I use flightstar: I particularly like the navlog with all of the
enroute nav and comm freqs. For longer trips not carrying a PC, I use my AnywhereMap PDA. On the PDA, you have to work out the routing on a chart, but then you can get winds from wxbrief and enter them into the flight plan to get estimated enroute times. |
On Thu, 23 Jun 2005 13:05:23 -0700, "Chris G." nospam@noemail wrote:
I'm considering purchasing flight planning software, such as the Jeppesen FliteStar or the RMS software or some other flight planning software after I finish my flight training. I don't intend to have it plan the route for me, but I do want the ability to change my mind "on the fly" and see how that impacts my flight planning. I still prefer to do the final planning by hand on paper with the software as a backup to make sure I didn't make a large error in my calculations. What have your experiences been with the different software? What did you like and dislike about the software you used? Thanks, Chris Have you had a look at www.pocketfms.com This runs on a PC and PDA can even connect to a GPS for moving map display. It's free but you can donate for improved maps. Don't be put off by it being free, it's very good. It's easy to use but has so many features it takes a while to get used to. There are over 600 users and all are free to contribute to it's development & many do. Give it a try then come back here with your comments. David |
I am using PocketFMS for preliminary flight planning. It's an amazing
piece of software, especially since it doubles as a VFR GPS solution. However, it is being produced in the Netherlands and while their European data appears to be very reliable, the US mapping has some glitches. For example airports are stored twice (e.g. LAX and KLAX), weather info is not always updated and it's hard to find out whether you did indeed get current weather. Also the Navlog printing may or may not work. I'd recommend using PocketFMS to quickly plan your route, then print it out and finish it by hand or using other software to add wind correction. I have also tried out aeroplanner.com and found it passable. My main complaint is that it's entirely web-based and their server is not very responsive. Planning a flight from scratch just takes too long. |
On 24 Jun 2005 13:05:53 -0700, "grubertm"
wrote: I am using PocketFMS for preliminary flight planning. It's an amazing piece of software, especially since it doubles as a VFR GPS solution. However, it is being produced in the Netherlands and while their European data appears to be very reliable, the US mapping has some glitches. For example airports are stored twice (e.g. LAX and KLAX), weather info is not always updated and it's hard to find out whether you did indeed get current weather. Also the Navlog printing may or may not work. I'd recommend using PocketFMS to quickly plan your route, then print it out and finish it by hand or using other software to add wind correction. Much of the data for this prog comes from DAFIF which is soon to be unavailable to the public. This has prompted a system being developed where selected users around the world will provide the information to update the database. The result should be more accurate and up to date information. At present the update cycle is 28 days but for contributors it is updated every 2 hours. Navlog printing works fine with me. Just print in landscape then fold in two. Since the authors of PocketFMS respond to queries and suggestions this is developing into a superb prog. It is being developed to allow individuals to customise many aspects of its use making it very flexible. David |
I used FliteStar for a number of years. In my opinion it is the best quality
and easiest to use. The downside is like everything else Jeppesen sells they get an awful price for it. Over the years I've tried just about all the other flight planning software and none of them did it for me in terms of functionality and usability. The usability piece I'm sure has a lot to do with what you get used to. This year I tried and switched to Voyager. It had a lot of neat features and it came close enough for me in terms of usability. I had some discussions with the President of the company about some shortcomings that might stop me from using the software and at the end of the conversation I wound up purchasing the product and wound up as a beta tester. They have a free download of their software and I recommend giving them a try. http://www.seattleavionics.com/default.asp I would suggest trying a bunch of different programs and seeing which one meets your needs and is easist for you to use. "Chris G." nospam@noemail wrote in message eenews.net... I'm considering purchasing flight planning software, such as the Jeppesen FliteStar or the RMS software or some other flight planning software after I finish my flight training. I don't intend to have it plan the route for me, but I do want the ability to change my mind "on the fly" and see how that impacts my flight planning. I still prefer to do the final planning by hand on paper with the software as a backup to make sure I didn't make a large error in my calculations. What have your experiences been with the different software? What did you like and dislike about the software you used? Thanks, Chris |
I went over to a friend's house this weekend and played around a bit
with his Jepp FliteStar progran, but the functionality I want it going to set me back $249 initially. I don't even know if that comes with any updates? If not, then I have to add even more money to that figure...ugh. I really liked the profile view of my flioght that Jepp has compared to the Golden Eagle software. In messing around with the software, I have found that I prefer to plan it on a paper sectional and use ther software to plan a general route that I think I want to fly. In filling out my nav log, I can put on there reference points tha I might not otherwise be able to mark in the computer generated plan. (Example: 1 NM W of KSPB, 3 NM E of KKLS, BTG 300 FROM) I found it interesting that none of the software I have selected so far is more specific on a PA-28 than to be a "generic" pa-28. I fly the Cherokee 140, which does have a different performance than a Cherokee 180. Minor gripe, I guess, but a little annoying because the POH for the Cherokee (1969) really sucks. Long story short, I'm going to hold off on buying any software for a while becvause I don't really need it. The Golden Eagle does a passable job of helping me "rubber band" the routes so I can find a better route. to tweak on paper. Chris Chris G. wrote: I'm considering purchasing flight planning software, such as the Jeppesen FliteStar or the RMS software or some other flight planning software after I finish my flight training. I don't intend to have it plan the route for me, but I do want the ability to change my mind "on the fly" and see how that impacts my flight planning. I still prefer to do the final planning by hand on paper with the software as a backup to make sure I didn't make a large error in my calculations. What have your experiences been with the different software? What did you like and dislike about the software you used? Thanks, Chris |
Have you ever tried AirPlan? You can download the 30 day demo from
http://www.razorsedgesoft.com/airplan.zip |
more specific on a PA-28 than to be a "generic" pa-28. I fly the Cherokee 140, which does have a different performance than a Cherokee 180. Minor gripe, I guess, but a little annoying because the POH for the Cherokee (1969) really sucks. Most decent packages allow you to edit the aircraft performance profiles. Jeppesen's FlightStar/FlightMap allows extensive modifications and you can swap data files with other users. |
Chris wrote:
In filling out my nav log, I can put on there reference points tha I might not otherwise be able to mark in the computer generated plan. In Jepps' FlightStar, you can easily add user waypoints to your route that will show up on the NavLog. Additionally the software automatically calculates TOC (top of climb) and BOD (begin of descent) waypoints and automatically includes those waypoints in the NavLog. I found it interesting that none of the software I have selected so far is more specific on a PA-28 than to be a "generic" pa-28. I fly the Cherokee 140, which does have a different performance than a Cherokee 180. The profiles included in FlightStar normally are considered starting points and/or generic aircraft. You can either find a profile more specific to your aircraft from someone else who has already customized the profile or you can do it yourself using the POH, your experience, or both. -- Peter |
AOPA Stall/Spin Study -- Stowell's Review (8,000 words) | Rich Stowell | Aerobatics | 28 | January 2nd 09 02:26 PM |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
AirPlan Flight Planning Software Update | Dean Wilkinson | Products | 0 | October 25th 04 11:22 PM |
WINGS: When do the clocks start ticking? | Andrew Gideon | Piloting | 6 | February 3rd 04 03:01 PM |
Global Aviation Flight Planning Software – Free | Greg Siemon | Instrument Flight Rules | 0 | December 20th 03 05:42 PM |
