Wolfgang Kemper wrote in news:d8mpdd$ent$1
@home.itg.ti.com: John Galban wrote: Bucky wrote: For example, the top speed of a car could be 120 mph, but it would be dangerous to drive it at that speed because a sudden movement in the steering wheel could cause the car to flip over. This can happen at 75 mph or at 50 mph. What's so magic about 120 mph? If you're point is that driving a car is dangerous, I agree. If you're trying to make some analogous connection to flying a plane at it's service ceiling, you missed the boat (car, plane...). John Galban=====N4BQ (PA28-180) Little notice from a German "Autobahn" driver: I had a Alfa Romeo where I felt very comfortable even with 150 mph and I had a Jaguar where 120mph was nice but at 150mph I had the impression to became instable. I pushed a Chevy Blazer to 100 mph and was afraid to kill myself. Everything is relative , some dudes manage to flip over at 30mph , I have seen this last December here in Dallas, and with the right car and environment even 200 mph are safe. Sorry way OT. I agree. It all depends on the vehicle, the driver, and probably more importantly, the road conditions. I have a Harley Sportster ('86 883) and I've pushed it over the century mark. On a good clean road it's rock solid. Then again, I've been nearly dumped by a railroad crossing in bad shape at only 30mph. Damn near jolted the handle bars out of my hands. Brian -- http://www.skywise711.com - Lasers, Seismology, Astronomy, Skepticism Seismic FAQ: http://www.skywise711.com/SeismicFAQ/SeismicFAQ.html Blog: http://www.skywise711.com/Blog Sed quis custodiet ipsos Custodes? |
"Bucky" wrote in message
oups.com... I'm not blaming the pilots. I just want to find out if flying a plane at its maxmimum operating altitude is standard practice, or if it's considered dangerous. It's not considered dangerous. For example, the top speed of a car could be 120 mph, but it would be dangerous to drive it at that speed because a sudden movement in the steering wheel could cause the car to flip over. A sudden movement in the steering wheel could cause the car to flip over at 60 mph, depending on the nature of the movement (which would be true at 120 mph as well). Likewise, an airplane can be crashed from practically any altitude or airspeed. Even with your reference, it's not clear what is meant by "maximum altitude", but assuming that marketing document is referring to the certified ceiling of the aircraft (as described on the type certificate), the aircraft should be expected to fly safely all the way up to, and including, that altitude. This would include expecting the engine design to tolerate operation at that altitude, without stoppage. I can see no justification for expecting the pilots to limit themselves to a lower altitude. The CVR may indicate a less-than-professional approach to their flying (one normally selects a cruise altitude for reasons other than entertainment, for example ![]() anything wrong operationally. Of course the article says nothing about whether they stopped at 41,000'. It sure sounds as though they got to FL410, and then just cruised at that altitude. But if they had tried to climb higher, that might have presented a problem. Until there's evidence they did so, however, the "head of the Air Travelers Association" has no basis for his comments. All experimentation had presumably been done previously, during the certification of the airplane. All the pilots were doing is operating the airplane within the limits determined during certification. It will be interesting to see what the ultimate determination of the engine failures is. It could be one of at least three causes, including: * Pilots exceeded certified ceiling (ie they didn't stop climbing at 41,000') * Poor maintenance resulted in engines that no longer performed to certified standards * Erroneous or (even worse) fraudulent data used during certification resulting in an aircraft that had never actually been tested at the designed and certified ceiling of 41,000' It may turn out to be something else entirely. Perhaps when the final NTSB report is released, information along those lines will be provided. Until then, I think it's premature for anyone to be criticizing any party, the pilots or otherwise, for any liability in the accident. It could even turn out that, in the end, it was all just an accident. Pete |
Maximum altitude is usually based on pressure differential...the difference
between ambient pressure outside the aircraft vs cabin pressure...the engines don't come into the equation. I have had a Lear 23 up to FL43, which is/was its maximum altitude. The Lear's manual contained a restart envelope, just in case one or both engines failed...it involved gliding down to at least 12000 feet before a restart was attempted (the atmosphere must contain enough oxygen to support combustion). Bob Gardner "Bucky" wrote in message oups.com... http://news.yahoo.com/s/ap/plane_crash_investigation I think this was reported a month ago as well, but there was another round of news releases today stating that the pilots took their Bombardier CJR200 to its maximum altitude of 41,000 ft. Afterwards, both engines failed and they crashed before reaching an airport. Of course, the pilots should not have experimented around, but is it dangerous to take a plane to its max altitude? When the engineers specify a maximum altitude, doesn't it still have to be safe at that altitude? |
Bob Gardner wrote:
Maximum altitude is usually based on pressure differential...the difference between ambient pressure outside the aircraft vs cabin pressure...the engines don't come into the equation. So you're saying that the engines could operate at an even higher altitude. It's just that the cabin pressure could not be maintained? |
No. A pressurized airplane is like a balloon....more pressure inside than
