Nimbus 4DT accident 31 July 2000 in Spain.
Old June 21st 05, 02:13 PM
Bill Daniels
None of these big gliders are very good at diving. I don't believe there
is anything sinister about the N4DM. They're just not built for diving.
Any time the nose is well below the horizon, they will pick up speed
rapidly. Don't do that.
Large span gliders will fly slowly and that means that there is a large
airspeed difference across their span when circling - my "little" Nimbus 2C
can develop a 15 knot difference. This, plus a thermal gust, can make them
roll into a spiral dive.
Recognizing this and taking prompt action when it happens is actually easy
once you experience it a few times. Just allow the speed to increase a bit
to increase control authority, then stop the turn and then recover normal
airspeed.
If the glider is allowed to progress into a full spiral dive, the options
narrow considerably. Only very gentle and precise control inputs will save
the day. Try not to apply large aileron and elevator inputs
simultaneously - bending and twisting the wing at the same time can break
it.
Reading the Spanish report made it seem that the pilot did not have complete
control of his glider. That's a shame when it's a two seater and there are
a lot of experienced pilots who would have been willing to ride with him and
help him master it.
Bill Daniels
"HL Falbaum" wrote in message
Yes, indeed. If anything, the spiral dive recovery is more critical from a
structural standpoint. A modern glider is more likely to progress to
spiral
dive anyway. The pilot, by his own admission, did the wrong recovery for
either case.
However, since the Spanish report refers heavily to the Minden report,
with
many similarities, I wonder if there is something peculiar about the
Nimbus
4 DT. Both apparently departed into a stall and incipient spin in a strong
thermal. This pilot had sufficient recent flight experience, and total
time,
to have developed good "survival" reflexes, including the "stick forward"
manuver. He had little time in the Nimbus 4, but quite enough in the
Nimbus
3 to know how to fly it.
If it was purely the fault of very strong thermals, then the other gliders
in common use at places like Minden would also have similar accidents.
This
does not seem to be the case.
Obviously, I have never flown a Nimbus of any kind. I have a few hours in
the Duo-Discus, but nothing larger. The Duo is certainly not malignant in
any way.
So my question is to those with Nimbus D experience. Is there some
handling
characteristic that will bite a fairly experinced and competent, but
unsuspecting pilot?
I am thinking that the (biennial USA) Flight Review should include spiral
dive recovery routinely, in addition to the usual other "emergency"
maneuvers.
Hartley Falbaum
CFIG USA
"Stefan" wrote in message
W.J. (Bill) Dean (U.K.). wrote:
The Spanish report in English translation may be found at
http://www.gliding.co.uk/accidents/r...s4dtreport.pdf (3MB).
Thanks for the link. Very educational, indeed. I think this answers the
question whether spins and spiral dives should be demonstrated and
recovery should be regularly trained.
Stefan
Old June 21st 05, 02:39 PM
Don Johnstone
At 13:24 21 June 2005, Stefan wrote:
Don Johnstone wrote:
It is to be
hoped that some of the above passage is the result
of iffy translation, if not it is a very strange sequence
of events.
Perfectly correct translation. No strange sequence
at all.
The report conclusions do not help. I am no expert
Yes, they do. Know your airplane, know the emergency
procedures and
particlarly know its behaviour in regading to spins.
Practice spin
recoveries, practice spiral dive recoveries. And any
pilot who is even
tempted to pull back the stick in a spin is not airworthy.
I agree entirely. But was this glider ever spinning?
The report does make the point that intentional spinning
of the 4DM is prohibited.
on the 4DM but is it possible to exceed VNe in a spin?
Certainly not. But many gliders will not stay in the
spin but go into a
spiral dive. Which was obviously the case here.
I don't see that as obvious. How did it get from spin
to spiral dive. The action taken by the pilot would
not have prevented the auto-rotation, in fact it should
have ensured that it continued and that the glider
remained stalled. Stall plus autorotation =spin.
