaring on Mars?
If there are dust devils there is lift!
https://www.goodnewsnetwork.org/a-na...rs-3000th-day/
Old January 14th 21, 03:11 AM posted to rec.aviation.soaring
AS
Agreed but the 'air' pressure on Mars is around 6mb vs. 1013.25mb (0.1771 inHg vs. 29.92 inHg), so the wing design and speeds at which said wing will have to move to produce lift will be dramatically different compared to what we are used to.
Uli
'AS'
Old January 14th 21, 03:37 AM posted to rec.aviation.soaring
John Good
20-some years ago, AeroVironment proposed a glider for Mars photography. They got as far as testing a model, as shown in this short video:
http://www.airspacemag.com/videos/ca...rs-airplane_1/
Old January 14th 21, 10:56 AM posted to rec.aviation.soaring
Airport Bum
Retrieves would be challenging....
Cheers,
Jim J6
Old January 14th 21, 03:00 PM posted to rec.aviation.soaring
Martin Gregorie[_6_]
http://www.airspacemag.com/videos/ca...esting-a-mars-
airplane_1/
Around the same time Aurora tested a marsplane: this one was a bit bigger
and was designed to fold up to fit one of the standard aeroshells. It was
tested at around 100,000 ft, where air pressure is similar to Martian
ground level, by drolling it from a high altutude balool launched from
Hawaii. I remember talking about it with Bob Parks, who was the Aurora
project member when ARES was being set up and flew it for the high
altitude tests. He joked that if he'd been on the ball he could have
claimed a near-unbeatable FAI speed record when he was flying back to the
islands after a test - he reckoned it had hit around 500 mph early in the
return leg when still very high up.
https://www.nasa.gov/centers/langley..._ARES.htmls://
media.xconomy.com/wordpress/wp-content/images/2007/10/062
https://www.spacedaily.com/news/
marsplane-02b.html15133/1491665020_1004ad04ee.jpg
Martin | martin at
Gregorie | gregorie dot org
Old January 15th 21, 12:13 AM posted to rec.aviation.soaring
Jonathan St. Cloud
As any true aviator (helicopter pilot) knows the first flight on another world will be by the premier of all aircraft, the helicopter.
Mankind's magic carpet.
https://www.nytimes.com/2020/06/23/s...pter-nasa.html
airplane_1/
Martin | martin at
Old January 15th 21, 01:39 PM posted to rec.aviation.soaring
Yep, heard about it, but thanks for posting that URL. It will be
interesting to see how well it does on RealMars (TM). In Martian
conditions a helicopter makes more sense than a powered plane or glider
because it should have a much lower landing speed.
BTW, the Aurora ARES design had an inverted V tail on twin booms to keep
the stabiliser clear of exhaust from a rocket unit mounted on the centre
line at the wing's TE) - a common design in the S-8P rocket glider RC
competition class which, oddly enough, Bob Parks competes in with his own-
design models.
Martin | martin at
Martin JRM Mars Flying Boat pics [18/21] - Martin-JRM-3-Mars-Bu_No__-76822-Marshall-Mars.jpg (1/1) Miloch Aviation Photos 0 July 7th 16 03:56 PM
Soaring on Mars? Roy Clark, B6 Soaring 5 March 27th 05 09:45 AM
Soaring on a terraformed Mars - winter diversions Bill Daniels Soaring 4 January 30th 04 10:28 PM
For Lennie - soaring on Mars Mike Borgelt Soaring 0 September 30th 03 01:42 AM
Soaring on Mars puffnfresh Soaring 21 September 3rd 03 11:24 AM
