GPS switched S for N!
Old June 22nd 05, 01:31 AM
George Patterson
Jonathan Goodish wrote:
Attempting to resist technology in the
cockpit is a losing battle.
If you own your own aircraft, it's very easy; just don't buy it. What's a losing
battle is the attempt to convince other pilots not to rely on this neat
"newfangled gizmo."
George Patterson
Why do men's hearts beat faster, knees get weak, throats become dry,
and they think irrationally when a woman wears leather clothing?
Because she smells like a new truck.
Old June 22nd 05, 03:52 AM
Jonathan Goodish
In article nj2ue.645$Z.549@trndny05,
losing
"newfangled gizmo."
I'm not sure what you're saying. The fact is, GA cockpits are moving
toward glass. Navigation is moving away from terrestrial navigation and
toward satellites... and the GPS system has been around for a very long
time. Sure, you can stick with legacy technology, but pretty soon
you're either going to be forced to upgrade, or be content to fly around
with limited navigational capability. Cockpit technology isn't going
back to simple transistors and vacuum tubes, it's moving toward a
PC-driven environment, like it or not.
If I were a CFI, I would NEVER discourage the use of technology in the
cockpit. It enhances safety tremendously, and even saves lives. It
improves operational efficiency. It is part of using "all available
information" in order to safely complete the flight. Using technology
like a GPS isn't "required," but those who have access to it and don't
use it are foolhardy in my opinion.
JKG
Old June 22nd 05, 05:25 AM
Dave Stadt
"Jose" wrote in message
When I got up to the mouth of the bay, I turned around and followed
the bug back south. [...] my destination was 5,900 miles distant, and
the time to
get there was 84 hours.
When I got home, I scanned out and out on the map, to find that my
waypoint was now located in the Andes on the Argentinian side of the
Chile-Argentina border.
What happened?
What happened was precisely why I am so vocal about paper charts and
against reliance on this newfangled gizmo thang. (and horrified at the
thought of central computer control of airplane systems)
I find I make many more mistakes than than these newfangled gizmos that have
been around now for 15 years. What bothers me is pilots relying on old
technology when they could increase their situational awareness many times
over if they took advantage of current extremely reliable technology.
Old June 22nd 05, 05:30 AM
Jose
cockpit.
There's a difference between the use of technology and the =reliance= on
it. I agree that we should all be able to =use= the available
technology. However, I see too many pilots, especially new ones, that
=rely= on it to such an extent that they could not navigage without it.
=This= is dangerous.
Jose
My other car is up my nose.
Old June 22nd 05, 05:49 AM
Chris G.
In the Cherokee and the C150 I train in, there are some ancient
(1997-era) Magellan GPS units that have VERY limited capabilities and
even more outdated databases that can't be updated. I don't have any
trust in that technology. I do trust the VOR(s) though. I trust the
compass for dead reckoning. Frankly, I don't want to know much about
that GPS as I have no intent on using it. I would rather master the
"legacy" skills needed to navigate using terrestrial navigation
techniques. I'll add technology later as I can and desire to.
Chris
cockpit.
Jose
Old June 22nd 05, 11:05 AM
Cub Driver
On Tue, 21 Jun 2005 18:56:32 -0400, "Guillermo"
I use a KLN 94, but when I input coordinates and waypoints, I always
crosscheck the distances and bearing with a chart to see if everything makes
sense.
I had been using the waypoint in question for nearly a year, and had
used it most recently a week earlier.. It wasn't "input" incorrectly.
It actually changed from 42N to 42S in a 7-day period.
I didn't want to complicate the post, but another user-defined
waypoint also moved. In this case, it appears to have adopted the
coordinates of my home. This was Mountain View airport in Wolfeboro,
which I punched in a month ago in preparation for going to an open
house there. (In that case I didn't enter the coordinates, but put the
cursor on the map where I knew the airport to be, and punched it in.)
I did notice, when I was flying north to Lake Winnipesaukee on
Saturday, that the MtnView locator seemed to be in the middle of Great
Bay. But since I wasn't heading there, I ignored it.
For years I used a Garmin III+ (not aviation) and all my waypoints
were user-defined. I never had a problem with it.
-- all the best, Dan Ford
email (put Cubdriver in subject line)
Warbird's Forum:
www.warbirdforum.com
Piper Cub Forum: www.pipercubforum.com
the blog: www.danford.net
In Search of Lost Time: www.readingproust.com
Old June 22nd 05, 01:09 PM
Bob Moore
Yep! I caught the same flack way back during the switch from
Radio Range to VOR/DME.
I've been through Radio Range, Manual DF, Celestial, DR Plotting Board,
CONSOLAN, Pressure Pattern, LORAN A, LORAN C, OMEGA, Inertial NAV, ADF,
TACAN, and VOR/DME. I'll take GPS anytime!
Bob Moore
Old June 22nd 05, 02:46 PM
Jose
.... and actually there are too many pilots who can't navigate VFR
without VORs.
Jose
Old June 22nd 05, 07:28 PM
Jonathan Goodish
cockpit.
Reliance on ANY one technology is generally not good. However, pretty
soon reliance on GPS for navigation will be essentially mandated by the
market. When you're IFR in the clouds or above a layer, you have to
rely on technology for navigation, whether that's old technology or new
technology.
I use GPS as the primary means of navigation on long flights. I have
weather uplink and TFR updates every 12 minutes. No chart or other
legacy technology can come close to that capability. However, if I'm
making the breakfast or dinner run, I never rely on my GPS--it's all
pilotage, even if it's out of the local area. For long flights, I
always have charts on board (both IFR and sectionals) and VORs tuned for
backup. I am always on a flight plan when making long flights.
I think students should be encouraged to use "all available
information." That means GPS (handheld or otherwise), VOR, ADF, etc.
Use flight plans, and get flight following when on VFR cross countries.
My handheld GPS units have been more reliable and more precise than any
other radio in any of the airplanes I've flown since I started flying 10
years ago. There is nothing inherently bad about GPS, and teaching
students to shy away from it is doing them a disservice, given the fact
that GPS and other modern technologies are the future.
JKG
Old June 27th 05, 04:09 PM
Tina Marie
In article , Jose wrote:
I use 'em when I hafta, and they're cool when they work, but I've never
seen the blue screen of death on a sectional!
No blue screen of death, but I have had several total sectional failures
in flight.
See, I used to own an open-cockpit biplane, and if you weren't very
careful about folding/unfolding them, the wind could catch them and
they were gone. I once lost 3 copies of the same sectional on the
same flight.
Tina Marie
http://www.tripacerdriver.com "...One of the main causes
of the fall of the Roman Empire was that, lacking zero, they had no way
to indicate successful termination of their C programs." (Robert Firth)
Fun weekend buying an Arrow (long) Jack Allison Owning 44 April 20th 05 12:29 PM
Fun weekend buying an Arrow (long) Jack Allison Piloting 45 April 20th 05 12:29 PM
