H.P. wrote:
The audio output device needs a compression circuit to keep audio levels more near a constant output. There are portable cd players out there that have such a feature. My iPod *does* have an audio compression feature, and it is turned on. Quite simply, the minimum audio signal required to power up the Muse is higher than I would like it to be. Your headset may have a dip switch that's factory set to mono-out a stereo input - like the Bose headset. Try the other setting. Or it may be wired in mono. Try it on a stereo source at home. No switch on my headsets, they're good ol' mono DC's. Knowing that the majority of aviation headsets are mono, PSE incorporated a mini switch inside the Muse, to provide either stereo or mono output. The position of said switch has no discernable effect on the music I hear in my headsets. Happy Flying! Scott Skylane |
Aviation headsets have notoriously higher impedance than the typical earbuds
that come with Ipods and other consumer audio devices. Might be an impedance mismatch requiring a matching transformer. "Scott Skylane" wrote in message ... H.P. wrote: The audio output device needs a compression circuit to keep audio levels more near a constant output. There are portable cd players out there that have such a feature. My iPod *does* have an audio compression feature, and it is turned on. Quite simply, the minimum audio signal required to power up the Muse is higher than I would like it to be. Your headset may have a dip switch that's factory set to mono-out a stereo input - like the Bose headset. Try the other setting. Or it may be wired in mono. Try it on a stereo source at home. No switch on my headsets, they're good ol' mono DC's. Knowing that the majority of aviation headsets are mono, PSE incorporated a mini switch inside the Muse, to provide either stereo or mono output. The position of said switch has no discernable effect on the music I hear in my headsets. Happy Flying! Scott Skylane |
R.L. wrote:
Aviation headsets have notoriously higher impedance than the typical earbuds that come with Ipods and other consumer audio devices. Might be an impedance mismatch requiring a matching transformer. Ummm, yeah. And since the Muse is *designed* to input consumer audio devices into aviation headsets, I would expect the built-in circuitry to handle this just fine. IMHO, it does an "O.K" job, but not as good a job as I would like. Happy Flying! Scott Skylane |
FS Aeronautical engineering textbooks for sale | john hawkins | Home Built | 0 | March 26th 05 09:53 PM |
FS Aeronautical engineering textbooks for sale | john hawkins | General Aviation | 0 | March 26th 05 09:53 PM |
Navy enlistment questions | Atcrossroad | Naval Aviation | 53 | September 23rd 04 10:43 AM |
PS Engineering Report | Jeff | Owning | 44 | December 7th 03 11:24 PM |
PS Engineering | Hankal | Owning | 0 | December 5th 03 12:25 AM |
