padding in Cobra trailer
Old April 26th 21, 02:10 AM posted to rec.aviation.soaring
BobWa43
Default padding in Cobra trailer
The carpet in my Cobra trailer is shedding badly. I would like to replace or cover it. Open to any ideas on how to remove the old carpet or can you just put some new material on top of the old? What material would be best? Soft felt, hard felt, carpet?
Old April 26th 21, 07:30 AM posted to rec.aviation.soaring
John Sinclair[_5_]
The padding’s I have seen have a rubbery under-service that deaerates . I removed everything with a wire brush and acetone. Wings & Wheels has replacement material in red or blue.
JJ
Old April 26th 21, 04:42 PM posted to rec.aviation.soaring
jfitch
Under no circumstances would I replace the Cobra carpet/padding with the same material. It is a great deal of work to remove the adhesive sheet they use, and the material self destructs on a regular time table. There are better materials available that will last much longer.
JJ
Old April 26th 21, 05:12 PM posted to rec.aviation.soaring
John Sinclair[_5_]
It’s not the same material! Spindleburger (owner of Cobra Trailers), continually evaluates every aspect of his product and frequently makes changes. New fabric without the padding is just the latest example of a company that really tries to improve their product.
JJ
Old April 26th 21, 07:59 PM posted to rec.aviation.soaring
Jason Leonard
I've been using closed cell neoprene sheets with decent success. Its more grabby but it can be cleaned, and won't scuff. It grabs, but it doesn't scuff or hold dirt that will scratch like carpet or felt. It also has a nice give to it that does protect.
Old April 27th 21, 12:18 AM posted to rec.aviation.soaring
Guy Acheson[_2_]
This is a great question that all Cobra owners will have to face.
I have two trailers and replaced the original carpet about five years ago with indoor/outdoor carpet that I put in place with rubber cement.
The hardest part is removing the crumbly foam rubber backing on the original padding. Aweful product.
My second trailer has the padding starting to fall off.
So...JJ...is there a heavy felt product or carpet that has self adhesive backing appropriate for this use?
Old May 5th 21, 11:24 PM posted to rec.aviation.soaring
Darren Braun
The carpet generally comes off surprisingly easy, I found. That's the best property of the original carpet. But it makes a powdery mess as you do so wear mask and probably gloves...
What is left behind is a bit of a sticky that I didn't care to remove. Instead I used loctite spray adhesive and a basic low pile outdoor carpet as the replacement. You will want to save the old pieces to use as a template.
Darren
Old May 6th 21, 03:04 AM posted to rec.aviation.soaring
Mark Mocho
Adhesive carpet tiles. Cut to fit. You also can work with one at a time rather than wrestling with a large piece of carpet. Pick tiles with either no padding or something other than the foam on Cobra carpet, which disintegrates in a dry climate.
https://www.google.com/shopping/prod...Q_dDasQ9pwGCAY
Cobra Trailer VIN MSC Soaring 3 July 1st 18 07:05 PM
New Cobra trailer - - which top? Ben[_6_] Soaring 34 February 19th 15 09:43 PM
2013 Cobra trailer price list needed for TA trailer sale [email protected] Soaring 0 June 22nd 13 02:42 PM
Cheap Cobra Trailer Lights 1998 Trailer on E-bay USA ONLY! flyingmr2 Soaring 4 November 16th 10 02:11 AM
Cobra Trailer [email protected] Soaring 22 December 7th 06 11:38 PM
