Monitoring Oxygen Uptake
Old June 15th 05, 05:13 PM
Eric Greenwell
Bill Daniels wrote:
"soarski" wrote in message
On the other Hand ........I live and take off at 8000 ft. now also
going on OX at 14000 ft, used to fly without, at higher altitudes. The
Rules, 12500 and 14000 ft are a good measure and most likely have some
margin built in.
As near as I can determine, these altitudes were determined during WWII
using very fit 18 year olds. Out of shape geezers should lower them
considerably. Being in the later category, I set the EDS to start O2 flow
at ground level especially with difficult to handle expensive gliders. With
the EDS consumption isn't a problem.
I recently got an oximeter, and was surprised to see my saturation drop
to 90 and lower above 11,000'. I now set my EDS for ground level
actuation, and put it on at 10,000'. Even with that, it will stay in the
93-94% range, unless I breathe a little more deeply than I tend to. That
will push it up to 97-98%. Oxygen is cheap, and very little is used in
the 10K to 12K range anyway.
Eric Greenwell
Washington State
USA
Old June 16th 05, 06:38 AM
Andy Blackburn
At 03:12 14 June 2005, Kilo Charlie wrote:
The only way to assure yourself of adequate oxygen
delivery to your body is
to use a pulse oximeter as OC has pointed out.
I highly recommend a pulse oximeter. I wore one in
the wave last week to check out my EDS system. I had
the EDS set to the standard O2 delivery starting at
10k. At 18k I put on the oximeter - it read 79% under
normal nasal breathing. With accelerated breathing
I could get it up to 89%.
This week I tried the F15 setting (extra O2 volume).
I went from 84% to 92% in about a minute at 16k.
Under none of these flights did I notice anything unusual
in my perceptions or performance - but then again you're
not supposed to.
9B
$200 pulse oximeter for monitoring your oxygen saturation Eric Greenwell Soaring 32 November 12th 04 03:03 PM
What's minimum safe O2 level? PaulH Piloting 29 November 9th 04 07:35 PM
Reprise - Oxygen concerns Neptune Soaring 20 May 27th 04 03:27 PM
Need oxygen information Neptune Soaring 3 May 10th 04 06:06 AM
Catastrophic Decompression; Small Place Solo Aviation Piloting 193 January 13th 04 08:52 PM
