Ventus A and B Wing Root Fairings
Old June 7th 05, 03:55 PM
Look in the June issue of Soaring for 2 photos of the Ventus A wing
root fairings.
Fairings should about equally benefit the Nimbus 2, but that wing is
thicker, and I do not know if anyone has developed fairings for it.
Dick Johnson
Old June 7th 05, 04:45 PM
ttaylor at cc.usu.edu
I found an image on Jim Phoenix's site of the fairing.
http://www.jimphoenix.com/jimphoenix...Nfuselage.html
Also the last issue of Soaring Magazine has a good picture from the
rear of Dick's Ventus with the wings on so you can see the flaps.
Old June 8th 05, 02:14 AM
Bob Korves
"JJ Sinclair" wrote in
oups.com:
I could
play a tune with my Nimbus when just moving the flaps up and
down----Weeeee-----wooooo----wrrrrr-----weeeee.
Hey JJ, my PIK-20d played the same tune. Were they in the same band?
-Bob Korves
Old June 8th 05, 06:58 AM
Dick,
I looked at my Ventus tonight and I see that the flap drive is about
two inches inboard from the end of the flap, but about four inches will
need to be cut off. How did you deal with the flap connection hardware
when you trimmed the flaps? At the upper (connection) end of the flap
is there enough room that you do have to change anything?
Tim
Old June 8th 05, 04:34 PM
Hi Tim,
No hardware needs to be changed to install the wing root fairings,
and shortening the flap roots is easy.
Dick Johnson
Old June 9th 05, 11:32 PM
I stll have the moulds for the fairing kit for Ventus B.
If anyone would like to cover my costs ($1200) on them I would be happy
to part with them.
Regards
Al
Wing tip stalls mat Redsell Soaring 5 March 13th 04 05:07 PM
Wing root fairings D.A.L Soaring 10 October 29th 03 11:36 AM
wing root strakes (not canard A/C) Wallace Berry Home Built 0 October 2nd 03 08:47 PM
Props and Wing Warping... was soaring vs. flaping Wright1902Glider Home Built 0 September 29th 03 03:40 PM
An Affordable Homebrue 60 in DS machine Grant Soaring 0 August 8th 03 03:52 AM
