How come GPS reads different
Old June 12th 05, 02:35 PM
Blueskies
"Matt Whiting" wrote in message ...
Not that unusual. GPS isn't very accurate vertically. Most GPS manuals tell you not to rely on the altitude in any
serious way.
Matt
Unless the GPS is WAAS capable?
Old June 12th 05, 02:49 PM
Dan Luke
manuals tell you not to rely on the altitude in any serious way.
It's usually more accurate than the altimeter, which is not corrected
for non-standard temperature.
Dan
C172RG at BFM
Old June 12th 05, 09:23 PM
Matt Whiting
That's not what my KLN89B manual says...
Matt
Old June 13th 05, 05:59 PM
Ross Richardson
Aluckyguess wrote:
I am getting over 500ft. difference and more.
Aluckyguess wrote:
How come the GPS reads a different altitude than the Altimeter?
For many reasons. The main reason is that they derive altitude by two
completely different methods and this inevitably introduces errors. Then
each method has its own inherent errors.
Even two altimeters side by side won't read the same altitude other than
by accident.
Matt
GPS altitude is not accurate. That is why you need to have a baro sensor
included as input to a IFR approved GPS.
Regards, Ross
C-172F 180HP
KSWI
Old June 13th 05, 06:45 PM
Frank Ch. Eigler
.... except when it is, which is most of the time.
That is why you need to have a baro sensor included as input to a
IFR approved GPS.
That baro input is used as a cross-check for gross errors, to assist
RAIM. It does not "correct" inaccuracy, and thus is irrelevant to the
normal GPS altitude readout.
- FChE
Old June 12th 05, 04:01 PM
Thomas Borchert
Aluckyguess,
Main reason: Altimeter indication is corrected for barometric pressure.
First order of business before comparing is to set the altimeter to
29.92. Even then, 500 feet off is not unusual IF the GPS is not WAAS
capable.
Thomas Borchert (EDDH)
Old June 12th 05, 06:17 PM
Peter Duniho
"Thomas Borchert" wrote in message
29.92.
No. As Dan points out elsewhere, the main error in the barometer is not
correcting for non-standard temperature. There are other errors as well,
but none of them involve setting the altimeter to 29.92 in an attempt to
make the altimeter more accurate. Unless the correct altimeter setting is
actually 29.92, setting it to 29.92 will simply make the error worse.
Pete
Old June 12th 05, 06:56 PM
Thomas Borchert
Peter,
Uh, yes. Brainfart on my side. Sorry
Old June 12th 05, 04:14 PM
Jim Fisher
"Aluckyguess" wrote in message
Altimeters are calibrated for local barometric pressure. GPS altitude based
on a computed, simulated sphere that approximates sea level.
If the Earth suddenly disappeared (as happened in Hitchhikers Guide to the
Galaxy) and you happened to be flying at that moment, your GPS would
continue to happily display an altitude even though there was no actual
Earth underneath you.
So, for safety reasons, I think we should all use GPS altitude so that we
can all safely land if the Earth ever actually disappears.
I've always been curious about something: The Earth is not a perfect
sphere. It bulges at the equator due to forces of tidal gravitation and
centrifugal force. My question is, do GPS altitude computations take this
into effect when you're, for example, flying over the equator instead of
over the north pole?
Jim Fisher
Old June 12th 05, 04:44 PM
Tauno Voipio
Jim Fisher
Yes - it's called the reference ellipsoid. There are actually
several of them and some GPS receivers allow selecting your
favourite one.
Actually, if Earth would disppear with all its mass, GPS would
get unusable, as the satellites would continue out of their
tracks due to the lack of gravity pull.
Tauno Voipio
tauno voipio (at) iki fi
GREAT AVIATION READS Cribsheet Piloting 1 September 12th 04 02:51 AM
GREAT AVIATION READS Cribsheet Rotorcraft 0 September 10th 04 06:06 PM
GREAT AVIATION READS Cribsheet Military Aviation 0 September 7th 04 06:37 PM
When the ASI Reads Below Zero BTIZ Piloting 11 August 23rd 04 04:57 PM
Newsweek Reads RAM! Bob McKellar Military Aviation 0 February 17th 04 02:10 AM
