On 27 May 2005 23:39:18 -0700, Antoņio wrote:
1.Assuming I busted B; who is reponsible if the controller asks me to follow an aircraft that is too far out on a straight in? I mean, I can reduce speed, s-turn, and the like but I can't turn base until the aircraft on final is a safe distance away, right? Bottom line, it is your fault. If a controller gives you instructions that cause a problem, then you need to speak up and say "cannot comply without clearance into Bravo. See 4-4-13 B at http://www.faa.gov/ATpubs/AIM/Chap4/aim0404.html Look at the note where it says: ....the pilot should promptly notify the controller if visual contact with the other aircraft is lost or cannot be maintained or if the pilot cannot accept the responsibility for the separation for any reason. Note the second half of the paragraph, which would be fitting your situation. 2.Is the controller supposed to arrange things so that I *can* turn base and not be in conflict with other aircraft? See above reference for ATC responsibilities.. 3.How would you resolve the problem if it were happening to you ? I would have requested clearance into Bravo if he had me heading in that direction. I would have slowed my speed down significantly to slow my approach into Bravo. Hope this helps! Allen |
I agree with the other posters the responsibility is yours, not the tower
controllers. If an enforcement action was contemplated, it would work in your favor, but not exonerate you. One thing for certain, file an ASRS! That can stop an enforcement action. See http://asrs.arc.nasa.gov "Antoņio" wrote in message oups.com... Today I flew into KBFI (Boeing field) which is class D and has extentions that underlie the Class B that require close attention to altitudes and headings so as to stay clear. Today the winds were favoring 31L (and 31R) and I came in from the west on the Vashon approach--the most common approach from the west. I was on a left downwind for 31L and the tower told me I was number three following an Arrow on about a 2 mile straight in final (Valley approach?). I acknowledged the traffic, and was waiting for it to come up on my 9 o'clock before turning base so as to allow enough spacing. The controller suddenly told me that I was too far south and said either that I had busted into surface B or was about to. (I never did clearly hear which). Unless one turns a fairly close in base here--within about a half mile or less--you end up in class B surface. My questions: 1.Assuming I busted B; who is reponsible if the controller asks me to follow an aircraft that is too far out on a straight in? I mean, I can reduce speed, s-turn, and the like but I can't turn base until the aircraft on final is a safe distance away, right? 2.Is the controller supposed to arrange things so that I *can* turn base and not be in conflict with other aircraft? 3.How would you resolve the problem if it were happening to you ? Any thoughts would be appreciated... Antonio |
![]() "Antoņio" wrote in message oups.com... Today I flew into KBFI (Boeing field) which is class D and has extentions that underlie the Class B that require close attention to altitudes and headings so as to stay clear. Today the winds were favoring 31L (and 31R) and I came in from the west on the Vashon approach--the most common approach from the west. I was on a left downwind for 31L and the tower told me I was number three following an Arrow on about a 2 mile straight in final (Valley approach?). I acknowledged the traffic, and was waiting for it to come up on my 9 o'clock before turning base so as to allow enough spacing. The controller suddenly told me that I was too far south and said either that I had busted into surface B or was about to. (I never did clearly hear which). Unless one turns a fairly close in base here--within about a half mile or less--you end up in class B surface. My questions: 1.Assuming I busted B; who is reponsible if the controller asks me to follow an aircraft that is too far out on a straight in? I mean, I can reduce speed, s-turn, and the like but I can't turn base until the aircraft on final is a safe distance away, right? 2.Is the controller supposed to arrange things so that I *can* turn base and not be in conflict with other aircraft? 3.How would you resolve the problem if it were happening to you ? Any thoughts would be appreciated... Where were you on the downwind when the Arrow was on a two mile final? I make the RWY 31L threshold to be 0.93 miles from the Class B boundary. Unless you were pretty much abeam the threshold or further south when the instruction was issued there should have been plenty of room to follow and avoid the Class B airspace. You're responsible for any bust. If following the instruction meant entering the Class B airspace I'd respond to it with "verify I'm cleared into Class B airspace." If the controller replies with "Negative" I'd inform him I was turning to avoid Class B airspace. Pilots are required to abide by the FARs regardless of any ATC instruction. |
ink.net... You're responsible for any bust. If following the instruction meant entering the Class B airspace I'd respond to it with "verify I'm cleared into Class B airspace." If the controller replies with "Negative" I'd inform him I was turning to avoid Class B airspace. Pilots are required to abide by the FARs regardless of any ATC instruction. I don't dispute that the FAA takes that position. But the FARs themselves are contradictory on that point. FAR 91.123b requires obeying ATC instructions, except if an emergency requires otherwise. There's no stated exception for non-emergency violations of the regs. If the tower says "Continue downwind, I'll call your base" and then hasn't gotten back to you two minutes later when you're about to enter Class B, and if the frequency is too crowded for you to call, then the only way to avoid busting Class B may be to violate 91.123b. --Gary |