The question is was the glider ever in a spin. Reading
Bill's post that is a pertinent question? My point
about the conclusions not helping is that they say
that the structural failure was from a 'spiral dive
OR spin'. I have to accept that the recovery action
taken by the pilot was incorrect but what was he trying
to recover from?
Stefan
Old June 21st 05, 03:06 PM
Stefan
"Meanwhile, the glider quickly gathered speed until it exceeded Vne."
(Page 2 of the report.)
to spiral dive.
By itself. Just as many gliders do.
I don't know (I'm tempted to say: nobody does) whether the glider was
technically ever in a spin or started right into the spiral dive. The
question is pretty pointless, pulling back the stick is a bad move in
either case.
Stefan
Old June 21st 05, 05:25 PM
M B
During my experiments with the wrap-around ASI,
I too started with the controls in a clasic spin entry,
and felt the stall, and then ended up in what
I could not discern was a spin or a spiral.
So I'd release the elevator pressure (assumed it
was a spin) and recover from the dive.
I did spins both before and after this in the
Blanik (with a non-wrap ASI) and they seemed
very easy to tell the difference from a spiral, and
quite easy to sustain as a spin for 4 turns or whatever
you wanted, with a subsequent quite well defined
spin recovery.
The spins in the other glider were at fairly forward
CG, so
after looking at it, I wasn't that surprised it didn't
stay in a spin.
I think Hartley was correct, that spins and spirals
ought
to be part of a flight review. From the report, however,
it seems this pilot got spin entry training. In all
of my spin entry training, this means crossed controls,
and a full stall, with recovery by flaps/dive brakes/power
to correct position, ailerons neutral, rudder opposite,
stick
pressure released or briefly forward to break the stall.
I can see value in doing full 2 turn spins left and
right,
however, instead of just spin entries (which can be
too mild,
or not give a good sense of spin vs. spiral indications).
I must think, however, that actually doing this in
some gliders
may be either prohibited or may damage the glider or
actually cause structural failure.
A slow reaction with flaps by the student might be
a
big problem. Likewise, practicing spins and recoveries
with
the engine extended in a motorglider might be
prohibited or damaging, but this might be exactly
the training needed to prevent a 180 turn back to the
airport from becoiming a stall/spin for example.
And how many instructors regularly spin a Nimbus or
a DG1000 with extensions or the like?
Honestly I don't know, since
I generally fly 18m or less spans myself...
What a shame to lose your own son though.
Geesh, what a tragedy.
It is to be
of events.
at all.
procedures and
Practice spin
pilot who is even
spin but go into a
Stefan
Mark J. Boyd
Old June 21st 05, 05:56 PM
Stefan
Read it again. His last spin training was 20 years ago and he swore to
never do it again. A pilot who panics when he hears the S-word is not
airworthy. (Respect, yes. Panic, no.)
Then improve your spin training. Spin doesn't necessairily mean crossed
controls.
right,
too mild,
Which it doesn't need. At this early stage, recovery actions are the same.
a
big problem.
Then the student needs more training.
with
You never explored how your glider drops the wing with the engine
extended/running? Gee, I wouldn't let my son be your student.
Stefan
Old June 21st 05, 06:08 PM
Eric Greenwell
M B wrote:
To verify this, I replicated the same situation twice
more
on the same flight. It was surprising how little
onformation I could get through windspeed noise.
I was relying on the ASI, and it was ambiguously
reading either 30kts or 100kts.
Don't the controls feel differently at 30 knots and 100 knots? That
should be a good clue as you begin the spin recovery.
Eric Greenwell
Washington State
USA
Old June 21st 05, 08:10 PM
M B
ago
Three months before the accident 'the pilot
had carried out some flights with the test pilot
(including diving at Vne and the start of spins.'
20 years ago may have been the last time he did fully
developed spins, but 'start of spins' sounds like
'spin entries' to me.
If your point was that his training was inadequate,
or
that perhaps the spin entries were demonstrated rather
than
trained, these are both possibilities, and I would
agree.
