Alternative to the Battery wows?
Old March 9th 21, 01:12 AM posted to rec.aviation.soaring
Mark Mocho
Default Alternative to the Battery wows?
"water vapor comes and goes with the weather."
Yes, but now we are talking about combusting H2 with O2, which is an entirely new source of H2O vapor.
And, if you want another little problem to solve with the storage and use of hydrogen, look up "Hydrogen Embrittlement."
I'm not saying it won't be feasible, but it isn't by any means a magic panacea.
In his book, "Skunk Works," Ben Rich talks about Lockheed's experiments with producing and storing liquid hydrogen in the 1950's for possible use as a fuel for high flying, Mach 3+ reconnaissance aircraft. The chapter is titled "Blowing Up Burbank." (That should give you a hint.) Their conclusions were that it was terribly inefficient due to the size of the storage vessel needed for acceptable range, it was very dangerous to transport and store and the infrastructure needed to ensure availability around the world would cost more than the rest of the program, including development of the aircraft and training Air Force personnel to handle it. They went with a new fuel (JP-7) and built the A-12, followed by the SR-71.
Old March 9th 21, 01:35 AM posted to rec.aviation.soaring
Moshe Braner
On 3/8/2021 6:10 PM, Mark Mocho wrote:
On Monday, March 8, 2021 at 1:42:45 PM UTC-7, Eric Greenwell wrote:
Mark Mocho wrote on 3/8/2021 11:34 AM:
And I seem to remember hearing that water vapor is more of a "greenhouse gas" than carbon dioxide.
Not so much when it comes to climate change, because as water vapor increases (primarily due to
global warming), it forms more clouds, which reflect the heat, tending to reduce global warming
- all part of a natural cycle that's be going on since the earth began. CO2 does not condense,
and we are adding it to the atmosphere at a far higher rate than natural carbon sinks can
remove it.
However, using hydrogen as an alternative fuel WILL add to the amount of water vapor in the atmosphere. Note the following statement:
"...water vapor is the largest contributor to the Earth’s greenhouse effect...However, water vapor does not control the Earth’s temperature, but is instead controlled by the temperature...If there had been no increase in the amounts of non-condensable greenhouse gases (like carbon dioxide), the amount of water vapor in the atmosphere would not have changed with all other variables remaining the same." (from the American Chemical Society's ACS Climate Science Toolkit)
The key phrase is the last one: "with all other variables remaining the same." Imagine that instead of seeing "normal" contrails behind a high flying airliner, there is a huge plume of water vapor that results from burning hydrogen. That definitely adds to atmospheric water vapor, independent of the natural evaporation/condensation cycle that forms clouds.
Of course, the "Chemtrails" paranoids will get a corresponding boost in popularity.
Naaah, to "make" the hydrogen you'd need to separate it from water.
It's a closed loop. There are many hurdles, but this one is not. Of
course you can separate it from methane (natural gas) instead, but if
you burn the gas directly you get the same water vapor.
I find the subject line of this thread appropriate though, there are too
many "wows" out there but the "vaporware" never materializes.
Old March 9th 21, 03:37 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Mark Mocho wrote on 3/8/2021 5:12 PM:
Yes, a new source, but it doesn't accumulate in the atmosphere, as the additional water vapor
will condense. CO2 does not condense, and lingers for hundreds of years.
Old March 9th 21, 04:23 PM posted to rec.aviation.soaring
Dan Marotta
That's terrific! The energy content in H2 beats anything except nuclear
power, and wouldn't it be great to fly a 72 ton glider around with
unlimited launch and retrieve capability? But one statement in the
article has me perplexed:
"Current hydrogen extraction is highly energy intensive, so ways to
harvest “green hydrogen” using water electrolysis are being explored."
I believe that it takes more energy to extract the hydrogen from water
than is realized by burning the hydrogen. I have no idea of the energy
cost to liquefy and distill hydrogen. Can anybody shed some light on
that? I can see giant smoke stacks spewing sooty black smoke into the
air due to burning coal to generate the electricity to compress the air
to harvest the hydrogen. Well... Maybe not. Perhaps covering Europe
with wind mills to make the electricity and using sailing ships to
deliver the H2 around the world.
Credit to Dr. Seuss and Rube Goldberg for the inspiration.
Dan
5J
On 3/8/21 11:26 AM, AS wrote:
Ran across this short article about an interesting project at the Delft University in The Netherlands:
https://www.yahoo.com/lifestyle/dutc...153606032.html
Uli
AS
Old March 9th 21, 04:46 PM posted to rec.aviation.soaring
John Galloway[_2_]
Dan
5J
Uli
AS
It looks like covering Saudi Arabia with solar panels is the way!
https://tinyurl.com/3kjwd6nf
Old March 9th 21, 06:28 PM posted to rec.aviation.soaring
Moshe Braner
On 3/9/2021 11:23 AM, Dan Marotta wrote:
That's terrific!* The energy content in H2 beats anything except nuclear
unlimited launch and retrieve capability?* But one statement in the
than is realized by burning the hydrogen.* I have no idea of the energy
cost to liquefy and distill hydrogen.* Can anybody shed some light on
that?* I can see giant smoke stacks spewing sooty black smoke into the
to harvest the hydrogen.* Well...* Maybe not.* Perhaps covering Europe
Yeah, the wide-eyed talk about hydrogen being "the most common element
in the universe" is pure nonsense. There are no "hydrogen wells" on our
planet. It's an energy carrier, not an energy source. And it's not a
good energy carrier, since it leaks through everything etc.
You can use natural gas or other fossil fuels to produce hydrogen from
other materials. Or solar. But currently it's mostly natural gas. And
yes it uses more energy to "produce" than you get from burning it. Or
even from using it in fuel cell$. About 4x more, all told, relative to
using electric power directly.
But the "hydrogen economy" rah-rah seems to emerge from the shadows for
another round every decade or so. Then it goes back into the shadows to
keep fusion energy company.
If the issue is what to do with surplus solar or wind energy, in the
(few) times and places where it's available, there are many other ideas,
including the production of liquid fuels which are much more practical
than hydrogen. Methanol and ammonia are some I've heard of. Yes they
are toxic if spilled. So is gasoline. At least you know when there's a
leak.
SeeYou Alternative? Papa3[_2_] Soaring 3 June 18th 18 05:07 PM
100LL alternative [email protected] Soaring 2 May 10th 08 04:54 AM
New $100 Hamburger Web Alternative Jay Honeck Piloting 0 November 3rd 06 01:11 AM
Alternative to IPAQ PDA's marc_dg400 Soaring 5 August 11th 06 04:22 PM
Financing Alternative L Owning 8 October 6th 03 06:14 PM