![]() "Gary Drescher" wrote in message ... I don't dispute that the FAA takes that position. But the FARs themselves are contradictory on that point. FAR 91.123b requires obeying ATC instructions, except if an emergency requires otherwise. There's no stated exception for non-emergency violations of the regs. If the tower says "Continue downwind, I'll call your base" and then hasn't gotten back to you two minutes later when you're about to enter Class B, and if the frequency is too crowded for you to call, then the only way to avoid busting Class B may be to violate 91.123b. Given that the FAA tells it's controllers that pilots are required to abide by the FARs regardless of any ATC instruction, who is there to charge you with violating FAR 91.123(b) in this situation? |
ink.net... Given that the FAA tells it's controllers that pilots are required to abide by the FARs regardless of any ATC instruction, who is there to charge you with violating FAR 91.123(b) in this situation? No one, presumably. As I said, I don't dispute that the FAA takes that position. This is just another situation where I wish they'd amend the FARs to say what they mean. --Gary |
![]() "Gary Drescher" wrote in message ... No one, presumably. Exactly. It's not an issue. |
![]() Gary Drescher wrote: "Steven P. McNicoll" wrote in message ink.net... You're responsible for any bust. If following the instruction meant entering the Class B airspace I'd respond to it with "verify I'm cleared into Class B airspace." If the controller replies with "Negative" I'd inform him I was turning to avoid Class B airspace. Pilots are required to abide by the FARs regardless of any ATC instruction. I don't dispute that the FAA takes that position. But the FARs themselves are contradictory on that point. FAR 91.123b requires obeying ATC instructions, except if an emergency requires otherwise. There's no stated exception for non-emergency violations of the regs. If the tower says "Continue downwind, I'll call your base" and then hasn't gotten back to you two minutes later when you're about to enter Class B, and if the frequency is too crowded for you to call, then the only way to avoid busting Class B may be to violate 91.123b. --Gary If frequency conjestion creates a sustained inability to request either a Class B clearance to enter the imminent Class B airspace or a new instruction to avoid the Class B, you have an emergency brewing. An emergency is not limited to the aircraft having a mechanical or similar such problem. Violating Class B airspace has unknown ramifactions, such as perhaps approach control seeing the intrustion and declaring an emergency on your flight because of loss of separation, etc., etc. So, in that light, use of your emergency authority under 91.03 (a) and (b) would be considered appropriate. Having said that, whatever action you have to take to avoid the Class B should be reasonable and prudent so as to not unnecessarily create an unsafe condition for the local controller working your flight. Sometimes, operating in conjested airspace involves juggling several balls at the same time. Operating IFR actually makes it all more straight-forward because the entire concept of Class B operates in favor of IFR operations. When Class B (TCAs) first was proposed in this country there were a lot of advocates that wanted to make that airspace Class A. But, other interests strongly opposed going that far. |
An emergency is not limited to the aircraft having a mechanical or similar such problem. Violating Class B airspace has unknown ramifactions, such as perhaps approach control seeing the intrustion and declaring an emergency on your flight because of loss of separation, etc., etc. It's true that a controller *might*, for additional reasons, deem a Class B incursion to be an emergency. But I doubt that a slight breach of Class B, with good visibility and no conflicting traffic, would *by itself* constitute an emergency. So I don't think 91.3b would necessarily come into play. Again, I don't dispute that you should avoid the incursion, even if you have to violate 91.123b. I just wish the FARs weren't contradictory on that point. --Gary |
with good visibility and no conflicting traffic, would *by itself* constitute an emergency. So I don't think 91.3b would necessarily come into play. An emergency is whatever the PIC deems it to be at the time. So, ok, you're on the ground, they have paperwork for you, and it ends up in a faceoff between you and the FAA. The controller says "You disobeyed my order. Fie on you." You say "You ordered me to violate the law, creating an unsafe condition. Fie on you." The controller says "By turning early, you created an unsafe condition." You say "By turning early, I created an inconvenience for you, and I was on your frequency. By not turning early, I'd create an inconvenience for an unknown entity with whom I was not in communication." My guess is that the FAA would side with you turning to avoid the class B. Jose -- The price of freedom is... well... freedom. for Email, make the obvious change in the address. |
Carrying flight gear on the airlines | Peter MacPherson | Piloting | 20 | November 25th 04 12:29 AM |
World Class: Recent Great News | Charles Yeates | Soaring | 58 | March 19th 04 06:58 PM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
One Design viability? | Stewart Kissel | Soaring | 41 | December 10th 03 03:27 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