I recently had a student do some spin training with
me
and was happy to see him seek it out before flying
a very tautly spinning single-seater. I recommended
another
aerobatic glider instructor for further aerobatics
if
he wanted more interesting training. Some exposure
to aerobatics every so often seems to be good
for pilots.
right,
too mild,
I might have this out of context. Please elucidate.
Spiral and spin recovery actions are quite differently
spelled out in our US manuals. I've also found that
students
'get it' after doing some 2-turn or more spins, but
don't necessarily 'get it' after only spin entry
recoveries.
with
the engine
student.
I do not plan to teach spins with the engine extended
in contravention to a flight manual, such as the DG500MB,
paragraph 2.9
I know you weren't suggesting teaching spins in contravention
to the flight manual. I certainly agree with exploring
non-prohibited edges of the
performance envelope to get a feel for the aircraft
(including the control stiffness felt at higher speeds).
But why don't you do this with your son yourself, Stephan,
aren't you an instructor?
Stefan
Mark J. Boyd
Old June 21st 05, 08:25 PM
M B
AFTER I did it, yes I thought back and yes, the
control pressure was definitely more than expected
at low airspeeds.
But WHEN I did it, I think the surprise of
looking at an ASI and having it tell me...
ambiguous garbage...
distracted my keenness to listen for airflow
or feel for control pressures.
The controls on this glider were quite light to
begin with. The airflow sound was actually
easier to detect for me than control pressures
in this (fairly noisy) glider.
I just distinctly remember it was the very
first time I had ever looked at an ASI where it
was impossible to read as a stand-alone indication
of airspeed. That was very, very strange for me.
Before that, I'd never flown any aircraft with a
wrap-around ASI and done intentional spins.
Part of why I'm writing this now is because the
was quite fascinating. I had to do it many times and
study the ASI to really believe I was in a spiral and
recovery and not a spin. The ASI needle whipped
around in a flash.
I tried spins later with further aft CG and was able
to
sustain spins, with the expected noise and control
feel
indications.
At 17:24 21 June 2005, Eric Greenwell wrote:
more
100 knots? That
Change 'netto' to 'net' to email me directly
Eric Greenwell
Washington State
USA
Mark J. Boyd
Old June 21st 05, 08:45 PM
Stefan
me
We ask it from ours before transitioning them to the first single seater.
Luckily, gliders cannot read. :-) Recovering from a developed spin is
certainly different from recovering from a developed spiral dive. But at
the early stage, when the glider just drops a wing and pitches forward,
your neither in a spiral nor in a spin yet. At this early stage,
corrective action is quite simple: Immediately stick forward and
opposite rudder. In most cases, this will do the trick just fine, and
you won't even know whether it would have developed into a spiral or a
spin. If a spin or spiral develops, you're in a different situation, of
course.
paragraph 2.9
Dropping a wing with the engine extended is part of our "club syllabus"
for transitioning to the DG505M/22m. If you have never done it, it's a
real eye opener how aggessively the wing will drop. Of course, we don't
let the spin develop but take immediate action. (The glider will recover
after about a quarter of a turn.)
Try it! You don't need to cross the controls, just pitch up with the
engine running until the glider ceases to fly. It *will* drop a wing
then, you have no chance to hold it with the rudder. As I said, an eye
opener.
Stefan
Old June 21st 05, 08:55 PM
Stefan
I find it even more surprizing that somebody in this situation would
look at the ASI at all...
to
feel
indications.
See? You *can* tell a spin from a dive if you have familiarisized (?)
yourself with the glider. Which you should (must, according to the
legislation where I live and fly) in your first couple of flights, anyway.
Stefan
bush rules! Be Kind Military Aviation 53 February 14th 04 04:26 PM
AmeriFlight Crash C J Campbell Piloting 5 December 1st 03 02:13 PM
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) Rich Stowell Piloting 25 September 11th 03 01:27 PM
