Gasahol Update
Old May 31st 05, 03:37 PM
Sport Pilot
Doug wrote:
There is a whole new line of excellent plastic floats called Aerocets.
Although I don't know how that is relevant.
Because the toulene in 100LL melted the plastic floats in many carbs.
Big STC to replace them about two decades ago.
One thing about mogas, it is best to get the mogas that airports have
.They typically get car gas that does not have the car gas additives.
Total BS, most FBO's that sell mo gas are either small mom and pop
operations that do not have a very large tank to ask the local
distributer to eliminate the aditive package, or they only offer it
because they are also using it for their ground equipment. Besides the
additives are only detergents which would only help to get rid of
carbon and lead deposits. The alcohol is added at the refienery not
the distributer.
No one really knows what these car gas additives will do to an aircraft
engine. Also, keep in mind car gas is NO LEAD. Lead has lubrication and
cushioning properties. BS! A myth created by the gas companies to discorage the government from eliminating lead, and an excuse for car companies to explain their valve failures. Aircraft engines are tested for compatibility before issuing the STC. My old Cessna had less problems on mogas than 100LL. No stuck valves on mogas.
Old May 31st 05, 04:31 PM
Doug
Well it is not TOTAL BS. I know for a fact that one mogas seller in
Colorado (where I get mine), gets his mogas the way I described. But
you bring up a good point. How does one tell just what you are getting
when you put in mogas or avgas?
Old May 31st 05, 04:34 PM
George Patterson
Denny wrote:
Jim,
Those recommendations are based on the alcohol being wood alcohol -
No. The EAA states this "Ethanol is often confused with methanol. These two
alcohols have distinctly different characteristics; however, all STC's prohibit
the use of gasoline containing alcohol - either methanol or ethanol." Those
recommendations occur later on that page and apply to either ethanol or methanol.
http://www.eaa.org/education/fuel/oxygenated.html
George Patterson
Why do men's hearts beat faster, knees get weak, throats become dry,
and they think irrationally when a woman wears leather clothing?
Because she smells like a new truck.
Old May 31st 05, 05:09 PM
Jay Honeck
But
If there are no visible contaminants, there is no water evident, and it
smells like gasoline, I run with it -- and unless you have some sort of
a chemical laboratory in your hangar, there's not much else you can do.
Like so many other things in this world, it's really not worth the
effort to worry about.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old May 31st 05, 05:27 PM
Corky Scott
On 31 May 2005 09:09:03 -0700, "Jay Honeck"
Thought there was some kind of easy test you could do by adding water
to a sample of your fuel.
Corky Scott
Old May 31st 05, 05:40 PM
Newps
Jay Honeck wrote:
But
Me too. If it smells like it might burn I'll use it.
Old May 31st 05, 07:17 PM
Sport Pilot
There is. Water and gas don't mix. Water and alcohol do.
Run to trash, find empty clear bottle (typically a water
bottle), scratch mark at about 10% point near bottom, fill
with water to that point, add gas, shake, let settle, see if
the water level is higher. If it is, alcohol has moved from
the gas to the water.
Do not spin this aircraft. If the aircraft does enter a spin it will return to earth without further attention on the part of the aeronaut.
(first handbook issued with the Curtis-Wright flyer)
You got that backward, if the alcohol is present the water level will
drop, not rise.
Old May 31st 05, 07:46 PM
Ron Natalie
drop, not rise.
Nope, it will rise. The alchohol which had been mixed with the gas
will now disolve in the water, the water level will rise.
Old May 31st 05, 10:23 PM
George Patterson
drop, not rise.
No, he got it exactly right. The alcohol will come out of solution with the
gasoline and mix with the water. The effect is that it appears that the water
level rises.
http://www.eaa.org/education/fuel/knopp_alcohol.html
George Patterson
Old May 31st 05, 10:33 PM
mike regish
There is. You can get a graduated tube from eaa or make one yourself. You
add water to the lower line, gas to the upper line and shake for 30 seconds.
After the water settles down to the bottom, you check to see if the line is
in the same place. If it's higher, you have alcohol. The EAA tube will tell
you the precentage.
mike regish
"Corky Scott" wrote in message
Corky Scott
Garmin GPS196 Update v.4 - obstacles? [email protected] Piloting 13 March 16th 05 06:05 PM
GPS_LOG WinCE update (version 1.2.2.1) Henryk Birecki Soaring 0 January 14th 05 05:27 PM
AD: December 2004 update for London Control now available ShelleyM Simulators 0 December 15th 04 01:12 PM
Anyone know how to update an old Loran database? Tom Jackson Owning 12 December 5th 03 06:03 PM
Anyone know how to update an old Loran database? Tom Jackson Piloting 6 December 3rd 03 02:15 AM
