#11
In article .com, Ben Hallert wrote:
Followup question, while doing this to get the current data is its own rewards, I wonder if there would be any implications for IFR-worthiness? I imagine it depends on what the POH supplement says about where the data can come from. I'm guessing it would invalidate the IFR-ness. I certainly would be hesitant to fly hard IFR behind data I reverse engineered, then generated myself. But the panel-mount in question is VFR-only anyway. Tina Marie -- http://www.tripacerdriver.com "...One of the main causes of the fall of the Roman Empire was that, lacking zero, they had no way to indicate successful termination of their C programs." (Robert Firth) |
On Tue, 14 Jun 2005 09:45:13 -0500, Tina Marie
wrote: In article , Ben Jackson wrote: Since you clarified you meant "PC card", then yes. The easiest way is going to be to get a laptop, boot linux (could be from CD) and insert the card. It will almost certainly recognize it as a storage card. Then you have to figure out what's stored on it. Might be a filesystem (likely FAT16) or it might be flat data. Hm. My laptop runs XP, but I saw a floppy-drive-like-device that lets you plug a PC card into a desktoy which I could put in my linux machine to try it. If it's FAT16, the XP box might be able to see it. I'll try that first, if it doesn't work, I'll go buy the hardware for my linux box. I wouldn't do that if I were you. Micro$oft operating system have a nasty habit of "fixing" the crucial areas that it THINKS are not right. I've got two drives here with a total of 110GIG of data that Winblows has made inaccessable. On one, it started creating additional File Allocation Tables until nothing was recognizable any more. The other, it rewrote the LBA mapping file and everything is gone -- poof! Use the Linux system. At least, it won't try to modify anything when you try to mount the removable drive. If it can't mount it -- it will just error instead of trying to "fix" it. And you can always tell Linux "mount -ro /dev/DEVICE". That way, its mounted read-only and you're sure of not messing up your only data source. Chuck |
On 2005-06-14, Tina Marie wrote:
Hm. My laptop runs XP In which case use Knoppix 2.9 (http://www.knoppix.org). It's a complete Linux system that runs off a CD and doesn't need installing. The latest version even happily uses some of the more exotic bleeding edge hardware we have floating around here. -- Dylan Smith, Castletown, Isle of Man Flying: http://www.dylansmith.net Frontier Elite Universe: http://www.alioth.net "Maintain thine airspeed, lest the ground come up and smite thee" |
![]() I always bump into memory limitations, I think that is the reason for no more Airmap 100 updates. New databases wont fit anymore... Michael Nickolas www.studionineproductions.com |
Michael Nickolas wrote:
I always bump into memory limitations, I think that is the reason for no more Airmap 100 updates. New databases wont fit anymore... If you could select your "POI"s then that might not be an issue. ie. remove VOR/NDB/ILS/Obstruction/Seaplane waypoints to keep an uptodate airport reference. This is all easily done with the Magellans upload software. The GPS might not be as useful, but still useable... |
AOPA VISA card fraud via XM Radio? | Dan Luke | Piloting | 5 | July 5th 04 06:38 PM |
Graphics | Jim Chambers | Simulators | 14 | April 22nd 04 03:29 AM |
Gasp-- On Topic RAM question! | Charles Gray | Military Aviation | 10 | December 28th 03 05:53 PM |
On topic: A-Bomb necessary? A different approach? | old hoodoo | Military Aviation | 24 | December 24th 03 08:58 PM |
Off topic question - Are you receiving viruses? | Mike Williams | Rotorcraft | 8 | September 27th 03 04:14 AM |
