TBO and Overhaul Costs
Old May 30th 05, 07:15 PM
A. Smith
"O. Sami Saydjari" wrote in message
Is there a website I can go to find out the TBO and overhaul costs of any
given engine? Right now, I am curious bout the GTSIO-520-L on a Cessna
421C.
-Sami
N2057M
The TCM GTSIO-520-L as overhauled by any reputable overhauler or as a
factory reman has a 1,600 hour TBO. The later Cessna 421C models (those
with trailing link landing gear) had GTSIO-520-N engines, similiar to the -L
but with a different fuel system. They are a little more expensive to
overhaul for that reason.
The Cessna 421B (tip tank model) has the GTSIO-520-H engine. Early ones had
a 1,400 hour TBO, later ones with better cylinders have a 1,600 hour TBO.
All the Cessna 421's are rated at 375 HP/engine.
Allen
Old May 31st 05, 01:55 AM
Mike Rapoport
Michelle,
Yes, I checked. After they stopped laughing, they gave me an outrageous
quote. My plan is to get my multiengine rating within the next month and
build some multiengine time before my purchase. I know this is not an
easy path.
-Sami
You should plan on not being able to insure the hull. It is exceedingly
unlikely that you will fly enough hours in a rented twin to get insurance in
a big pressurized one. What was the quote that they gave you and what
were the requirements?
MU-2
Old May 31st 05, 05:00 AM
Montblack
("A. Smith" wrote)
the -L but with a different fuel system. They are a little more expensive
to overhaul for that reason.
G-T-S?
Montblack
Old May 31st 05, 02:23 PM
Allen
"Montblack" wrote in message
("A. Smith" wrote)
expensive to overhaul for that reason.
G-T-S?
Geared-Turbo-Supercharged, The crankshaft turns at 3,350 RPM at take-off
while the propeller turns 2,235 RPM.
Allen
Old May 31st 05, 02:36 PM
Darrel Toepfer
Montblack wrote:
("A. Smith" wrote)
The TCM GTSIO-520-L
G-T-S?
Geared - Turbocharged - S (Case type I think) - Injected - Opposed
http://tcmlink.com/EngSpecSheetDocs/GTSIO520L.pdf
http://tcmlink.com/EngSpecSheetDocs/GTSIO520L.doc
Old June 7th 05, 02:33 PM
Paul kgyy
Sami, if you're thinking of upgrading to a twin, take a look at Mike
Busch's article on Annual Inspections in this week's Avweb.