out. If the pressure differential overcomes all of the safety features meant to avoid such a disaster, there would be a blowout at the weakest point...maybe a window, maybe a door seal, who knows? OTOH, if "cabin pressure could not be maintained" means an explosive decompression to you, then your statement would be correct. What it would take to keep the fire burning in the engines is something else again...there has to be a point at which combustion fails. Obviously, the two fun-seekers lost their engines. Neither you nor I know why. I can't understand the restart problem, though. An aspect of max altitude that has not been mentioned here is the "coffin corner" where Mach buffet and stall speed come together. Nothing to do with engine failure, but a consideration when flying high. Bob Gardner "Bucky" wrote in message oups.com... Bob Gardner wrote: Maximum altitude is usually based on pressure differential...the difference between ambient pressure outside the aircraft vs cabin pressure...the engines don't come into the equation. So you're saying that the engines could operate at an even higher altitude. It's just that the cabin pressure could not be maintained? |
"Bob Gardner" wrote
An aspect of max altitude that has not been mentioned here is the "coffin corner" where Mach buffet and stall speed come together. Nothing to do with engine failure, but a consideration when flying high. True..and "coffin corner" is weight dependant. The 41,000' limit for the B-707 was determined by the time required to execute an emergency descent to 14,000'. Bob Moore |
oups.com... So you're saying that the engines could operate at an even higher altitude. It's just that the cabin pressure could not be maintained? It really just depends on the aircraft. Every airplane has a variety of limits with respect to their operation. For many of those limits, there are actually a variety of potential limiting factors resulting in those limits, with usually only one being the *actual* limiting factor. For a pressurized aircraft, the certified ceiling could be due to the pressurization system or due to some engine limitations, or due to something else entirely (like stall speed, for example, where "stall" refers to an aerodynamic limitation having nothing to do with the engines). You'd have to consult the aircraft designer to learn which it was. Pete |
I have been in one on my old employers CRJ-200s at 41000 feet and I can
tell you they fly fine. We we repositioning and want to get home. I un-fortunately was riding in the jump seat and not the left seat. :-( Michelle Bucky wrote: http://news.yahoo.com/s/ap/plane_crash_investigation I think this was reported a month ago as well, but there was another round of news releases today stating that the pilots took their Bombardier CJR200 to its maximum altitude of 41,000 ft. Afterwards, both engines failed and they crashed before reaching an airport. Of course, the pilots should not have experimented around, but is it dangerous to take a plane to its max altitude? When the engineers specify a maximum altitude, doesn't it still have to be safe at that altitude? |
![]() "Bucky" wrote in message oups.com... http://news.yahoo.com/s/ap/plane_crash_investigation I think this was reported a month ago as well, but there was another round of news releases today stating that the pilots took their Bombardier CJR200 to its maximum altitude of 41,000 ft. Afterwards, both engines failed and they crashed before reaching an airport. Of course, the pilots should not have experimented around, but is it dangerous to take a plane to its max altitude? When the engineers specify a maximum altitude, doesn't it still have to be safe at that altitude? When an aircraft's operating limitats are established, the idea is that you should be able to safely operate the aircraft within those limitations. Exceed the limitats beyond a certain safety factor, and bad things may happen. The question I have not seen answered is whether 41,000' is outside the normal operating limits for the aircraft, particularly for its engines. If so, these guys were playing test pilot, if not, there was nothing wrong, foolish, dangerous, careless, or irresponsible with taking the aircraft to that altitude. KB |
![]() "Kyle Boatright" wrote in message ... "Bucky" wrote in message oups.com... http://news.yahoo.com/s/ap/plane_crash_investigation I think this was reported a month ago as well, but there was another round of news releases today stating that the pilots took their Bombardier CJR200 to its maximum altitude of 41,000 ft. Afterwards, both engines failed and they crashed before reaching an airport. Of course, the pilots should not have experimented around, but is it dangerous to take a plane to its max altitude? When the engineers specify a maximum altitude, doesn't it still have to be safe at that altitude? When an aircraft's operating limitats are established, the idea is that you should be able to safely operate the aircraft within those limitations. Exceed the limitats beyond a certain safety factor, and bad things may happen. The question I have not seen answered is whether 41,000' is outside the normal operating limits for the aircraft, particularly for its engines. If so, these guys were playing test pilot, if not, there was nothing wrong, foolish, dangerous, careless, or irresponsible with taking the aircraft to that altitude. KB My apologies. I made a too-quick correction and changed limitations to limitats, instead of limits... |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
Palo Alto airport, potential long-term problems... | [email protected] | Piloting | 7 | June 6th 05 11:32 PM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | November 1st 03 06:27 AM |
rec.aviation.aerobatics FAQ | Dr. Guenther Eichhorn | Aerobatics | 0 | October 1st 03 07:27 AM |
Where to soar near Jefferson City - Missouri? | Peter | Soaring | 2 | September 15th 03 03:29 PM |
