"The Muse"
Old May 23rd 05, 09:12 PM
R.L.
Aviation headsets have notoriously higher impedance than the typical earbuds
that come with Ipods and other consumer audio devices. Might be an impedance
mismatch requiring a matching transformer.
"Scott Skylane" wrote in message
H.P. wrote:
The audio output device needs a compression circuit to keep audio
levels
more near a constant output. There are portable cd players out there
that
have such a feature.
My iPod *does* have an audio compression feature, and it is turned on.
Quite simply, the minimum audio signal required to power up the Muse is
higher than I would like it to be.
Your headset may have a dip switch that's factory set to mono-out a
stereo
input - like the Bose headset. Try the other setting. Or it may be wired
in
mono. Try it on a stereo source at home.
No switch on my headsets, they're good ol' mono DC's. Knowing that the
majority of aviation headsets are mono, PSE incorporated a mini switch
inside the Muse, to provide either stereo or mono output. The position
of said switch has no discernable effect on the music I hear in my
headsets.
Happy Flying!
Scott Skylane
Old May 23rd 05, 09:29 PM
Scott Skylane
Ummm, yeah. And since the Muse is *designed* to input consumer audio
devices into aviation headsets, I would expect the built-in circuitry to
handle this just fine. IMHO, it does an "O.K" job, but not as good a
job as I would like.
Happy Flying!
Scott Skylane
Old May 23rd 05, 01:24 PM
OtisWinslow
I have one. It works fine for what it's intended to do. I think
an intercom with a music input would probably be a better plan.
"BTB" wrote in message
news:689ke.22001$gp.9619@fed1read03...
Anyone any experiences using "The Muse" for in-flight music ?
http://www.avionicswest.com/muse.html
Or there less expensive options ?
BTB
Old May 23rd 05, 03:24 PM
Thomas Borchert
Btb,
Uh, a headset with music input? If you don't have THE headset you always wanted already, this might be a good point to upgrade to an ANR headset with music input (and while you're at it, cell phone input, too). Lightspeed's headsets come to mind. Something like 250 $ will buy you their entry level ANR, which will get you the headset, music and cell input. The Muse seems a tad expensive in comparison.
Thomas Borchert (EDDH)
MessageEnd:
Old May 23rd 05, 10:32 PM
Paul kgyy
I've used the music input on my Lightspeed 30-3G and it's fabulously
good, IMO. Kind of a pain to have all that automatic muting going on
while flying IFR, though.
Old May 24th 05, 08:29 AM
Thomas Borchert
Paul,
So switch it off. The switch is in the battery compartment.
Old May 23rd 05, 09:30 PM
I have a "Muse" and I think it's of rather unimpressive design. The
battery door is loose, it's always a bit of effort to get the battery
to fit in their correctly, and the music volume is insufficient even
with the my iPod turned up and a fresh batter in the Muse.
Also, it's ridiculously overpriced.
Sportys has a new product that might fit the bill, though:
http://www.sportys.com/acb/showdetl....roduct_id=7145
Anyone try that yet?
This claims to be a both a cell-phone interface *and* a music
interface. That can be a benefit because the add on cell phone
interface like "AirCell" is *ridiculously* over expensive.
All these devices need to do is match connectors and match impedances.
There's just not much to it!
My $0.02,
Dave J
-- jacobowitz73 --at-- yahoo --dot-- com
BTB
